Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Dec 30, 2023 at 12:19 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    definitely shim the drywall.
    if you really wanted to cut the tile, cutting down the center of the full-face tile is going to suck. need to do it with a wet grinder and diamond blade, which is going to end up with a tile milk shake dripping off that will need to be contained. some guys would do the cut dry, but you'll be cleaning dust out of the entire house for the next 6 months. you'll also need at least 5-6 carbide-edged oscillating tool blades for the edges the grinding wheel won't fit into, also going to risk some cabinet damage with the grinder, and the strong possibility of a non-straight line, though a bead of cauk ought to correct most of that as long as the grinder doesn't run away on you.
    Drainbung and Sig45 like this.
  2. Dec 30, 2023 at 12:29 PM
    MGMDesertTaco
    Which microwave did you pick? :popcorn:
    Sig45 likes this.
  3. Dec 30, 2023 at 1:11 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    After spending more time than I'm willing to admit on this project, it is complete.
    All it took was three trips to Lowe's...and that's after the new microwave was delivered.
    This is what we went with. Opted for 1/4" and that was not thick enough, so we stacked a second 1/4" panel on top of it. 3/8" would have been perfect but I didn't see any at Lowe's. It was close enough.
    https://www.lowes.com/pd/Whirlpool-...gerprint-Resistant-Stainless-Steel/1000293839
    Got this on sale for $250.
  4. Dec 30, 2023 at 1:18 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Water filter was dripping for a while. Wasnt awful but started getting worse. About 2yrs use on it:rolleyes::rolleyes: ordered a new "manifold" and the waterline quick release for one side was broken new in the bag:rolleyes::rolleyes::rolleyes::rolleyes::rolleyes: luckily i could remove it from the old one. Can see the good one and bad one
  5. Dec 31, 2023 at 5:18 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So this was almost a week ago, but I'll share anyways...
    This is the $425 Christmas pinhole leak...
    After Christmas dinner was over I went down stairs and grabbed a beer and looked into the mechanical room like I always do. I could see the blocks I have the water heater on was wet. Thought well I guess I get to do a water heater tomorrow. Nope. Was the copper line for the radiators. Was a small drip so I just set a 5 gallon bucket under it. I was not paying for a service call in Christmas. I can solder copper and make those repairs, but I've never drained, filled, and purged a boiler. Next day at 7:25am called the service guy and he was here by 9am. Took about 2 hours to get everything done. The radiator cover assembly had been rubbing that pipe since 1965! Guy had no problem at all showing me the drain, fill, and purge procedure. My system is a huge PITA to get all the air out so I had to purge each zone again after a while. Seem to have gotten all the air out now. I know this will probably happen again as I looked at the other radiators and some of them are exactly the same.
    I will have to replace the firebox on the boiler come spring. It's deteriorated enough where it will probably not go through another season without blowing a hole out the back. Although spending $2000 vs $10,000 for a total system replacement I'll have to bite the bullet and get it repaired.
  6. Dec 31, 2023 at 6:46 AM
    ralfnjan
    ralfnjan Well-Known Member
    Before xmaas I spent $200 for the plumbers to tell me my well was dry. I thoughjt it was the pump. Doh! They pulled it up, I cycled the power, back in the hole below the usual depth a bit and it was blowing water quite nicely.
    All rain-ed up now, lots of water.
  7. Dec 31, 2023 at 6:52 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    If you set it below the old depth and are now getting water then indeed it may be "going dry". This might get you by till you get a new one drilled.
    One of my biggest fears living out in the country here...
  8. Dec 31, 2023 at 7:01 AM
    ralfnjan
    The well is 16 feet blasted out with another 20 feet drilled. Fine for Nov to May, then I have a 3000 gallon tank and booster pump for rain water, well for drinking is fine through the summer. I went back to the well too soon this year. I had forgotten my rule of thumb...when there's water coming in the sump pump hole there's enough water in the well for constant use. Had me worried for a while. I thought I'd be hauling water in teh winter, nnot fun.
    Water softener meter says we use about 50 gallons per day
  9. Dec 31, 2023 at 7:09 AM
    wilcam47
    Will
    Bourbon state
    What state are you in?
    Drainbung and Delta09 like this.
  10. Dec 31, 2023 at 7:17 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea that's a ridiculously high water table! That almost seems like Upstate NY.
    Drainbung and wilcam47[QUOTED] like this.
  11. Dec 31, 2023 at 10:29 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    My wife has been complaining about her bathroom sink running slow so I cleaned it out this morning.
    You never really get used to that smell, do you?
    308savage, wilcam47, Delta09 and 4 others like this.
  12. Dec 31, 2023 at 12:42 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  13. Dec 31, 2023 at 2:27 PM
    ralfnjan
    Ontario. Limestone 5 feet below the dirt level.
    wilcam47, Delta09 and Drainbung like this.
  14. Jan 1, 2024 at 2:58 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Hah, been doing most all my own work for years so I'm used to it. Even opening the lid to the septic for a quick look on things doesn't even phase me.
    Now, when I have to do the occasional work to the drains on the commercial hand washing sink at work. Yea, I'm gagging :laugh: Or a main line clogs up and sewage is coming out of the floor drain due to people flushing paper towels. Yea no. Bathrooms get locked and I nope out of that. :rofl:
  15. Jan 3, 2024 at 3:58 PM
    98tacoma27
    Ben
    Not Beech Creek
  16. Jan 6, 2024 at 11:52 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    True or false, a post on top of a wood floor cannot be load bearing?
  17. Jan 6, 2024 at 11:56 AM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    ^ based on the hundreds of episodes of This Old house I’ve watched; I’d say no.
    Probably need proper [x?] then consider something cosmetic wrapped around it
  18. Jan 6, 2024 at 11:59 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
    I see no reason that it couldn't be but that's entirely dependent on what's underneath it holding it up.
    ImpulseRed008 likes this.
  19. Jan 6, 2024 at 11:59 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    shouldn't be
    what is under them in the crawl space
  20. Jan 6, 2024 at 12:41 PM
    soundman98
    NW Indiana
    in this case, it should not be load bearing, as it's a decorative post. the largest load it can carry is the rating of the lumber at the thinnest cross section. far too much material is removed from those posts in too many places to be anything but decorative.
    load bearing supports are generally either square solid lumber(4x4 minimum) that's either wrapped, or concealed within a wall, or metal poles that would support an i-beam. the poles can be wrapped as well(basically a 'hot dog bun' around the pole), though concealing them within a wall is more common.
