Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. May 18, 2024 at 6:36 AM
    soggyBottom
    soggyBottom Well-Known Member
    I'm repairing the railings on the stairs that go to my deck. There are LED lights on the posts and I'm not sure how to do the wiring. Right now it looks like ass. It's low voltage. I think the transformer is pushing 12v but it may be 24.
    The original work had exposed wire nuts that were glued in place. I had a hard time unscrewing them. What is a nicer way to do it?
    shakerhood and wilcam47 like this.
  2. May 18, 2024 at 6:52 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    1/2" Pvc conduit? Spray paint it brown?
    shakerhood, Drainbung and 308savage like this.
  3. May 18, 2024 at 7:56 AM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    I've started a ceiling crack repair, the ends of the drywall sheets were just floating in space. I went into the attic and installed nailers. Is there any better way of tenting off an area to contain all of the drywall dust?
    shakerhood and MGMDesertTaco like this.
  4. May 18, 2024 at 8:04 AM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    Try a "sand-n-clean"??? I think that is what it is called. Hand sander with hose attached to s a small (1 gallon bucket??) and another hose from there to a shop vac.....keeps dust somewhat under control and collects in the water bucket. Otherwise, I got nuthin'
    soundman98 and Drainbung like this.
  5. May 18, 2024 at 10:11 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Ive done a vacuum close to the actual work site (ie where you are cutting/sanding) (with a HEPA bag) and then done two different methods. 1) box fan with a HVAC filter on the suction side. Pulls the air in that space through the filter and collects the dust. and 2) use a "shop air filter". pretty much same as the box fan but actually made for it
    Also adding a second (even third) plastic sheet wall can help. Off set the entrances on them. Then take them down from the dirty side first.
    Drainbung likes this.
  6. May 18, 2024 at 10:17 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    From a couple days ago. Changed out the kitchen light to 2 separate pendant lights over the island. You can see the non box that was in use when I pulled the old light out, from the previous owners. Luckily had enough wire to run to the new light and didn’t need to splice or run new wire. Used ceiling rated boxes and patched the bastard holes.
    Malvolio, 916carl, Fargo Taco and 7 others like this.
  7. May 18, 2024 at 5:28 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    how to make it nicer really comes down to how much money you want to throw at the problem. pvc conduit might be the nicest, but really any conduit solutions will require entirely re-wiring the system from the transformer. one thing i'd suggest is to replace the plastic remodel box holding the splices with an outdoor-rated weatherproof box and cover. i like the pvc weatherproof versions, as they don't rot out. they do make cable glands that make the wire entry sealed, but they aren't always stocked, and it's just as easy to seal the cable entry into the box with a tube of silicone.
    the official install guidelines for those low voltage lights state to use waterproof wire nuts, the ones with the 'fingers' in them, and full of dielectric grease. however, the vast majority is done by landscapers and is installed exactly as you're not happy with. so it's not like there's a better method that's being actively sold these days either
    one thing i found after installing those waterproof wire nuts is that the twisting action to tighten the wire nut usually squeezed all of the dielectric grease out. so to prevent call-backs, i'd use a can of this to re-fill the wire nut after tightening to ensure that it's as waterproof as i can make it.
    there's zipwall products. https://www.zipwall.com/shop/dust-barrier-zippers-and-doors/
    a contractor i used to work with on high-end remodels used them on every single job. he'd always include the zipper closure into most jobs, and had a few of the spring-loaded poles to hold the plastic sheet up.
    HOWEVER, he always did what you've already done with blue-taping the plastic/drywall intersection, as most dust otherwise got past the seam. but the zipper opening was a huge improvement to work access, as we weren't moving/billowing the entire sheet and creating a small wind near the area that would suck/blow debris out of the work area. another thing to make sure of is to tape off any air duct returns in the work area-- those will also pick up and distribute the dust through the house. no solution is perfect, there's always going to be some dust that gets out and through the rest of the house, but it's greatly reduced via those methods.
    another post mentioned the vac attachment. i recall the kit he was talking about, but can't seem to locate it anymore-- it was an all-inclusive vacuum/sander kit.
    this one that popped up in my search is the hose/sander attachment that connects to any standard shop vac.
    https://www.menards.com/main/tools/...it/09165/p-1444433725663-c-8951.htm?exp=false
    https://www.homedepot.com/p/Hyde-Mini-Dust-Free-Sponge-Sander-292932/316803235
    https://www.homedepot.com/p/MARSHALLTOWN-Vacuum-Sander-with-6-ft-Hose-VS792/100645895
    alternatively, there's also the wet-sanding method that uses this sponge.
    https://www.menards.com/main/paint/...p-1110455652168-c-1528807000872.htm?exp=false
    https://www.homedepot.com/p/Armaly-ProPlus-Drywall-Finishing-Sponge-Case-of-6-00610/314973515
    my dad absolutely loves the sponge sanding method, and prefers it over any other method. i attempted it on my bathroom remodel, and couldn't get the technique right, and went back to normal dry-sanding.
  8. May 18, 2024 at 10:36 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    For low voltage stranded, these might be nicer to extend wire cleanly and without water intrusion.
  9. May 18, 2024 at 10:41 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    +1 on zip wall, like he said still need to tape..
    if you don’t want to buy the whole kit, and no fancy zipper you can buy poles individually that essentially do the same thing from harbor freight.. I have both a zipwall kit and some of these poles for various projects
    also can you box fan a window within the space?
  10. May 18, 2024 at 10:43 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Love these mother fuckers. Got boxes on boxes :fistbump:
    shakerhood and soggyBottom like this.
  11. May 19, 2024 at 6:58 AM
    soundman98
    NW Indiana
    that reminds me. never saw one on a professional job, but for a while i was on many jobs where the homeowners made their own and swore the results were worth every penny for dusty inside-the-house projects.
    get 4 HVAC filters, tape them together and put a box fan on top:
  12. May 21, 2024 at 1:56 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    IMG_7740.jpg Here’s the finish product of the butchered pavilion I helped recover…IMG_7739.jpg IMG_7741.jpgWood work only. The hip roof was a debacle to put it mildly.
    TacoLarn, Malvolio, 916carl and 11 others like this.
  13. May 21, 2024 at 4:37 PM
    soundman98
    NW Indiana
    i'm surprised there's not a hanging fan in the center. that's usually one of the first things they always want to make sure gets installed in my area.
  14. May 21, 2024 at 5:51 PM
    SH7mi
    Kevin
    West Grove, Pa.
    One is being installed, a 70”. I installed support framing for it. If you zoom in on the one photo you can see a yellow wire drop.
  15. May 22, 2024 at 5:41 PM
    SH7mi
    Kevin
    West Grove, Pa.
    IMG_7744.jpgHere’s the fan
  16. May 25, 2024 at 10:58 AM
    jsi
    jsi Well-Known Member
    native earthling
    Nice, I have a fan that looks just like that on my outdoor patio too. I'm about ready to replace it with a 3 blade model though. The swallows love it and want to build nests there. For tiny little birds they sure make a mess. Every year I have to remove the blades in the spring and reinstall them for the summer, a 3 bladed fan would make that annual task quicker. Other than the nesting problem I do like it.
    SH7mi[QUOTED] likes this.
  17. May 25, 2024 at 11:11 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    you could try bagging it with an oversized trash bag so there is no nesting surface held in place with a zip tie or 2
    jsi[QUOTED] likes this.
  18. May 25, 2024 at 3:48 PM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    I have a little trim to put up on the chimney, then some touch up work. But I just painted my house inside and outside. I'd say I have about 5k in materials, but I replaced a bunch of trim and siding so I'm fine with a 5k summer project. Now I have Solaris loaded to go camping for a few weeks. Starting in the sand dunes, then off to the VLA in new Mexico. Then over to meteor crater painted desert petrified forest, back up through dinosaur into wyoming and home to FOCO!
    I also replace all the overhead lighting, and put all new bathroom kitchen sinks and hardwares. The whole house feels bright and fresh after i got rid of all that dark stained Regan era wood. The house is still a 1980s pig, but now it atleast has lipstick... I can get back to being a man child again.
    What do you think? Upgraded life right?
    Edit: I'd love some inexpensive suggestions for the chimney. Even once I put the rest of the trim on fix the rain gutter paint down the side of the house (fix it all) it will still look weird. It always did. My neighbor suggestions are 1x1 batons run vertical spaced so that I have about 3 or 4. I think it will look fucking stupid. I'm then drawing attention to a pigs ass. Any real home improvement ideas I'd love some advise on this project . I have a thick skin. Give me some truth. I know the roof needs replaced, what how can I rehab the overgrown 1980s zero scape? My current plan, I'd to rent a skid loader put the thickest landscape black shit down directly over the surface. Fuck sifting rocks all summer with a separator. Is that crazy or should I make some kind of shaker ( I grew up in Alaska in mining culture) to salvage the old rock? My land is .25 archers and was originally zero scaped. Not enough rock was originally added so spots are bear now!
    We also discussed using the ditch feature as a 4x4 track. Any ideas?
  19. May 25, 2024 at 8:55 PM
    wilcam47
    Will
    Bourbon state
    cool looking place
    They have all kinds of faux rock or brick panels would look better than that. Just my .02cts
  20. May 26, 2024 at 4:41 AM
    G2.M6
    Fort Collins CO
    Yup, I'm looking hard at the fake rock.
