Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 1, 2024 at 4:18 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Repainting the vertical deck took FAR too long, but it's done. Hopefully we move before it needs to be done again.
    Now that the painting is done I need to take care of some landscaping.
    JPTx, pdenajim, Delta09 and 10 others like this.
  2. Aug 2, 2024 at 5:39 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Took out the wall. So how greedy do I get for the shower? 34x48 or push it to 36x60?
    Charlie Too and MGMDesertTaco like this.
  3. Aug 2, 2024 at 5:43 PM
    MGMDesertTaco
    3ft x 5ft
  4. Aug 2, 2024 at 7:07 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    36x60 of course. absolute worst case if it's somehow too large, a bench could be added. i'm told that ladies love the bench for shaving in the shower.
    T4R_hereforbearings and daveeasa like this.
  5. Aug 2, 2024 at 7:08 PM
    daveeasa
    David
    PNW
    shakerhood likes this.
  6. Aug 2, 2024 at 7:14 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Bigger is better!
  7. Aug 2, 2024 at 8:28 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Depends on what you are planning on doing in the shower!
  8. Aug 2, 2024 at 8:30 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Not really. You want to be able to do anything and everything you can think of whenever you think of it, so bigger is better.
  9. Aug 2, 2024 at 8:41 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
  10. Aug 2, 2024 at 8:54 PM
    soundman98
    NW Indiana
    not really. as any of us get older, we get less flexible, so the more space to move to perform the same reach, the better.
  11. Aug 3, 2024 at 7:25 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    F all this noise.
    Rented a drain camera myself since the plumber didn't come, found the bladder that was stuck in the line and found the spot the pipe was broken.
    Proceed to cut concrete open enough, time consuming without a concrete saw.
    Dig out around existing pipe with a Sawzall blade.
    Then tried multiple times to glue on two fittings fast enough but I do not have the skill or speed apparently.
    Settled on this compression fitting before I was going to resort to rubber couplings.
    Letting it dry out tonight so I can watch it tomorrow for leaks before I seal it all again
  12. Aug 5, 2024 at 6:46 PM
    Aaron O.
    Aaron O. Well-Known Member
    Aaron
    Denver, CO
    2023 Tacoma Off Road DCLB
    After getting a quote from Home Depot to reface my cabinets for $23k I decided just to paint them. The worst thing that happens is that I screw it up and have to buy the Hampton bay builder grade cabinets to replace with for $3k. Still not quite sure what kind of gold laced paint that lady was selling when she gave us that quote the other day! Also I have twin toddlers at home so the working time that I have for this project is 8pm-11pm, should be done by 2025!
  13. Aug 5, 2024 at 8:13 PM
    Christmas
    Christmas Well-Known Member
    Finally ready to sheet it.
  14. Aug 5, 2024 at 9:07 PM
    ScrippsRanch67
    Bob
    Fiberglass shell
    That will be a very nice workshop. Are you going to lay some plastic conduit below to give you and option of floor plugs? Squeeze in a chase? Just a thought.
  15. Aug 5, 2024 at 9:18 PM
    Christmas
    No, all sockets will be in wall. I'm going to insulate and cover all the walls and roof interior in 1/2" ply. Might even get a mini split.
  16. Aug 6, 2024 at 4:18 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Did the same thing with my house, was the most affordable option. I have $300 in paint and new hardware.
    Do yourself a favor and get a couple sets of cheap plastic saw horses for the doors, it's a life saver!
    I see you've already started priming, but I really recommend and oil base to seal everything and get it to stick. I know having two young children the smell can be an issue. Kilz makes and odorless version. It's not completely odorless, but is reduced a whole lot. I used Benjamin Moore Advance as the paint. It's $80 a gallon, but rolled on correctly it'll look like you sprayed it.
  17. Aug 6, 2024 at 4:25 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Was the Benjamin Moore just interior paint or a cabinet paint? Probably going to be doing this to our kitchen later this year.
  18. Aug 6, 2024 at 4:39 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It's an interior paint, but is made specifically for trim and cabinets.
    https://www.benjaminmoore.com/en-us.../product-catalog/awiap/advance-interior-paint
    It's basically an oil based paint that is soap/water cleanup. Levels out super nice and easy to work with. Roll it on with a 3/8 nap microfiber roller and leaves a smooth finish. I won't use anything else for trim or cabinets.
  19. Aug 6, 2024 at 12:55 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Which Kilz primer do you recommend? Kilz Original Oil Based? About to do the same on cabinets. Many thanks.
  20. Aug 6, 2024 at 1:08 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I used Zinsser Cover Stain. It's a little thicker, but Kilz Original will work fine. Both stink, so be prepared. If you can find it, get some liquid sandpaper and follow instructions listed. Makes it stick even more.
