Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Sep 11, 2024 at 6:10 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Looks great!
    MGMDesertTaco and Drainbung like this.
  2. Sep 12, 2024 at 3:21 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    :101010::101010::101010: looks beautiful.:hattip:
    wilcam47 likes this.
  3. Sep 12, 2024 at 6:47 AM
    RxYoda
    RxYoda Well-Known Member
    Mark
    Florence, SC
    2023 Sport Premium 4x4 DCSB
    That was before!
    - Covers were a bit of a bear to get off. (16 y.o. Unit)
    - Bent fins were pre-existing
    - Cleaned with authorized cleaner 3 times (from outside once, from inside twice, drying with leaf blower between each treatment)
    - Rinsed with water hose on “flat” setting
    - Rinsed inside out with pressure washer with widest nozzle being carefull not to hold too close to fins (12-18”)
    - Fins looked much better (but not new) after
    NOTICEABLE increase in efficiency and reduced run time.
    308savage, G2.M6, Drainbung and 2 others like this.
  4. Sep 12, 2024 at 6:48 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Where's the after picture??
    :worthless:
  5. Sep 12, 2024 at 6:56 AM
    RxYoda
    Mark
    Florence, SC
    Being a little “extra”, I doubt they are as thorough as I (the homeowner) would be. I would expect them to spend 30 minutes cleaning. I would watch them remove covers (Not much on YouTube)
    - Expect ground to become water logged. Ensure drainage.
    - Use safety glasses when using caustic cleaner
    - Manual pump spray goes much further than aerosol (I used both)
    - Use leaf blower before water to remove debris.
    - Use stiff bristle brush to straighten bent fins where possible.
    - Had been 3 years since serviced (slacker doing some traveling)
  6. Sep 12, 2024 at 6:58 AM
    RxYoda
    Mark
    Florence, SC
    I was waterlogged/soaked, hurried in to dry out. Forgot to take pic before covers:crapstorm: ‍. Cleaned covers/exterior too though. Can try to snap some later today.
  7. Sep 12, 2024 at 2:34 PM
    Christmas
    Christmas Well-Known Member
    Finally cool enough to get the roof finished.
    dumontrider, Tiedie, jubei and 9 others like this.
  8. Sep 15, 2024 at 11:49 AM
    Christmas
    Got deck and stairs done. Dog approved.
    dumontrider, jubei, pdenajim and 12 others like this.
  9. Sep 15, 2024 at 4:13 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Does anyone know what brand or type handle this might be? I don't see anything like it at Lowes Depot. The handles there might bolt up, but I don't think they'll reach the metal striker.
  10. Sep 15, 2024 at 4:35 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
  11. Sep 15, 2024 at 5:17 PM
    wilcam47
    Will
    Bourbon state
  12. Sep 15, 2024 at 5:52 PM
    replica9000
    2019 T4R ORP
    wilcam47[QUOTED] likes this.
  13. Sep 15, 2024 at 6:03 PM
    wilcam47
    Will
    Bourbon state
    RustyGreen likes this.
  14. Sep 15, 2024 at 6:30 PM
    replica9000
    2019 T4R ORP
    The color isn't too important. I'm not sure if these are really the same.
    Edit: Mine has a square shaft that goes through the base. The handle is held in with a pin (right of Allen screw). There's a spring that goes over that pin, which is missing in my photo.
  15. Sep 16, 2024 at 3:02 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I had the exact same door at my old house. Pretty sure it's an old style Larson. I don't think you can get an exact replacement anymore, but I did find something similar.
    https://www.amazon.com/Ideal-Securi...1726480830&sprefix=larso,aps,125&sr=8-10&th=1
    Probably going to take some tinkering to get it to latch.
  16. Sep 17, 2024 at 5:59 AM
    Mils Hills
    Mils Hills New Member
    Mils Hills
    The Toto Drake is a solid choice, so it should be worth the hassle. Running into unexpected issues like that can be really frustrating, especially late at night. It’s good that you found a temporary fix with the cap and got the water back on. On another note, if you're looking for part time moving jobs, AroundWire could be a helpful platform. It's designed for connecting people to various opportunities, including short-term and blue-collar work, making it easier to find local jobs or hire someone for a quick moving gig.
  17. Sep 17, 2024 at 12:26 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    Digging 7 footers the age of 56 feels a little different than age 26…IMG_8112.jpg
  18. Sep 17, 2024 at 12:28 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    SH7mi[QUOTED] and RustyGreen like this.
  19. Sep 17, 2024 at 2:02 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Fun multi-day project at a multi-family unit one block from the ocean. My customer has completely redone the exterior. Prior to painting back in May/June, I replaced some vertical v-match pine siding on one gable end. The porch was brick, they recently had the stone work done. The final component was the unsightly front porch. Wrapped the posts in 1x5 Lifespan for a little wiggle room (1/4"). Glued and screwed together (one post was replaced as it was way too warped to wrap). Going to paint the posts in the morning and then install the railings (basic deck style in cedar). Will need to prime that before paint.
  20. Sep 17, 2024 at 5:37 PM
    wahudiditagain
    wahudiditagain Well-Known Member
    Wes
    Central Ohio
    2017 TRD OR DC 4x4 Inferno
    That used to be a 2 hour project. Now it would be over done over 2 days with
    multiple recovery periods.
    Plus I would hurt for 3 days afterwards.
