Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Oct 13, 2024 at 11:35 PM
    Christmas
    Christmas Well-Known Member
    Progress, all be it slow. Finished storage area, windows and wiring. Onto insulation and sheeting.
  2. Oct 15, 2024 at 7:58 AM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Here's something that will make everyone cringe. I finally got a roof over the newest bin on the woodshed, so now I have 4 cords that are covered.
    This is my basic "pallet" construction with the last of the cedar post fencing materials that I scavenged from a neighbor a few years ago when they had a new fence installed. The typical purlins were not used, since this only keeping rain and occasional light snow off of the wood. 2 Long stringers ( front and back) with 3 "joists" ( for lack of a better term) then staggered boxing between that.
    I snapped a line then used a demo blade to trim the front overhang. It would have been a major PIA to trim from the backside.
    Good enough for what I need it to do.
  3. Oct 15, 2024 at 5:32 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    that's built better than most homeless encampments, and those last years!
  4. Oct 15, 2024 at 6:13 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Snake issues?
  5. Oct 15, 2024 at 8:58 PM
    241240
    241240 Sir Lurks-A-Lot
    09 base double cab 4.0 MT
    Sat my fat rear end in it.
    Bought a cheap door at the used door store. Three of the four recessed panels have shrunken, leaving a gap across the top edge of the panel. Worst one is shown in the second photo, it’s about a quarter inch gap.
    Any ideas for an easy way to plug it? We’re going to paint the door so it doesn’t need to be pretty.
    So far I’m leaning towards just trying to rip a piece of scrap wood to fit and gluing it in.
    Drainbung, thomasburk and RxYoda like this.
  6. Oct 15, 2024 at 11:59 PM
    Christmas
    Insulation sucks. It's like a test of your will.
  7. Oct 16, 2024 at 12:42 AM
    Christmas
    FYI. Did you know? The insulating value of wood, by itself is 1.4 per inch to achieve an R value of 1. So, you would need some thick walls to maintain a constant temperature.
    Drainbung and wilcam47 like this.
  8. Oct 16, 2024 at 5:44 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Or did it slide down? Is there a way to reposition the panel centered? I don't know, just trying to think this through...
    jwctaco, 241240[QUOTED] and Drainbung like this.
  9. Oct 16, 2024 at 6:04 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I guess you don’t get snow where you live. I imagine it wouldn’t take too much wet snow to bend that overhang down, unsupported as it is.
  10. Oct 16, 2024 at 9:49 AM
    241240
    Possibly. They don’t feel rattley-loose at all but I haven’t tried moving them with any appreciable effort. I’ll give that a shot after work tonight.
    thomasburk[QUOTED] likes this.
  11. Oct 16, 2024 at 10:04 AM
    soundman98
    NW Indiana
    I would just use a paint-compatible caulk. No need to get fancy if you're not trying to keep the wood grain visible.
  12. Oct 16, 2024 at 4:53 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Replaced a burnt 12V ceiling light with a new one from HD, identical swap so used existing hanging hardware which made it easier, set the lighting on 5K bright.
    Replaced outlet receptical and vinyl plate, replaced single switch and plate, and replaced triple switch and plate one being a 3-way. It feels better and looks better.
    Reason I did this was that the switch in the hallway was worn in the triple switch and caused the light in the family room to flicker when the hallway light was switched on.
    Hallway Light:
    Hallway Switch:
    Family Room Switch:
    Family Room Outlet & Light:
    MGMDesertTaco and wilcam47 like this.
  13. Oct 16, 2024 at 5:21 PM
    2ndhandTacoman
    Walter
    Maryland
    tree rats, mostly. I haven't seen any serpents, thank goodness.
    IPNPULZ[QUOTED] likes this.
  14. Oct 17, 2024 at 10:24 AM
    jsi
    jsi Well-Known Member
    native earthling
    Finishing the basement -
    When I was a kid I used to build model airplanes. The kits were basically a bunch of balsa sticks and a plan. Seems nothing has changed in my life except the sticks are bigger. :rofl:
    Ever since I moved into this house I've wanted to make this cold storage room my shop. It's a beginning.
    First wall on the floor
    Standing. Now I can put up plastic to try to keep the construction dust off our stuff.
    And FUCK! :annoyed:That laser line is on the lowest point of the ductwork and the door was installed by the builder. I don't even have a fraction of an inch for drywall.
    I always knew this was going to be a problem, but I put it off for future me. The project is dead in the water while I get bids from HVAC companies to put in new, skinnier ductwork. Fun$$$
    MGMDesertTaco, Sig45 and wilcam47 like this.
  15. Oct 17, 2024 at 11:23 AM
    Christmas
    Just cut the door and drop it down.
  16. Oct 17, 2024 at 11:27 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Id cut door also
    MGMDesertTaco likes this.
  17. Oct 17, 2024 at 11:29 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    X3. We just finished ours and I've been cutting doors.
    You'll also have to figure out how to support the drywall under the duct so expect some height loss there too. We did 2x4s laying flat
  18. Oct 17, 2024 at 12:22 PM
    RxYoda
    RxYoda Well-Known Member
    Mark
    Florence, SC
    2023 Sport Premium 4x4 DCSB
    If the ductwork is 24” or narrower, you could frame the outer edges with 2x4s and span the area. Probably want a moisture barrier between though. I would also cut the bottom of the door 1/2 to 3/4”.
  19. Oct 17, 2024 at 2:05 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Saved myself a lot of headache when I did my basement by not using drywall and paining the ceilings and ducts black. Looks great and don’t have to worry about things like this.
  20. Oct 17, 2024 at 3:12 PM
    jsi
    native earthling
    I'm a tall guy so I want every inch I can get. And, most importantly, the wife vetoed the idea of cutting the doors. We will see what she says when the bids come in. I briefly entertained the thought of tearing out the entire forced air system and going with a ductless heat pump mini split system. I got one quote at $30K and promptly dropped that idea.
    I've worked on a number of commercial builds where they did just that, paint everything black and call it good. I don't mind the look, but not the vibe I'm after.
