Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Oct 17, 2024 at 10:20 PM
    island taco
    island taco Well-Known Member
    Vince
    victoria, canada
    White '23 LBDC TRDSport
    Kicker speakers, Key amp, Spiker hood struts, tonnueo cover, Cooper AT3 4s, Method Double Standard Bronze
    move the door to the right
    jsi likes this.
  2. Oct 17, 2024 at 10:39 PM
    MGMDesertTaco
    How about a hidden Murphy door? The trim would cover a lot.
    https://murphydoor.com/products/pai...MIv5fBoZuXiQMVIiCtBh1uLhZnEAQYAiABEgK4r_D_BwE
    shakerhood and jsi[QUOTED] like this.
  3. Oct 21, 2024 at 4:31 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So, I've had this ugly ass bush thing by the corner property line post (don't ask...). I've always hated it, even after trimming. Just didn't look right out there in the yard.
    What it looked like when I bought the place.
    Welp, today I got tired of it and went at it...
    Removed, top soil spread out to try and level the area, and put down some grass seed.
  4. Oct 21, 2024 at 4:32 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Did you rip out the root ball with the 4th gen?
    RustyGreen and Delta09[QUOTED] like this.
  5. Oct 21, 2024 at 4:35 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    No, the thing was right along the drain field for the septic. My luck the roots would have run deep and I would have done some expensive damage :laugh:
    Most of it was rotten anyways so it wasn't too bad. Worst part was they dumped all the construction debris in that area. Hell, could have been debris from a home from the 1700's. Whole area was a giant field waaaaaaay back in the day.
  6. Oct 22, 2024 at 7:15 AM
    RxYoda
    RxYoda Well-Known Member
    Mark
    Florence, SC
    2023 Sport Premium 4x4 DCSB
    Maybe a little strange question…
    Has 5/8” Advantech been take off the market? Or is it just being diverted to disaster area repair? (In the past it works as a GREAT compromise of weight/support.)
  7. Oct 22, 2024 at 8:35 AM
    MGMDesertTaco
    It shows out of stock at HD and Lowes. It doesn't appear to be discontinued.
  8. Oct 22, 2024 at 9:58 AM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    I’m replacing all my copper plumbing with PEX A in stages. I’m starting at the 2-2nd floor bathrooms. I will replace the entirety of remaining copper in time.
    Has anyone done this? I’m no plumber but mechanically able. I’m just asking for tips…
    Clark27 likes this.
  9. Oct 22, 2024 at 10:49 AM
    Christmas
    Christmas Well-Known Member
    Pex is run differently than other water systems. You need to run a control manifold for each individual line. Meaning you don't just Tee off a branch line for each end of line. Kind of like wiring with no Daisy chaining. If you are running it under a house or exposed basement rodents could be a problem.
    MGMDesertTaco and SH7mi like this.
  10. Oct 22, 2024 at 11:05 AM
    SH7mi
    Kevin
    West Grove, Pa.
    Yes. I have the manifold. I’m just trying to conceive a plan for procedure, I’m not doing the entire house at this time. I just need to install the manifold with a bypass to allow for the remaining plumbing to stay active
  11. Oct 22, 2024 at 12:17 PM
    241240
    241240 Sir Lurks-A-Lot
    09 base double cab 4.0 MT
    Sat my fat rear end in it.
    My parents house (~20 yrs old) has the central manifold in the utility room with individual tube runs to each fixture from there. My house (~3 years old) uses tees and branches pretty much just like copper would.
    I’m also no plumber but have done some work with pex and found it pretty idiot proof. If you use the copper compression rings check them with the go/no-go gauge after you squish them. If you need to make joints in tight spaces the pinch ring version is probably easier. My pinch tool has an LED that lights up when it is appropriately pinched.
    I will also add a disclaimer that I don’t remember the difference between PEX A and B and whatever else they have now, so all of this might be completely irrelevant for you. I’ve never used the version that needs the tube expanded before it gets stuck over a fitting.
    wilcam47 and SH7mi[QUOTED] like this.
  12. Oct 22, 2024 at 1:07 PM
    Christmas
    SH7mi likes this.
  13. Oct 22, 2024 at 3:13 PM
    SH7mi
    Kevin
    West Grove, Pa.
    PEX A is the expansion version. I have the Milwaukee expanding tool, like you said it appears to be easy. Thanks for the reply
    Clark27 and wilcam47 like this.
  14. Oct 22, 2024 at 4:37 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Why?
    Drainbung and theesotericone like this.
  15. Oct 22, 2024 at 4:37 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Exactly. lol
    308savage[QUOTED] and Drainbung like this.
  16. Oct 22, 2024 at 5:28 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    PEX A doesn’t require the manifold. I’ve seen it used on new buildings but I’m redoing all my home water lines from copper to PEX A and using the traditional main branch and tee system. No reason you can’t do that. I have found PEX to be extremely easy to use and I’ve had no issues. I order a lot of my stuff from SupplyHouse because it was harder to find local but as time goes on I have more success finding parts local to me.
    TwistedTLM4 likes this.
  17. Oct 22, 2024 at 6:08 PM
    SH7mi
    Kevin
    West Grove, Pa.
    That’s where I ordered the manifold
    Clark27[QUOTED] likes this.
  18. Oct 22, 2024 at 8:16 PM
    Clark27
    Springfield, MA
    2015 Lexus GX460
    Yeah I read a bunch on the manifold system and the pro/con list of using one. I like the idea for sure. Just didn’t make sense for my remodel as I am slowly redoing everything when I get the chance. I’ve been very happy with SupplyHouse. Good prices and fast shipping. Happy to shop local when I can but it was hard when I made the switch a year or two ago
    SH7mi[QUOTED] likes this.
  19. Oct 23, 2024 at 5:10 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Hello everyone. I did the demo of the small deck, trying to knock out the last of the decking project while I have some time on my hands and the weather is nice.
    The deck ledger was hung overtop of the aluminum siding that black-ish looking lower course is what the siding looked like, many moons ago.
    I never paid attention to this bit of ugliness before I guess that this was someone's idea of a kicker board. The new ledger board will use up a bit of that real-estate, so I will pull that tomorrow and see how bad it is behind it. The rim joist seems fairly solid, no "soft" rot that I found when I attached the ledger for the big deck.
  20. Oct 23, 2024 at 5:17 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Wut
