Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 28, 2024 at 12:51 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Outstanding idea. I have plenty of smaller sticky sanding disks for my orbital sander. I could stick a couple in a line. There's definitely room to slide some cardboard or poster board under in the areas where there is clearance.
    Thank you!
  2. Nov 28, 2024 at 1:12 PM
    Tacoma Mike
    Southern Maine
    Perfect solution.
    He’ll just look like he isn’t wound to tight opening and closing the door 400 times..
  3. Nov 28, 2024 at 1:16 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Yes but think of the stress relief it will provide hahaha
    soundman98, RustyGreen, Sig45 and 2 others like this.
  4. Nov 28, 2024 at 1:28 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    It’s TW. Everything Rubs somewhere.
    RustyGreen, Sig45 and Tacoma Mike like this.
  5. Nov 28, 2024 at 2:24 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    what's the deck underneath the door threshold made of?
    Sig45[QUOTED] likes this.
  6. Nov 28, 2024 at 3:26 PM
    Sig45
    Mark
    Maine
    There is no threshold.
  7. Nov 28, 2024 at 3:45 PM
    4x4spiegel
    grind or plane the deck or a sanding disk mentioned earlier .
  8. Nov 28, 2024 at 3:47 PM
    Sig45
    Mark
    Maine
    The floor is stone. Sanding disk/rasp on bottom of the door is pretty much the only option. The doors open in.
    For clarification. There's a short brick walkway from the driveway to the main entry door in an alcove. The stone floor starts at that door. About 6ft in is another entry door (same as the other one). The stone continues for several feet before it transitions to hardwood flooring.
    soundman98 and Pointeman like this.
  9. Nov 28, 2024 at 4:17 PM
    Pointeman
    Mark
    I was thinking if the discs don’t work you could use a sanding belt cut into a long strip as well.
  10. Nov 28, 2024 at 4:28 PM
    MGMDesertTaco
    Almost 4" thick solid wood entry door! I wish they sold those at Home Depot.
    Sig45 and wilcam47 like this.
  11. Nov 28, 2024 at 4:41 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    If they did, we wouldn't be able to afford it.
    soundman98, Lawfarin and Sig45 like this.
  12. Nov 28, 2024 at 4:51 PM
    MGMDesertTaco
    Think of the size of the tree they had to harvest. :sawzall:
    edit: Probably cut down by hand too. :rofl:
    Sig45 and Kremtok[QUOTED] like this.
  13. Nov 28, 2024 at 4:59 PM
    Sig45
    Mark
    Maine
    Your idea had me thinking the same....like flossing! :D
    Pointeman[QUOTED] likes this.
  14. Nov 28, 2024 at 5:00 PM
    Sig45
    Mark
    Maine
    I'll see if I can get a pic. It's a very very wealthy/well known family and I'm reluctant to post things publicly. I'll run it by the onsite property manager.
    Many such families have vacation/2nd homes here in Maine, right on the ocean.
  15. Nov 28, 2024 at 5:02 PM
    Sig45
    Mark
    Maine
    You should see all the hand carved decorative trim features in this place. I just stand and look in awe. Floor to ceiling wood in many rooms.
  16. Nov 28, 2024 at 5:15 PM
    Sig45
    Mark
    Maine
    It's not a solid piece of wood. Does have rails & stiles. But still just under 4" thick.
    Can't imagine what something like that would cost now.
  17. Nov 28, 2024 at 5:30 PM
    Pointeman
    Mark
    I don’t blame you. When you get jobs like this you want to make sure that you maintain the trust of the people who are paying your wages
    Tacoma Mike, wmb67, Tiedie and 2 others like this.
  18. Nov 30, 2024 at 3:37 PM
    Tacoma Mike
    Southern Maine
    Sucks to be so fuckin rich..
  19. Nov 30, 2024 at 8:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Is there any room under the door through any of its swing arc or does it rub everywhere through the arc ? If there is room at some point I would consider something like using spray adhesive to put an aggressive sanding paper on a flat surface like plywood or 1/8" aluminum sheet , put it under the door and swing the door back and forth on the sanding media to remove material . It would be hard to get a decent cut across 4" of thickness with any kind of saw with the door hanging
    Pointeman and Sig45[QUOTED] like this.
  20. Nov 30, 2024 at 11:31 PM
    Sig45
    Mark
    Maine
    The door seems to be hitting/rubbing in a couple of spots and first rubs when open about 1/3 of the way.
    Per the advice/recommendation of @Pointeman, I grabbed some 18" belt sander belts in 80 & 120. Plan A is to cut the belts in half, open the door partially, slide a couple of the cut belts under the door and in the area it's rubbing the stone. Then I'm going to put one foot on each end of the cut belts to hold them in place, with the door between my legs I'll slowly swing the door and let the sandpaper do it's thing. (I'm pretty flexible so I'll have plenty of swing room). I'm hoping that'll be enough to remove enough material to stop the rubbing. I think only about an 1/8" needs to be removed.
    If I can create enough space under the door, I'll pull the sanding sheets back and forth while applying upward pressure.
