Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Dec 22, 2024 at 5:29 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Before you buy one ask your neighbors, friends, coworkers. Someone probably has one. Most people buy one and only use for one job. If you were closer I’d let you use mine. Been in the corner of my shed for about 15 years now.
  2. Dec 22, 2024 at 5:53 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Good point, I would rather not buy one.
    Toyko Joe likes this.
  3. Dec 22, 2024 at 6:49 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    If you get one make sure to have about 4 people on that thing because if you lock up on something it will break an arm......
    thomasburk[QUOTED] and Pablo8 like this.
  4. Dec 22, 2024 at 7:05 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    In the sand of Tampa you won’t unless you’re near trees. I’ve put in about 600 fence posts in Florida and have only had two spots that kick back because of tree roots.
    Just my experience.
    thomasburk and Pablo8 like this.
  5. Dec 22, 2024 at 7:15 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Nice -
    More than many many times than I can count haha I have hit boulders that need one or more of the follow:
    digging up
    Busting up underground
    Boring through
    Etc
    The delay is days to hours of frustration and soreness. Oddly I remember most of the rock! I liked the big flat ones, just punch through - but one punched and then sheared longitudinally, ended up busting in pieces.......
    The only win with immovable rocks is often I could anchor to the rock and a) really strong post and the b) next clown will be baffled if he tries to pull that post for whatever reason. :anonymous::rofl::thumbsup:
    Toyko Joe[QUOTED] and thomasburk like this.
  6. Dec 22, 2024 at 8:42 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    That's how I felt most of my yards posts.
    Pablo8[QUOTED] and thomasburk like this.
  7. Dec 22, 2024 at 2:47 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    just a note-- those hinges are cabinet hinges. they're generally only going to support about 3/4" of overlap between the door and the frame they're mounted to. in your pictures, your panels are far larger than that.
    i would also potentially look at adding a backer board to the doors for further reinforcement. could be as simple as a 1" furring strips installed within the opening, or as fancy as a solid panel that slots within the opening.
    you can also experiment with 'hatch hinges' in conjunction with the pneumatic shocks, depending on mounting location, they can provide similar clearance to the concealed hinge hardware, without the typical spring-loaded design most concealed hinges like linked above have--which can introduce extra stress on the panel while opening/closing.
  8. Dec 22, 2024 at 5:00 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Good info for me as I am going to be doing some spraying ... :thumbsup:
    Pointeman[QUOTED] likes this.
  9. Dec 22, 2024 at 7:02 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I'm not quoting everyone that responded about paint sprayers but thanks to all that responded. I am going to create a make shift paint booth in my garage that I can heat with a closed loop oil filled electric space heater since it's a winter in new england job. Also, since this is a one off project, I don't want to spend $500 on a sprayer I will only use for this one project. The X5 looks a bit more professional grade than I was thinking. Looking at one for $159 that should do the trick. If it's bad, I'll clean it up and return it.
    thomasburk and Tiedie like this.
  10. Dec 23, 2024 at 4:27 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I've been debating adding to and/or upgrading my pressure washer (1800psi electric Stihl). I really like it and it serves me well for light duty work (cleaning decks, vinyl siding, etc.). I've turned down some bigger, dirtier cleaning jobs as I know that unit would struggle.
    So I was at Lowe's poking around for something else and something caught my eye. They had a 3700psi Simpson Pro pressure washer (just the one) with Honda engine and the better Triplex serviceable pump. New in box. Regular price is $850. It's marked down to $339 on clearance. At that price I'd be a fool to say no.
  11. Dec 25, 2024 at 9:08 AM
    241240
    241240 Sir Lurks-A-Lot
    09 base double cab 4.0 MT
    Sat my fat rear end in it.
    This fall/winter’s project was turning some awkward space around and under the stairs into a playroom for the kids. We told them it would be a storage room while we did most of the work on it, then we added the facade and decorated it while they stayed at Grandma’s a couple nights ago.
  12. Dec 25, 2024 at 9:59 AM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    Tricking children is the best part of being a parent.
  13. Dec 29, 2024 at 7:35 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    General maintenance stuff today - flushed the water heater and got all kinds of tan water and particles out of it. I do that once per year, and it doubles as a good test of the sump pump since that never runs otherwise. Might be smarter to do it during the summer, though - the well water is super cold in the winter (shallow well) and I'm sure I use quite a bit of electricity getting the tank back up to temperature.
    On to a thorough pellet stove cleaning.
    MGMDesertTaco, wilcam47 and Pablo8 like this.
  14. Jan 1, 2025 at 8:16 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Just a quick PSA...
    3M delicate surface is indeed NOT delicate :facepalm:
    Also, don't be like me. Didn't feel like cutting the bottoms each time for a coat of primer and 3 coats of paint, so I put down the same 3M tape. It was at that point I missed a crucial step in taking an ever so thin bead of clear caulking to seal the tape to the floor/baseboard so it wouldn't bleed. :bananadead:
    This has been brought to you by your village idiot :anonymous:
  15. Jan 1, 2025 at 9:45 AM
    soundman98
    NW Indiana
    still far better than most.
    that's what they make markers for!
    https://www.amazon.com/Lifreer-Revolutionary-Furniture-Markers-Scratch/dp/B0BP2R6MCG
    my preference is to just pull the doors. far easier and less masking.
    the floor/trim is not a huge deal. i've seen many houses are far worse with pro painters...
    Sig45, RustyGreen, wilcam47 and 3 others like this.
  16. Jan 1, 2025 at 9:47 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I'm just gonna sand down and re-shellac the door. I should have known the old finish was frail.
    The base is getting quarter round due to floor damage from someone in the 70's removing the old trim, so it'll hide most of it.
  17. Jan 1, 2025 at 10:04 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    That got me thinking and I stumbled on this. Definitely curious how it looks. Could be nice in a utility room perhaps.
    thomasburk and RustyGreen like this.
  18. Jan 1, 2025 at 10:11 AM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    pretty cheap too :anonymous: cool though be nice in the right setting
  19. Jan 1, 2025 at 12:32 PM
    soundman98
    NW Indiana
    i've done a ton of undercabinet led tape light.
    notice that one cuts/installs the trim first, and then installs the led tape light.
    under a cabinet, with a near perfectly smooth finish, and enough access for my body to get under there, it's difficult. i can't imagine the creative contortionists nightmare that would be needed to install that tape light on the ground, with limited finger access to get the adhesive to stick. and then to get it around corners, the tape doesn't bed easily, or stay easily, which adds even more complexity.
    also, check aliexpress and ebay. i'm pretty sure all of that stuff is available for less without the middle man of etsy...
    i've come across it in the past on aliexpress. i'd like to use it as a night light in my main hallway. the main issue is getting the trim to transition back to standard trim that it meets up to.
    daveeasa[QUOTED] and wilcam47 like this.
  20. Jan 1, 2025 at 1:13 PM
    Sig45
    Mark
    Maine
    I don't tape anything anymore. Cut in and keep a putty knife with dry rag wrapped around the blade nearby to quickly and cleanly wipe off any "oops".
