Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jan 16, 2025 at 9:20 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    When i did my garage, the electricians wanted the same thing...lay the conduit and then fill and then they will pull through it. It was around 150ft too. Mine did have ~30 ft that had to be backfilled as it was passing by a pipeline pipe that the owners had to be present to work around. I did run a good pull line through for them at least which they were appreciative of even though the just used it to do their own pull line.
    But, I will say, it only took them ~15 minutes to get the line run with just two guys. Laid out the line, hooked it up, and just pushed/pulled it and wasnt bad at all.
    Granted, I was doing the trenching/backfilling and also purchased all the conduit and laid it out but the conduit portion shouldnt have mattered
    Drainbung and SH7mi[QUOTED] like this.
  2. Jan 16, 2025 at 9:23 AM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    At least you ran a fish line that they could use for their own. This guy didn’t even do that. Plus, he’ll be installing the cable in 20* temps…. Have fun with that!
    soundman98 and Drainbung like this.
  3. Jan 16, 2025 at 9:34 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    It’s much easier to pull through a fixed conduit than one that’s moving.
  4. Jan 16, 2025 at 9:37 AM
    SH7mi
    Kevin
    West Grove, Pa.
    Agreed but if I have the cable and the conduit, I’m running both simultaneously
    Drainbung likes this.
  5. Jan 16, 2025 at 9:50 AM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Because electricians are prima donnas. Also the reason you got to do the trench. Sorry sparkies but you know it's true. lol
    Malvolio, Drainbung and SH7mi[QUOTED] like this.
  6. Jan 16, 2025 at 9:51 AM
    SH7mi
    Kevin
    West Grove, Pa.
    No argument from me. Every time I have to tap into my house electric I want to strangle the electrician…
  7. Jan 16, 2025 at 10:00 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Pushing a tape through the conduit isnt hard. And yes pulling multiconductors will be easier after the conduit isnt moving around
  8. Jan 16, 2025 at 12:42 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    At least you dug a ditch and laid in some conduit. I found some Romex about 4" under the dirt that goes from my foundation then towards the shed.
    soundman98 and theesotericone like this.
  9. Jan 16, 2025 at 12:53 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    If it is gray in color, it is outdoor Romex - OK to not be in conduit.
    4" however, is too shallow.
  10. Jan 16, 2025 at 1:22 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    HD once had outdoor romex cheaper than indoor, didnt understand why. :notsure:
    soundman98 likes this.
  11. Jan 16, 2025 at 1:26 PM
    2ndhandTacoman
    Walter
    Maryland
    Oh no, the PO couldn't be bothered with doing a single F-N thing remotely close to being "good enough". It looks like 14/3 white Romex.
  12. Jan 16, 2025 at 1:32 PM
    Scott B.
    Scott
    Georgia
    :eek:
    wilcam47 likes this.
  13. Jan 16, 2025 at 4:35 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Lol it was around there when they were here. Was even more annoying cause we had some snow on unfrozen ground and they didnt come till after lunch or so. Sun melted the snow and made it a bit of a muddy mess. They never complained though
    Ive found so much buried wire around our property its not even funny. Luckily its all old and "dead". They used to have lights and stuff all over I guess and just buried the wire 6-12" down. It was irrigated too at some point so there is tons of old poly water lines too. Makes digging fun
  14. Jan 16, 2025 at 5:20 PM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    Because everyone hates working with UF-B, so you only buy it if you really need it. Supply & demand. I used it once because Lowes was out of 14/2 Romex and I needed to finish the project that weekend, so UF-B it was. Rest of the coil is still sitting in my supply drawer, several projects later.
  15. Jan 16, 2025 at 5:23 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I didnt think it was any more work than regular romex.
  16. Jan 16, 2025 at 5:25 PM
    SpencerTacoSC
    Daniel
    2004 Tacoma 4x4 V6
    Really? I always hate stripping the outer insulation since it's cast solid around the conductors, and you can't just run a knife down it like you can the outer sheath of Romex. I mean, it's manageable but definitely a bit trickier.
    soundman98 and Scott B. like this.
  17. Jan 16, 2025 at 6:08 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Its been a while since i used it but certainly not enough to make me think it was a pain. Granted i work with industrial multiconductor fairly often that has multiple layers/shielding
  18. Jan 16, 2025 at 7:24 PM
    Christmas
    Christmas Well-Known Member
    Been awhile since I posted any progress on the new shop last summer. If I get everything sorted and moved in by summer, I'll be amazed. 50yrs of accumulation.
  19. Jan 19, 2025 at 3:48 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    in low temps, with multiple conductors, i always pulled a fish tape through as i connected the underground conduit together. made fishing in the wire at the end a breeze.
    also had far too many backfill operations that either moved or damaged the conduit enough to make pulling wire later a mistake.. at least get the wire in and powered up, then they'll know when they hit something!
    of course, my truck always had 3 shovels on it at all times. i wasn't afraid to dig, but most customers didn't like the bill after i did!
  20. Jan 22, 2025 at 10:49 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Is it possible to hire someone just to review electrical work and point out any code violations? Home inspector? Or actual electrician? Kinda curious to maybe do that so I can learn a bit more and proactively address things.
    Malvolio likes this.
