Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 10, 2025 at 9:49 AM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    Crimps actually are a more secure connection rather than less
    308savage[QUOTED] likes this.
  2. Feb 10, 2025 at 11:53 AM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Along with 47 wraps of electrical tape!
    Jeff Dartfrog likes this.
  3. Feb 10, 2025 at 2:05 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Good grief... I just can't fathom how anyone does hack work at that level and feels good about it.
  4. Feb 10, 2025 at 5:59 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I see you must have been the last guy to do electrical in my house... :annoyed:
    soundman98 and 308savage[QUOTED] like this.
  5. Feb 10, 2025 at 6:05 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Owner didn't even make it up the driveway before he said how embarrassed he was. You could tell he was gonna go back to the office and totally blow up on the crew that did my install.
    Other than every downspout being the wrong height, every strap was hand cut by a toddler, some of the downspouts weren't even screwed into the gutters.
    I told them to hold off on the re-install until I could get some trim boards replaced today. Found some guys on Nextdoor, cheap, showed up on time, hammered the work out in a day. Front porch was all mostly replaced, all the rotted wood replaced with PVC. Lots of trim on every corner of the house, and I stripped off some old unused utility boxes around the house. Getting ready to paint the house and don't want a bunch of old shit hanging on for dear life after paint.
    jwctaco, Sig45, wilcam47 and 5 others like this.
  6. Feb 10, 2025 at 6:50 PM
    308savage
    Adam
    East Tennessee
    Gotta insulate those connections!
  7. Feb 11, 2025 at 3:20 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So, I just finished another room painting the wooden trim white and am happy to report the caulk and painters tape trick on the floor worked great! I didn't quite smooth it out thin enough and got just a small lip of caulk, but no paint on the floor!
    The paint looks like it doesn't match on my (horrible) cut in, but it was just wet.
  8. Feb 11, 2025 at 4:26 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Will be opening up the septic tank today . Oh joy . Having some drain problems. Used 2 gallons of main line liquid cleaner already . Sometimes things drain fine other times not . I think it’s possible my D-box might be bad . I have a small low spot ( small ) in the yard . Pretty sure it’s the D box . I just found out if you have a water softener the salt obviously corrodes concrete . If that’s the problem I will have to get a plastic D box . We shall see if the tank has too much liquid in it. :annoyed:
  9. Feb 11, 2025 at 4:31 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Once you open it up, you'll quickly see if it's a baffle clog or a failed drain field/clogged distro box. Although solids should not be getting into the field so if the distro box isn't crumbled the outlet baffle could have fallen off as well.
    My system is an old single compartment tank that almost 60 years old. The only thing saving me right now is the terracotta drain field is probably cracked and still draining through them. :anonymous:
    Yes, I'm budgeting about $30K for replacement here in the next 5 years. Gotta go with a sand mound system :annoyed:
  10. Feb 11, 2025 at 4:54 AM
    Charlie Too
    Charlie Too Well-Known Member
    Western PA
    2021 Army Green Tacoma TRD Off Road
    Man, that's a bummer. We have been good all these years but I fear the day this may come. Good luck.
  11. Feb 11, 2025 at 5:01 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Looks really nice :thumbsup:
    Drainbung and Delta09[QUOTED] like this.
  12. Feb 11, 2025 at 5:02 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The ever so tightening rules from the PA DEP makes things ungodly expensive. My township has a 3 year pumping rule, which isn't that bad. I've been doing it every 1.5 years.
    The system replacement cost is high though. I guess the soil doesn't drain good in my area so every house here has to do sand mound. Back in '65 when my house was built they just chucked a tank in the ground, put 100' of field line in, and called it good :laugh:
  13. Feb 11, 2025 at 5:04 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Sorry man, bummer. Mine was installed in 72’ , get it pumped every other year, my guy says it looks good :fingerscrossed:
  14. Feb 11, 2025 at 5:05 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    I’m fortunate, it’s all sand around me
  15. Feb 11, 2025 at 5:14 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    My wife just retired from the county health department, 40 years , the folks that give the permit for well and septic . She has some great/ disgusting stories. An example, guys all pissed off he has arsenic levels off the chart and can’t get a well permit, he wants to open a bed and breakfast. Doesn’t want to have safe water hauled in . It’s old agriculture land.
  16. Feb 11, 2025 at 5:39 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    I used to work for a big/quality builder and development company. Very thorough process, we built a house on this guy’s property. Go over the entire process with them, start to finish. Get a call from the owner about two years later, all pissed. It seems they forgot to mention that they wanted a pool in their backyard. We typically put the well in front and septic in back, based on grade and soil conditions. I go meet the homeowner and Jerry our septic contractor. Homeowner is all upset that it’s going to cost over 30k to relocate the system. Jerry looks at the homeowner and says, you wanna shit or swim :rofl:I’ll never forget that line :rofl:
  17. Feb 11, 2025 at 9:20 AM
    lynyrd3
    Bill
    Myself and an excavation friend put those big plastic teepees in around 20 years ago ,new leach field . I’m all gravel here . . Not sure how many feet but around 100’
  18. Feb 11, 2025 at 9:22 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Home ownership can be a great thing, but damn can it be an expensive bitch sometimes :rofl:
    :pout:
  19. Feb 11, 2025 at 12:37 PM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    We put in a new well,130’ and a new HVAC system in the last 3 years, love it
  20. Feb 11, 2025 at 12:55 PM
    MGMDesertTaco
    Save those receipts in case you ever sell. Improvements are tax deductible and I think repairs are deductible for rentals.
    jwctaco, Drainbung and wilcam47 like this.
