Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 1, 2025 at 11:18 AM
    ralfnjan
    ralfnjan Well-Known Member
    Geeez, that guy sounds like me :muscleflexing:
  2. Mar 1, 2025 at 11:24 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    We all could probably hear about more stories like this. Thanks for sharing!
  3. Mar 2, 2025 at 3:45 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Short/long story, our garage door spring broke during the hurricane last September. The wife didn't know what had happened so she tried the button again. And that damaged the top panel, replaced spring. The door damage was Jerry rigged up for a quick fix but bad enough to warrant a new panel.
    Called Clopay gave them the s/n of the door and they gave me the part numbers and prices. Not great in my mind. Off to HD which is the only place to get replacement panels. Ordered the panel without glass and a new strut because the other one was damaged.
    Install went without a hitch, until the door opener. According to the install manuals door and opener. It needed extra bracing. That was not done when it was installed by the door installer from the beginning. Out to the work shop for some angle iron to make a brace. That's where I needed a longer clevis pin, low a behold I had one. I'm keeping the old strut to put on the 3rd. panel for extra bracing and stability, just need to get some more screws and a little time.
    IMG_20250302_063210693.jpg IMG_20250302_063346239_MP.jpg IMG_20250302_063218223.jpg
    In hindsight I'm glade I got a new panel because as time passed I could see the door panel was going to give way and fail. And it's quieter than ever.
  4. Mar 2, 2025 at 4:49 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Well my year just got more expensive :annoyed:
    Went down to the basement last night to grab a beer and noticed water on the floor in the room with the well expansion tank and water softener. Hmm, not good. Found the brine tank on the softener was overflowing out the overflow tube. Crap. Well, maybe it did a regen and the drain messed up again. I mean, the tubing for the drain is kinda janky. Scooped out about 12 gallons of water and ordered some more sturdy plastic tubing to redo the drain line next weekend. Just went down to do some laundry and decided to check on the brine tank. Shit...
    Water level increased about 10"-12" in 14 hours. Welp, it's done. Control valve/head must have sprung an internal leak. Once my laundry is finished I'll put it in bypass. Yes, I know the salt level is kind of low. System is 24 years old and I knew this day would come so I haven't been keeping that much in there. No sense in sourcing a head as the media is probably shot by now as well.
    Kinda hard to see, but you can see the wet bottom plate from the water I had to clean up.
    :spending:
  5. Mar 2, 2025 at 6:01 AM
    Sig45
    Mark
    Maine
    :mad:
    Delta09[QUOTED] likes this.
  6. Mar 2, 2025 at 6:02 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Its been on borrowed time since moving in, so it's no real surprise. Just hurt the wallet since I've been re-doing my garage at the same time.
    wilcam47 and Sig45[QUOTED] like this.
  7. Mar 2, 2025 at 6:03 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Well that sucks
    wilcam47 and Delta09[QUOTED] like this.
  8. Mar 2, 2025 at 6:09 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Bought our house 30 years ago in August. First Christmas Eve, water heater tanks, two days later back on line, I’m not a plumber. Second Christmas Eve, furnace takes a crap, three days later, we got heat , I’m not a HVAC tech. Called in some favors.
  9. Mar 2, 2025 at 6:12 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Luckily I'm a jack of all trades, plumber, electrician, boiler man, carpenter, etc. so it isn't too bad, just an unexpected bump in the road. :annoyed:
  10. Mar 2, 2025 at 6:16 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
  11. Mar 2, 2025 at 6:23 AM
    Sig45
    Mark
    Maine
    Oh Jim, gotta clean up the top of that outside corner miter. One side appears to be about 1/16" off.
    :D
  12. Mar 2, 2025 at 6:25 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Better than my work; I just wood fill, caulk, and paint everything before taking pictures to make it look like I know what I'm doing :anonymous:
  13. Mar 2, 2025 at 6:26 AM
    Sig45
    Mark
    Maine
  14. Mar 2, 2025 at 6:28 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    At least I admit it! :rofl:
  15. Mar 2, 2025 at 7:05 AM
    Sig45
    Mark
    Maine
    Joking aside. Looks great! I like the use of the metal panels.
  16. Mar 2, 2025 at 7:29 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    You should have seen it before, full blown 72’ decor. So do I put the mirror back in level, or follow the counter top :annoyed:
  17. Mar 2, 2025 at 7:30 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Countertop id think
    jwctaco[QUOTED] likes this.
  18. Mar 2, 2025 at 7:35 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    It looks off when you stand back, wife thinks it’s fine, drives me nuts. Not bragging but I can see when stuff is not square- level, plumb, OCD carpenter :cool:
  19. Mar 2, 2025 at 8:19 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Countertop.
    I always run parallel to the nearby surfaces. Otherwise your eye gets drawn to the difference.
  20. Mar 2, 2025 at 8:19 AM
    soundman98
    NW Indiana
    Really need to get one of those cheap water alarms.
    jwctaco and Delta09[QUOTED] like this.
