Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 8, 2025 at 9:15 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My hot water tank failed this week, wasn't even 5 years old. Bought a basic one as a replacement with no electronics in hopes that it lasts longer.
    Drainbung likes this.
  2. Mar 8, 2025 at 2:54 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    :mad:
    :sorry:
    Water heaters are always a luck of the manufacturing day thing. The tanks are all glass lined the same way, either you get a good one that lasts or a bad one that doesn't.
    The quality of your water impacts life too.
    When I replaced mine (30 gallon electric) I removed the chinzy plastic drain valve and replaced it with a copper pipe nipple and a full port ball valve - that flows some water when you flush it. :rocket:
  3. Mar 8, 2025 at 5:22 PM
    shakerhood
    Southern Ohio
    About 6 months ago it started randomly making super crazy hot water so l knew it's time was limited. This week it had tripped the breaker and when flipped back the screen was beeping, flashing, and non-operational. Should have replaced that plastic drain valve on the new one like you did.
    Delta09 and Drainbung like this.
  4. Mar 8, 2025 at 5:24 PM
    MGMDesertTaco
    What brand/model was the one that failed?
    shakerhood and Drainbung like this.
  5. Mar 8, 2025 at 9:02 PM
    shakerhood
    Southern Ohio
    (A.O. Smith 50 gallon), I believe it may have been an electronic thermostat issue but went down that rabbit hole when it started cooking the water and that part was discontinued. Was able to extract a fault code on it on the last day before giving up with it as it kept saying tank empty dry fire.
    MGMDesertTaco[QUOTED] likes this.
  6. Mar 8, 2025 at 9:13 PM
    MGMDesertTaco
    Interesting, Lowes used to carry Rinnai. That's where I bought the gas tankless for my last house. Now all they sell is A.O. Smith. I'd like to get another gas tankless Rinnai or Navien for the next house.
    Tiedie and shakerhood[QUOTED] like this.
  7. Mar 8, 2025 at 9:17 PM
    shakerhood
    Southern Ohio
    Tankless actually sounds like a pretty cool option, would have to be more efficient.
  8. Mar 8, 2025 at 9:20 PM
    MGMDesertTaco
    Tankless HW systems are great if you have natural gas or propane. Low maintenance, no risk of flooding. Just gotta keep them flushed with distilled vinegar on an annual or semi annual basis.
    soundman98, shakerhood and Tiedie like this.
  9. Mar 9, 2025 at 7:05 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Screens... :puke:
    :rant::rant:
    We have had water heaters without screens for about 100 years, why do manufacturers think that adding a screen to a simple mechanical device is an improvement... :mad:
    ...stepping off soapbox now...
  10. Mar 9, 2025 at 12:17 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Everything is insulated and lathed out. Before you go "WTF" on the lathing, I had a moment of stupid and/or change how I wanted to do the drywall. I'm not the greatest at finishing drywall so I'm going to hang it vertically to eliminate any butt joints. Not exactly how the pros do it, but it will be the easiest for me.
  11. Mar 9, 2025 at 12:34 PM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    :thumbsup:
  12. Mar 9, 2025 at 4:56 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Looking sharp!
    You can put 5/8 OSB or plywood up then you have something to screw shelves, etc to wherever you want.
  13. Mar 9, 2025 at 5:06 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    That would be nice, but seriously break the budget :laugh:
    All in this should be around a $700 project trimmed and painted.
    I've got all the measurements written down for my planned shelving, so shouldn't be too hateful to put everything back together.
  14. Mar 10, 2025 at 2:36 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    So about 3/4 of the way done hanging the drywall. I'm definitely not good at this, but somehow I only fudged up one outlet. Not bad considering a couple sheets had a door/window and two outlets o_O
    In case anybody was wondering. 500+ lbs on the tailgate on a 4th gen is sketchy AF :rofl:
  15. Mar 10, 2025 at 2:53 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    nah not bad on the gate, but throwing some 2x4's or 4x8 plywood can help them too. only say that watched a guy drop a curb and watched like 4 sheets of Gypsum snap and hit the ground with the paper backer holding what was left together
  16. Mar 10, 2025 at 4:35 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Agreed. As much as the crap costs its worth supporting
    soundman98 and Delta09 like this.
  17. Mar 10, 2025 at 4:37 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    You ain't kidding. 12 sheets 1/2", bag of 90 minute mud, USG Plus 3, some tape, and screws was $300 o_O
    RustyGreen and Drainbung like this.
  18. Mar 10, 2025 at 4:39 PM
    MGMDesertTaco
    Did you use a drywall screw gun or just stick em and sink em?
  19. Mar 10, 2025 at 4:40 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Just carefully used my Milwaukee impact with a regular #2 bit. There was several times I sunk it too deep and had to put another screw beside it. Whoops :anonymous:
  20. Mar 10, 2025 at 4:45 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    I find number 2 on the clutch setting to be just about perfect for that very reason
    Drainbung and Delta09[QUOTED] like this.
