Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. May 18, 2025 at 4:52 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Still a work in progress, but I replaced my load center. Kept it the service a 150 amp just got a little bigger panel. The old Challanger panels are known for issues so wanted to be proactive getting it out. Also bought a transfer switch to add a generator hook up, digital timer for the pool, whole house surge protector, and an energy monitor. Electricity bill almost doubled when they switched me to a smart meter, so now I can track my usage myself to double check their numbers.
    Also redid some of the pool wiring. Changed the motor to 240v vs 120 and replaced the boxes outside. Still gotta wire in the transfer switch and a random circuit or two. Wanted to take a pic before it gets too messy in there lol.
  2. May 18, 2025 at 5:47 AM
    soggyBottom
    soggyBottom Well-Known Member
    I don't have any pictures, but I have a friend who has the most over engineered grounding on his house.
    He took 2" gas pipe, filled it with epsom salt, buried it in the ground with irrigation on the pipe. He is into ham radio, and when he turns on the water, the noise floor in the radio visibly drops.
    thomasburk, Drainbung, jubei and 2 others like this.
  3. May 18, 2025 at 5:59 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Hoping to get this done this summer. Had the water softener changed last year. Now I need to replace that water tank and all the fittings. Hopefully my neighbor will have time soon (he’s a plumber) he’s been booked solid for a while now. It doesn’t leak, all the water is from when the softener being replaced.
  4. May 18, 2025 at 6:03 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Whoa, how old is that thing? Looks like you definitely got your moneys worth!
    Drainbung likes this.
  5. May 18, 2025 at 6:18 AM
    williams63
    chili
    nh
    2011 dblcb
    Was here when I bought the house 24 years ago.
  6. May 18, 2025 at 6:23 AM
    williams63
    chili
    nh
    2011 dblcb
    Had the water softener replaced last fall and the furnace the summer before that. Tank is next.
    Drainbung and Delta09 like this.
  7. May 18, 2025 at 6:28 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Just an FYI for anybody who gets one of these or similar. After running the regen cycle on initial startup, flush the system way more than I did. Control unit said I used about 4 gallons which obviously wasn't enough. Water in the toilet looked discolored this morning and thinking it was just dirty (the hard water made it nasty quick) but decided to peek inside the tank. Hey look some resin beads! I think the first thing I did after the regen cycle and inadequate garden hose flush was use the restroom. Whoops. Aerator screens weren't bad in the faucets so it looks like the toilet took the brunt of it.
    Other news I notice the well pump does not cycle near as much with the proper pressure in the bladder. How long that will last, who knows.
    soundman98, Drainbung, Sig45 and 2 others like this.
  8. May 18, 2025 at 10:16 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    And it says maintain. But thats different right?
    Ill admit i was wrong on the cost for commifornia. That baffles me.
  9. May 18, 2025 at 11:17 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  10. May 18, 2025 at 4:30 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    It's all good man. I don't care enough to research each states laws regarding fences. lol
    As far as Cali goes? I don't agree with a lot of the shit that goes on in this state. I'm only here because of this.
  11. May 18, 2025 at 5:07 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Haha, that's one idea
  12. May 19, 2025 at 3:36 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    So...one of my shed doors is off.
    Opening is square. Got a fix for me?
    If it wasn't dragging on the ramp and sticking I wouldn't care but Mrs. SpruceMica does so...
  13. May 19, 2025 at 6:02 AM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Looks like 1/2” T111 sitting in a 5/4 x3” piece of trim with a routered groove? If yes this is where mine failed as well. The gaps on 3 sides look consistent so my guess is that the vertical piece has shifted down due to the weight of the door. My door didn’t have a backer board though it did have a center brace…so I cut a piece of 1/8” door skin to fit, put a flat shovel under the sagging corner and had my son press down on it until it raise the end level with the other door and the used glue and a pneumatic stapler to attach the skin to the back of the door. Stapling around the door and across the center frame brace. Then painted the inside of the door.
  14. May 19, 2025 at 6:39 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    After stapling and before removing your shovel, insert a sturdy shim to lift the door 1/4" above 'level', so when dry the door will come to rest to desired height. With weight of door, time, and usage, one might suspect a little more settling. :thumbsup:
  15. May 19, 2025 at 4:21 PM
    Pointeman
    Mark
    Hahaha thanks for mentioning this…and yes the use of a shim is probably (most definitely) a more appropriate device for this application. :anonymous:
    I will say that my backyard ingenuity was probably fueled by my frustration of not being able to open the door!!!
    Drainbung and soundman98 like this.
  16. May 22, 2025 at 6:42 PM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    Replace that valve with all stainless steel
    virginiamarine and soundman98 like this.
  17. May 25, 2025 at 3:08 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    The fake hinges and handles on my garage doors are rusting a bit so it was time to fix that.
    Before:
    After:
  18. May 26, 2025 at 12:42 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    The deer really destroyed my bushes this past winter. Last year I covered them up, this year I thought they thinned out from being covered up so I left them uncovered. Didn’t know the deer loved them.
    So finally had enough and chopped them down a couple of weeks ago. Started digging up the roots and then the Nor Easter came rolling in. Had a break in the weather yesterday so got everything dug out and started planting. Finished 30 min today before I needed to head to work. Have one small boxwood by the other side of the garage I need to put weed barrier around and mulch. I’ll finish that tomorrow.
    Got some shrubs that the deer shouldn’t eat, and all low maintenance free stuff. Since neither me or my wife have much of a green thumb.
  19. May 29, 2025 at 1:43 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Well my small part on this job was to simply demo the bathroom in this 1840's home as part of a remodel. Last known bathroom remodel was back in 2002. My job was to remove the tile and the fake mdf beadboard and trim....fairly easy. I was then asked to rip up the subfloor and install new along with a partition wall for the end of the new tub/shower. Ok. The plumber had hacked a hole to run supply and drain for the new shower and he didn't remove the toilet flange (which is being repalced). Nothing is in normal rough in state. I'm just shoring up the floor where needed and covering everything with new 3/4 subfloor. I'll have to have a joint at the toilet flange. Original subfloor are 1" thick boards. Two walls still have the original horse hair plaster/lathe. One day turned into 2-3.
    Anyone know what this semi cylindrical thing is in the wall? I've not seen anything like this. Appears to be galvanized.
  20. May 29, 2025 at 3:18 PM
    Matt Sierra
    Matt Sierra Well-Known Member
    NorCal
    2020 TRD Pro MT
    Maggy SC, C4 Overland front bumper
    Not sure what the edges look like in your example, but I’ve seen a similar plate used to mount a toilet paper holder. The holder screws into the two holes in the middle of the galvanized plate
