Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 5, 2015 at 5:56 PM
    #4101
    Ride98red
    Ride98red You people are so petty...and tiny
    Aaron
    NOVA
    Gatekeeper tailgate "lock", WeatherTech floor liners - Front and Rear, Factor 55 Hitch Link w/Van Beest 3/4" D-ring Shackle, ARB 30' Snatch Strap, Trailer Hitch Socket Relocate, Skygear Waterproof Fuse/Relay Box, LED Bed Lights, QuickFists with custom mount
    actually, check out his pic above of when he put the drywall back in. I'd say he did one hell of a job with the drywall. Lord knows I've mudded way worse than that and it came out flawless.
  2. Mar 5, 2015 at 6:00 PM
    #4102
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I use PL Premium sub floor adhesive and ring shank gun nails for subfloor plywood
  3. Mar 5, 2015 at 6:00 PM
    #4103
    Ride98red
    Aaron
    NOVA
    nah, gotta have a nailer dude! back in the day when I did flooring I think I used a bostich or hitachi coil nailer for subfloor but I freakin HATED my gun. freaking thing was always leaving heads up (and not to the fault of the compressor). screwing is just too slow.
  4. Mar 5, 2015 at 6:02 PM
    #4104
    Ride98red
    Aaron
    NOVA
    + 1 to that. what nailer do you use?
  5. Mar 5, 2015 at 6:03 PM
    #4105
    OZ-T
    Peter North
    British Columbia
    These aren't " too slow "
    http://www.strongtie.com/products/quikdrive/systems/
  6. Mar 5, 2015 at 6:03 PM
    #4106
    PkTaco
    PkTaco Well-Known Member
    David
    Zanesville Ohio
    To each there own. Screws vs nails the debate can go on for ever. The most important part is the sub floor adhesive.
  7. Mar 5, 2015 at 6:03 PM
    #4107
    OZ-T
    Peter North
    British Columbia
    I run Senco FramePro 600/601
  8. Mar 5, 2015 at 6:05 PM
    #4108
    PkTaco
    David
    Zanesville Ohio
    Those are sweet Oz.
  9. Mar 5, 2015 at 6:06 PM
    #4109
    OZ-T
    Peter North
    British Columbia
    Common screws have no shear value and that can be an issue with some seismic designs here that utilize the floor diaphragm as part of the lateral restraint
  10. Mar 5, 2015 at 6:12 PM
    #4110
    Ride98red
    Aaron
    NOVA
    haha I knew someone would bring it up! but I want tensile strength. necessary on subfloor? probably not. but I want a strong floor all around, which is why I want to nail it vice screw it.
    so back to my question...what gun you use? c'mon, give it up man!
  11. Mar 5, 2015 at 6:13 PM
    #4111
    Ride98red
    Aaron
    NOVA
    disregard Oz. I see it now in above post. thanks!
  12. Mar 5, 2015 at 6:14 PM
    #4112
    T4RFTMFW
    T4RFTMFW Well-Known Member
  13. Mar 5, 2015 at 6:14 PM
    #4113
    PkTaco
    David
    Zanesville Ohio
    I get what you are saying.
    Aaron do you have any pneumatic tools/compressor yet?
  14. Mar 5, 2015 at 6:22 PM
    #4114
    Ride98red
    Aaron
    NOVA
    Yeah, I have a crapola craftsman compressor that needs replaced. Wont use that to do the subfloor. it lacks the cojones to keep up. I have a POS coil nailer that I wont even attempt to use for the subfloor. I have a couple finish nailers and then my favorite at the moment - my paslode finish nailer. love that thing!
    now I just need something for sub floor/framing and ill be happy.
  15. Mar 5, 2015 at 6:24 PM
    #4115
    PkTaco
    David
    Zanesville Ohio
    You are going to need a flooring nailer to do the hardwood too.
  16. Mar 5, 2015 at 6:25 PM
    #4116
    OZ-T
    Peter North
    British Columbia
    Simpson stong tie are shear rated seismic screw systems
    and I already said I run Senco FramePro 600's and 601's
  17. Mar 5, 2015 at 6:31 PM
    #4117
    Ride98red
    Aaron
    NOVA
    glue down hardwood. that might change though. depends on how the transition from wood to tile works out between the two rooms.
    if I do 3/4 hardwood I'd just rent the nailer. no need for me to buy one for one room in the house.
  18. Mar 5, 2015 at 6:36 PM
    #4118
    Ride98red
    Aaron
    NOVA
    ah, good to know. thanks
  19. Mar 5, 2015 at 6:54 PM
    #4119
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Am I reading this correctly? You want to build your floors up a 3/4" then put hardwood floors on top? You still may end up with squeaks because the original floor wasn't glued or nailed down properly. Seems like an awful lot work for possibly same squeaky floor.
  20. Mar 5, 2015 at 7:38 PM
    #4120
    cynicalrider
    cynicalrider #NFG
    Jersey
    Did something similar to the upstairs bedroom, super clean and a much easier project. The fireplace and cable box/PS3 in the closet across the room 50 ft away is the reason it was not complex.
