Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 20, 2015 at 5:15 PM
    #4341
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    OZ - How do you secure the decking? I'm building a deck (redwood) and screwing the decking on the outside edge and laying down the next board. Just looking for expert knowledge.
  2. Mar 20, 2015 at 5:23 PM
    #4342
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This was face screwed with 3" trim head stainless screws
  3. Mar 20, 2015 at 6:30 PM
    #4343
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Did you make that mesh for the privacy fence? Looks like you cut it into 1x for strips....I might steal that look...waay better than lattice.
  4. Mar 20, 2015 at 8:26 PM
    #4344
    OZ-T
    Peter North
    British Columbia
    Yeah , I had a bunch of leftover rippings of clear cedar from when we milled up a bunch of exterior trims so I did cut the strips , they are 1" x 5/8" , the spacing is 3" square in between . Each connection is back stapled on the side facing away from the hot tub with 1 1/8" galvanized 1/4" crown staples
  5. Mar 21, 2015 at 9:47 AM
    #4345
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Nice work Oz. I like the historic squares and not on the diagonal. Do you know what species of vine will be planted? In two years the look with growth will be phenomenal.
  6. Mar 21, 2015 at 9:56 AM
    #4346
    OZ-T
    Peter North
    British Columbia
    I think it's going to be some type of Clematis or similar
  7. Mar 21, 2015 at 10:07 AM
    #4347
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    So many nice options with Clematis. Wide variety of colors and different blooming seasons. Some are very fragrant as well. Toss in a few Jasmine vines and he could create a back yard with an oasis of smells.
  8. Mar 21, 2015 at 11:36 AM
    #4348
    Tj0hn
    Tj0hn Well-Known Member
    Arkansas
    Stock TRD Sport 4x4
    Ground heave? I'm not familiar. Please explain
    The house is built on a concrete slab.
  9. Mar 21, 2015 at 11:42 AM
    #4349
    OZ-T
    Peter North
    British Columbia
    If you're on a slab it's unlikely to be frost / ground heave , that usually occurs in post and pier type foundations that allow for independent settling and movement
    http://en.m.wikipedia.org/wiki/Frost_heaving
  10. Mar 22, 2015 at 3:13 AM
    #4350
    PkTaco
    PkTaco Well-Known Member
    David
    Zanesville Ohio
    Oh yeah. It will be rock solid. You can by several different drying times. 20, 45 and 90 minute. The big thing when using it is to know your limits with what you can mud in that time span. I always get the 45 minute variety
  11. Mar 22, 2015 at 11:51 AM
    #4351
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
  12. Mar 22, 2015 at 12:12 PM
    #4352
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
  13. Mar 22, 2015 at 12:15 PM
    #4353
    joshua721
    16 f150 xlt v6
    I never use speed set unless its commercial work and I have a very short time frame. It sands and leaves a different texture and shows under paint easier.
  14. Mar 22, 2015 at 3:46 PM
    #4354
    OZ-T
    Peter North
    British Columbia
  15. Mar 24, 2015 at 10:50 AM
    #4355
    cynicalrider
    cynicalrider #NFG
    Jersey
    Looking good Josh!
  16. Mar 24, 2015 at 1:40 PM
    #4356
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Is the floor porcelain tile?
  17. Mar 24, 2015 at 4:20 PM
    #4357
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    looks like it. I did the porcelain wood look tile back in 2013. turned out great.
  18. Mar 24, 2015 at 4:22 PM
    #4358
    OZ-T
    Peter North
    British Columbia
    I was just looking at some 6" x 72" wood grained porcelain tiles last weekend we may use for our ensuite
  19. Mar 24, 2015 at 4:54 PM
    #4359
    theredofshaw
    :thumbsup: follow the mix ratio on the color match grout to a T. buddy of mine didn't do so and ended up with a grout that wasn't quite what was advertised.
  20. Mar 24, 2015 at 5:57 PM
    #4360
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    That is a LONG tile
