Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. May 25, 2015 at 6:37 PM
    #4641
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If you're using an impact driver to set your screws , driving a 3" screw through 2 pieces of wood , you always run the risk of breaking the screw inside the joint without really knowing it . The wood will have different hardness levels just because of the nature of wood , and therefore different resistance levels to the screw as you are attempting to drive it , essentially you are forcing the screw to turn through 2 different resistance levels at the same speed which can result in the screw snapping at the interface between the boards
    Additionally , as wood dries , especially pressure treated lumber it shrinks and tries to twist etc , putting substantial pressure on the fasteners
    Nails can bend and still retain their holding capacity , try bending a screw , it will snap because they are brittle and hence have no shear value
    I built scaffold with 3" screws once , as I was taking it apart after a couple weeks of use I found that about every 2nd screw had broken , most right at the interface between the boards . It was later that day that the scaffold collapsed with me on it resulting in me falling 12' and landing in a pile of lumber that was the scaffolding .
    Just use nails
    T4RFTMFW likes this.
  2. May 25, 2015 at 6:47 PM
    #4642
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I'm not arguing with you, but I've never had a problem with deck mate screws. Some of the cheaper coated deck screws with a Phillips drive have had plenty of heads snap off. But with the t25 bit deck mate screws I can drive it completely through a piece of wood without it snapping.
    Either way, I'm going to be using approved nails made by Simpson strong tie.
    I tried sending a screen shot of this picture to live but it won't go through. So here's a link to a basic drawing of a free standing deck, which I've been basing my plan off of.
    https://www.decks.com/deckbuilding/Free_Standing_Decks
  3. May 25, 2015 at 7:05 PM
    #4643
    OZ-T
    Peter North
    British Columbia
    Stop arguing with me , just use some approved nails like the ones made by Simpson strong tie
  4. May 25, 2015 at 7:23 PM
    #4644
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    Haha.
    Your going to have to show me what your calling a hurricane strap. We use them to further tie a roofing system to a building.
    Toenailing is shooting a nail at an angle your corners done require toenails. It also depends on your railing and if its inside the framing or on the outside.
    Bolt size and number will be based off your deck size and planned use. You mentioned a hot tub not sure if that's going on your deck or not but that would change your load rating drastically.
    And a single tapcon has around 500lbs shear rating in light block.
    Do your drawings and submit them.
  5. May 25, 2015 at 7:34 PM
    #4645
    OZ-T
    Peter North
    British Columbia
  6. May 25, 2015 at 8:16 PM
    #4646
    JLink
    Josh
    Ocean, NJ
  7. May 26, 2015 at 6:25 AM
    #4647
    joshua721
    16 f150 xlt v6
  8. May 26, 2015 at 7:01 PM
    #4648
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Next your gonna tell me that I can't bury a shipping container under my deck and use it as a support;)
    BF5FB8A2-C9B0-4F72-923F-92A2B13DC800_zps_d71ea668217930dc99572af26a12b0e266d3f57d.jpg
  9. May 26, 2015 at 7:03 PM
    #4649
    OZ-T
    Peter North
    British Columbia
    As long as the foundation under the container doesn't settle , no problem
    I'm actually looking at buying a 20'
  10. May 26, 2015 at 7:06 PM
    #4650
    Frkypunk
    Timmy
    Woods of P.A.
    Mine is a 20' 5500 dry weight and most of it will be under frost level. I left adjustment for going up or down with the deck, just in case.
  11. May 26, 2015 at 7:08 PM
    #4651
    OZ-T
    Peter North
    British Columbia
    Oh nice , that's your set up ?
  12. May 26, 2015 at 7:12 PM
    #4652
    Frkypunk
    Timmy
    Woods of P.A.
    Yup...I ran low on money so did a quick 10'x50' deck 2' cantaliever and made the balusters out of emt conduit....lol people that see it scratch their head...I need it for occupancy:)
  13. May 26, 2015 at 7:13 PM
    #4653
    Frkypunk
    Timmy
    Woods of P.A.
    Can't bury truck containers...I coated my whole box in foundation tar.
  14. May 26, 2015 at 7:14 PM
    #4654
    OZ-T
    Peter North
    British Columbia
    How much $ was the container ? A 1 trip 20' is about $4000 CDN delivered in my area
  15. May 26, 2015 at 7:14 PM
    #4655
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Shipping containers are stout! I don't know the exact numbers, but you can stack them 5-10 high fully loaded. Supporting a deck isn't going to be a problem. :D
    My company has a containerized ring crane. Notice the containers used for ballast?
  16. May 26, 2015 at 7:15 PM
    #4656
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    I like
  17. May 26, 2015 at 7:15 PM
    #4657
    SMKYTXN
    Nathan
    Houston
    DCFB
    I used to have a 40' high cube refrigeration container. That was $5000 delivered.
  18. May 26, 2015 at 7:17 PM
    #4658
    Frkypunk
    Timmy
    Woods of P.A.
    $2200 delivered then I cut some logs and rolled it into to place with the skid steere. It's coated in galvanized with 1" marine grade plywood of a floor.
  19. May 26, 2015 at 7:17 PM
    #4659
    OZ-T
    Peter North
    British Columbia
    I'll be getting a container most likely , more stout and likely to survive movings better
  20. May 26, 2015 at 7:18 PM
    #4660
    OZ-T
    Peter North
    British Columbia
    Huh , good deal
    These ones already have a marine grade plywood floor , maybe there are different specs
