Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Sep 12, 2015 at 5:40 PM
    #5221
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You mean like a pre made fibreglass pan ?
  2. Sep 12, 2015 at 5:42 PM
    #5222
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    On site, resin and fiberglass cloth.
  3. Sep 12, 2015 at 5:46 PM
    #5223
    23Skidoo
    Paul
    meme
    My tile guy is using a schluter system with a fiberglass install below. Just curious what others are doing to waterproof shower floors.
  4. Sep 12, 2015 at 5:47 PM
    #5224
    OZ-T
    Peter North
    British Columbia
    Nope , never even seen that done in my 27 years as a carpenter , everybody here uses the Schluter system now , not sure what advantage a fibreglass pan would have over the dry pack and Kerdi system , is there one or maybe it's a regional thing like how they still use soldered copper pans back east
    23Skidoo[QUOTED] likes this.
  5. Sep 12, 2015 at 5:48 PM
    #5225
    23Skidoo
    Paul
    meme
    Thx
  6. Sep 12, 2015 at 5:49 PM
    #5226
    OZ-T
    Peter North
    British Columbia
    Huh interesting . Seems redundant because the Kerdi is waterproof so it's unlike the old EPDM system where the mud pack would actually accumulate moisture
    Not that it's worse or anything just seems like an extra step that isn't necessary
  7. Sep 12, 2015 at 5:52 PM
    #5227
    23Skidoo
    Paul
    meme
    I'm thinking my tile guy is a bit paranoid and not budget conscious .
  8. Sep 12, 2015 at 5:54 PM
    #5228
    OZ-T
    Peter North
    British Columbia
    Is he an older guy that likey started out using the old EPDM system and it's double drain ?
  9. Sep 12, 2015 at 6:00 PM
    #5229
    23Skidoo
    Paul
    meme
    Yes.
  10. Sep 12, 2015 at 6:11 PM
    #5230
    OZ-T
    Peter North
    British Columbia
    Well that's probably what's going on . In the EPDM system , those drains had weep holes so that while the bulk of the water went down the drain at tile level , any water that accumulated in the dry pack could weep out into the drain at the base of the dry pack , that's because the actual waterproof barrier , the EPDM , was at the bottom , meaning all the dry pack , tile and grout could absorb moisture
    The Schluter system puts the waterproofing directly under the tile at the top of the sloped tray , either their sloped foam pan or a site built sloped dry pack
    As there is no weep holes at the base of the Schluter drain to allow moisture out , my question to him would be if moisture gets through the Kerdi layer down to your fibreglass layer , how does it get out ? If there is a persistant leaking of water down to the fibreglass pan , it would only be a matter of time till that pan was full and would be leaking anyway , no ?
    DoorDing likes this.
  11. Sep 12, 2015 at 6:53 PM
    #5231
    23Skidoo
    Paul
    meme
    I agree. That is exactly why I am questioning him. Thanks for your input. I will revisit this again next week with him.
  12. Sep 13, 2015 at 4:31 PM
    #5232
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Funny that you put the shower head to the left...is that because of an outside wall or just more room on the left?
  13. Sep 13, 2015 at 5:11 PM
    #5233
    OZ-T
    Peter North
    British Columbia
    There is a shower head and 2 body sprays on the left side of the sloped ceiling , they are controlled by a mixing valve and diverter on the inside of the wall on the left , can't see them in the pics
    The mixing valve you can see on the back wall will control another shower head , a removeable hand held style that will be mounted on a fixed rail in the centre of the back wall
    My wife and I like different temperature water in the shower plus the hand held is nice for cleaning the walls and glass .
  14. Sep 16, 2015 at 2:43 PM
    #5234
    OZ-T
    Peter North
    British Columbia
    Pulled a 12/2 NMWU cable through a DB2 conduit today to provide switched power / lights out to my woodshed for the winter . My wife was my helper and we had to pull about 110' of cable , I thought having her pull the fish tape and wire through from outside would be the easy job while I stayed in the crawl and fed the wire and made sure it didn't get pulled in too far
    I think that was the longest pull in history .... at about 4' at a time .... with 10 second rests between each pull because I didn't tell her she was going to need gloves and apparently the fish wire was " cutting into her hands "
    I was like " why didn't you stop and put on gloves then ? "
    " you said I wouldn't need gloves "
    " uh ok , thanks for your help "
    WTF
  15. Sep 16, 2015 at 3:30 PM
    #5235
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :facepalm: :laughing:
  16. Sep 16, 2015 at 4:21 PM
    #5236
    OZ-T
    Peter North
    British Columbia
  17. Sep 16, 2015 at 4:39 PM
    #5237
    OZ-T
    Peter North
    British Columbia
    it was pretty straght forward , no bends only one elbow at the end , I was able to push the fish tape all the way through , no vacuum , mouse or string needed
  18. Sep 16, 2015 at 4:45 PM
    #5238
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    that volt drop though...
  19. Sep 16, 2015 at 4:52 PM
    #5239
    OZ-T
    Peter North
    British Columbia
    Yeah , we discussed that , you think there is too much drop to power up a light ?
  20. Sep 16, 2015 at 4:55 PM
    #5240
    OZ-T
    Peter North
    British Columbia
    I'm not too worried about it , seeing how this cable is replacing an extension cord thats been run out there for the last 5 years , but from a technical standpoint , what is the voltage drop at 110 ' ?
