Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 30, 2015 at 9:07 AM
    #5601
    daggs81
    daggs81 Well-Known Member
    CT Shoreline
    2017 TRD Sport
    My house is 2600 sqft BTW, with 2.5 baths.
  2. Nov 30, 2015 at 11:11 AM
    #5602
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    Looks like the viess is heating the water and you're using the gray tank as a holding tank for the water. That's why you wouldn't see any cold spots. The issue I heard about was from people drawing water straight off the tankless heater. Every time you stop the water at the faucet and turn it back on you can run into a small cold pocket of water while the heater relights.
    Nice setup BTW
  3. Nov 30, 2015 at 12:15 PM
    #5603
    daggs81
    CT Shoreline
    2017 TRD Sport
    Thanks, the guys who installed it did a great job. You are correct, the water coming out of my faucets is not coming directly from the water heater so i wouldnt see those cold spots.
  4. Nov 30, 2015 at 12:40 PM
    #5604
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    What's the benefits to use a tankless with its water going into a tank vs a tank heater? It's kind of the same concept as a tank heater, no?
    I'm genuinely curious. It's not really saving space with the tank there. And as far as efficiency, I wouldn't think it'd be much better. My tank gas heater rarely kicks on unless water is turned on and cold water is introduced. It's new and very well insulated. I'm just wondering what the benefits of your set up is vs tank heater. Just seems as though the main benefits of tankless which is huge space saving is eliminated that way. :notsure:
  5. Nov 30, 2015 at 12:43 PM
    #5605
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The tank is acting as a buffer I assume
  6. Nov 30, 2015 at 12:46 PM
    #5606
    T4RFTMFW
    T4RFTMFW Well-Known Member
    :popcorn:
    I need to replace mine in the spring. Electric..
    It's expensive to use, hoping the new models are both more efficient in use and in electricity needs. They should be, mine is 23 years old and still works fine, but is expensive.
  7. Nov 30, 2015 at 12:51 PM
    #5607
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Yeah, but why not just use a tank heater there?
  8. Nov 30, 2015 at 1:02 PM
    #5608
    daggs81
    CT Shoreline
    2017 TRD Sport
    My tankless heater also heats the lines for my hydro air heating system. In my setup, room was not an issue as there is almost too much room in my basement where this is located. This allows for one small, efficient heating system to handle both the hot water for the house and the heating system at the same time, hence being more efficient and actually saving some room as well.
    DEEVON911[QUOTED] likes this.
  9. Nov 30, 2015 at 1:08 PM
    #5609
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Oh, ok. That makes sense to me now. Thanks for the explanation.
  10. Nov 30, 2015 at 1:18 PM
    #5610
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    The tank operates like a normal water heater, maintains a temp in the tank. The tank has a temp sensor that fires the boiler, domestic hot water is heated via a heat exchanger.
  11. Nov 30, 2015 at 1:21 PM
    #5611
    OZ-T
    Peter North
    British Columbia
    Yeah but the water is preheated by the tankless heater no ?
  12. Nov 30, 2015 at 1:24 PM
    #5612
    Saskquatch11
    No, water that goes through the tankless heater is a closed loop.
  13. Nov 30, 2015 at 1:28 PM
    #5613
    OZ-T
    Peter North
    British Columbia
    I see
    We did something somewhat similar with a geothermal system to provide domestic hot water via a heat exchanger in a large storage tank branched off of the hydronic floor heat system in a client house I built
  14. Nov 30, 2015 at 1:41 PM
    #5614
    daggs81
    CT Shoreline
    2017 TRD Sport
    Correct
  15. Nov 30, 2015 at 3:58 PM
    #5615
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    Wow. Just messed with it shortly tonight and thus thing is impressive. It will hold itself on the wall. And once I had the settings right I didn't see dust.
  16. Nov 30, 2015 at 4:28 PM
    #5616
    OZ-T
    Peter North
    British Columbia
    Thats sweet
  17. Nov 30, 2015 at 5:04 PM
    #5617
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Last year we had replace 12 sheets of drywall in a room remodel and rented a tool very similar to this and what a lifesaver.....
  18. Nov 30, 2015 at 5:25 PM
    #5618
    OZ-T
    Peter North
    British Columbia
    Didn't realize that thing was so expensive , it's $1450 CDN without a vacuum at Lee Valley
  19. Nov 30, 2015 at 5:28 PM
    #5619
    joshua721
    16 f150 xlt v6
    Add the ct36ac too. If it preforms like they say the amount of time it will save will really add up. And I can't find a reliable drywall finisher so I'm doing more and more drywall.
  20. Nov 30, 2015 at 5:32 PM
    #5620
    OZ-T
    Peter North
    British Columbia
    I almost bought a $900 water saw last week cause I'm doing some tile work at home
