Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Dec 22, 2015 at 7:04 AM
    #5801
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Too many contrasting wood finishes in the room (excluding floor):
    -mantel
    -tv hutch
    -coffee table
    -end table(s)
    -book shelf
    By having at least a uniform or complimentary furniture/fixture finish in the room, that would help.
    Same with decor... picture frames, clock
    guitarjamman likes this.
  2. Dec 22, 2015 at 7:12 AM
    #5802
    daggs81
    daggs81 Well-Known Member
    CT Shoreline
    2017 TRD Sport
    My vote would be to do something like this:
    im not a big fan of the tile they picked for around the fireplace but you could pick what ever you want for that
  3. Dec 22, 2015 at 8:07 AM
    #5803
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    That is a really good idea! We use all sorts of free things we have gotten over the years but are planning on getting new furniture and tables with our returns this year.
    I showed my wife that picture and she screamed "I love it!" That is a great idea too - thanks!
    theredofshaw likes this.
  4. Dec 22, 2015 at 6:38 PM
    #5804
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    @wileyC
    Here's your opportunity for a pretty good " I told you so " moment
    Let it all out , I can take it , lol
    SH7mi, joshua721 and DoorDing like this.
  5. Dec 22, 2015 at 6:55 PM
    #5805
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    :laughing: One never stops learning.
  6. Dec 22, 2015 at 6:58 PM
    #5806
    OZ-T
    Peter North
    British Columbia
    The tiles would actually stay up without the jig but wouldn't allow us to manipulate them into plane very easily . We set our 3 grounds to plane out with each other first and that ensured the ceiling field would plane out with the sloped door jamb when we got up to that point . The jillpoke was because we were getting about 1/8" of sluff in the middle of the lower panel near the top
  7. Dec 22, 2015 at 7:00 PM
    #5807
    OZ-T
    Peter North
    British Columbia
    Worked good
    We abandoned our other jig system this morning , this was way better
  8. Dec 22, 2015 at 8:09 PM
    #5808
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    :bikewheelie2:
    ...gotta do what you gotta do... :D
    ...now we're beginning to see... you've got a heck of a lot of tile getting put into that bathroom!
  9. Dec 22, 2015 at 8:16 PM
    #5809
    OZ-T
    Peter North
    British Columbia
    220 sqft of the Bianco Carrera and about the same of the Silver Shadow
  10. Dec 22, 2015 at 8:27 PM
    #5810
    wileyC
    Centerville, OH
    ...judging from the gable in the shower, i'm assuming this is a second story bathroom?.. curious what kind of joist and subfloor arrangement you put in this room... hopefully meets stiffness min, ...if I remember from reading john bridge forums years back, ...a L/720 max deflection spec for natural stone...
    :fingerscrossed:
  11. Dec 22, 2015 at 8:31 PM
    #5811
    OZ-T
    Peter North
    British Columbia
    Yes its in the roof of the second story , joists on the second floor are Select Structural DFir2x12 on 16" centres , in the ensuite I dropped down to 2x10 to allow for the 2" 32MPA hydronic heated thin slab over framing , the shower is dropped again to 2x8 to allow for a curbless shower pan to plane out with the top of the heated slab , span is only 10' in that area , plus Ditra
  12. Dec 22, 2015 at 8:41 PM
    #5812
    wileyC
    Centerville, OH
    ...the 2x8 (16" O.C.), i'd imagine that is code in Canada?.. span is supported from below where the joist system step-down transition occurs?...
  13. Dec 22, 2015 at 8:53 PM
    #5813
    OZ-T
    Peter North
    British Columbia
    Floor joist code is dictated by the Span Tables which are in turn determined by lumber species / span / loading / on centre spacing , but in short , yes they meet code for that span
    The joists run end to end and parallel to each other so where there is a drop down in size , there was a step in the floor during framing
    ie ~ the bottom of the joists are at the same elevation / sit on the same wall plane
  14. Dec 23, 2015 at 7:02 AM
    #5814
    daggs81
    CT Shoreline
    2017 TRD Sport
    @OZ-T What grout are you planning on going with, our master is carrera marble similar to the bianco you chose. I wish we went with an epoxy grout to help with the grout staying cleaner and not staining, but we ended up using a sanded grout with stain blocker, but its not really blocking anything and requiring a lot of cleaning.
  15. Dec 23, 2015 at 8:54 AM
    #5815
    OZ-T
    Peter North
    British Columbia
    We're going to use an unsanded Mapei grout , likely Warm Grey
    Did you seal yours ?
  16. Dec 23, 2015 at 9:08 AM
    #5816
    daggs81
    CT Shoreline
    2017 TRD Sport
    we did, but we also went with a white grout which i am wishing we went with grey instead. But you live and you learn. Its also hard to find a decent cleaner that is safe with the marble tile.
  17. Dec 23, 2015 at 10:02 AM
    #5817
    OZ-T
    Peter North
    British Columbia
  18. Dec 24, 2015 at 9:25 AM
    #5818
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Roofers came today. Said I had a half dozen nails poking through the roof shingles and some flashing that was not properly installed.
    Hoping it's all good now. Atleast until spring when my roof gets fully replaced.
    Bennett707 and DoorDing like this.
  19. Dec 24, 2015 at 10:02 AM
    #5819
    T4RFTMFW
    Agreed.
    I'm now left hoping that the new roof replacement crew is better than the previous one.
    :boink:
  20. Dec 24, 2015 at 11:57 AM
    #5820
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    bitch lets knock that shit out.
