Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jan 4, 2016 at 8:25 PM
    #5941
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Yup it is hard metal pipe throughout.
  2. Jan 4, 2016 at 8:31 PM
    #5942
    ABA180
    East Bridgewater MA
    Got it..I'll have to hit the local Home Despot for that and see if the tape measure trick works. Much obliged.
    Now to solve my faucet issue..my dishwasher adaptor aerator has a small screen and the water sprays out too fast. I threw on a regular aerator with a 1.5 gpm screen and much better, so can I get a 1.5gpm piece and drop it in the dishwasher metal one?
  3. Jan 4, 2016 at 8:34 PM
    #5943
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    K
    Here we have to have a 10mm ( 3/8" ) rainscreen by code . 1x2's are fine but what is really economical is 1/2" plywood strips because you can use up all your oddball scraps and rippings
    Here we use a perforated aluminum J moulding for the bottom drain , you can get different sizes from 3/8" - 1" . If you can source some locally get the drain size that will work with your strapping size ( ie 1/2 j moulding for plywood or 3/4" j moulding for 1x2 )
    Looks like this
    Use that top and bottom , for the drain and air intake at the bottom and vent at the top . Use solid corners at your wall corners to provide decent backing for any corner trims ( ie use 1x4 of 4" plywood strips )
    I usually install my windows at sheathing plane and then run a solid strip of strapping material around the bottom and both sides
    The head flashing at windows and doors needs to go on so that it tucks under your primary WRB , and you need to use another section of j mould above doors and windows to allow moisture out / air in .
    You need to figure out a trim detail to allow the top of wall j mould to vent , don't vent the rainscreen into the soffit , make s termination at the eaves
    23Skidoo[QUOTED] likes this.
  4. Jan 4, 2016 at 8:37 PM
    #5944
    OZ-T
    Peter North
    British Columbia
    also I like to allow gaps between the straps vertically to allow some cross ventilation
  5. Jan 4, 2016 at 8:45 PM
    #5945
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Thanks. Sounds like a good idea.
    I found a local supplier for the "j" flashing.
  6. Jan 4, 2016 at 8:47 PM
    #5946
    OZ-T
    Peter North
    British Columbia
    Its way more sturdy that trying to wrap insect cloth around the ends
    Hit me up if you got any questions
    DoorDing and 23Skidoo[QUOTED] like this.
  7. Jan 4, 2016 at 8:54 PM
    #5947
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I don't understand. Is your dishwasher a portable one where you roll it to the kitchen sink and hook up the supply?
    If you have one like that, I'd remove the aerator completely for the DW. All an aerator does is prevent splashing when filling a glass or something. It's just an air/water mixer..... Your DW won't know the difference. :)
  8. Jan 4, 2016 at 8:58 PM
    #5948
    ABA180
    East Bridgewater MA
    It is. My old sink had the adapter for the dishwasher hookup. I changed the faucet and kept that adapter, when using the sink now the water stream is all over the place and splashes out of the sink.
    I tried using the screen added into it and no dice. Tonight I got a 1.5gpm aerator (non hookup) at Home Despot and the stream is perfect. As it stands now I'll have to swap the piece out to use the DW..which if that's the fix so be it but have to think it can be one for all
  9. Jan 4, 2016 at 9:04 PM
    #5949
    File IFR
    Central MA
    If you feel confident enough with plumbing, you should go under the sink and install a 'T' on the hot pipe and a quarter-turn shut off with adapters to accept your DW Line.
    You'll never screw around with removing and installing the aerator on the fixture again for each wash.
  10. Jan 4, 2016 at 11:01 PM
    #5950
    scocar
    scocar Patron of the Farts
    Just put my Lee Valley free shipping order in. Nothing major, but the sawzall pruning blade, a Simple Scribe, a couple more mini plier/snips (the set I got for Christmas was good, Japanese make, I filled it in with a couple more), metal bender for the vise, and some wireless hinge LEDs for inside cabinets. Mounts to euro hinges, but you can put them elsewhere. I may try one in my Tacoma console.
    http://www.leevalley.com/US/wood/page.aspx?cat=1,43349&p=73761
  11. Jan 4, 2016 at 11:09 PM
    #5951
    ABA180
    East Bridgewater MA
    That I have not a clue how to do. It looks like the adapter one is narrower than the regular, so if I can get an adapter one the same width that is the cure.
  12. Jan 6, 2016 at 12:44 PM
    #5952
    OZ-T
    Peter North
    British Columbia
    When you need a 13" tile and you only have 12x12
    DoorDing likes this.
  13. Jan 7, 2016 at 10:23 AM
    #5953
    OZ-T
    Peter North
    British Columbia
    Maticuno likes this.
  14. Jan 7, 2016 at 11:57 AM
    #5954
    scocar
    Woot! Got my upgrade set today.
  15. Jan 7, 2016 at 12:14 PM
    #5955
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    You could run your house for a few days off that thing. :thumbsup:
  16. Jan 7, 2016 at 2:10 PM
    #5956
    OZ-T
    Peter North
    British Columbia
    Do the bases have the yellow tab with the star where the battery attaches ?
  17. Jan 7, 2016 at 2:40 PM
    #5957
    scocar
    The battery bases are black with the star, which also works, I believe. Or maybe that was the bottom of the impact driver. I'll pull everything out of the box and review the video again tonight at home.
  18. Jan 7, 2016 at 3:19 PM
    #5958
    OZ-T
    Peter North
    British Columbia
    Yeah I just looked at the back of the battery package , yellow , yellow with star and black with star all work with the 5ah battery
  19. Jan 7, 2016 at 4:21 PM
    #5959
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I learned the joys of a tractor towed chain harrow today. Didn't get any photos, but my yard and horse pasture has been hurting with rain, then freezing, then rain again and horse poo all over the place.
    About 45 mins fixed 3+ months of damage...
    Oh...and HI!!
  20. Jan 7, 2016 at 4:41 PM
    #5960
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Wow 5ah. I just looked up my Milwaukee 18v xc batteries, they're only 3ah
