Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 8, 2016 at 9:47 PM
    #6161
    Protosimian
    Protosimian Headbanger.
    Roger
    Where the Wild Things Are
    2012 MGM Sport
    Dents and scratches, and other stuff.
    EDIT: Reply to Bennett707...forgot to quote,:frusty:.
    There should be a legend on the document, if you have a complete survey.
    In my jurisdiction the circles would probably represent the statutory iron posts mentioned by OZ. These are often buried during development, rightly or wrongly, so a metal detector is often needed.
    If the side walk is a public thoroughfare, and the circles are your property line, then the sidewalk should be bordering or slightly set off from your property line. This assumes that any right of way or easement would be shown on your source document
    Maybe get quotes from a surveyor on staking out your boundary. Peace of mind, you know.
    EDIT 2: Just for the record, get the underground services marked before you drill.
    :bananadead:
    theredofshaw and Bennett707 like this.
  2. Feb 9, 2016 at 5:24 AM
    #6162
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    Im a surveyor and will lend a little bit of insight. If you have a sidewalk, it should be outside of your property and lie within the public right of way for the road. We design them to be 4' off the property lines.
    In regards to those circles, they very well could be iron pins/rods, but I would not be surprised if they are just a circle to delineate the end of a line/segment. There are no "crows feet" or any other marker to show where a curve ends and a tangent begins, so some drafters set a circle to mark the end of a bearing line in AutoCAD.
    If you read your deed, it will read from a point, go such and such an angle a distance of 75.00' to another point. OR it will say from an iron pin, go such and such an angle a distance of 75.00' to an iron pin. That will tell you what those circles are - but I would lean more towards being the marker for the end of a line (no surveyor puts an iron pin at EVERY node on a property line like that plan is suggesting for an entire subdivision).
    Also, I would be cautions about that hatching line on the rear or your property. Your deed will describe what is going on back there, but it seems like you have a continuous easement or something similar (also marked on the plan with a thick dashed line). Your best bet is to hire a surveyor to set wooden stakes at your property corners, then install the fence 1' inside of those stakes.
  3. Feb 9, 2016 at 6:57 AM
    #6163
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    always 811!! :) no legend unfortuantely, just found that in my closing documents when i purchased the house. think back in 1976 they did the bury?
    good info about the circles. i will find my dead i noticed that thick line and was wondering what that was. thank you for sharing the information!
    ill attempt to find the rods myself if i can find a metal detector. otherwise, surveyor it is!
  4. Feb 9, 2016 at 8:53 AM
    #6164
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Totally agree on putting the fence totally on your property and not on the property line , also hiring a surveyor
  5. Feb 9, 2016 at 8:59 AM
    #6165
    Protosimian
    Roger
    2012 MGM Sport
    You would hope major services would be identified on the survey, but it's free where I'm at, so I get locates done even when I'm reasonably sure there is nothing there.
    Also, the stuff has to get from the service to the home, and any of those local buried connections would not be on the survey, in the normal course.
    Bennett707[QUOTED] likes this.
  6. Feb 11, 2016 at 3:37 AM
    #6166
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    This past weekend, I replaced an old sink/counter combo with a new simple utility sink & new faucet and added some plano shelving next to it (was wasted space prior). Had to tie the 2 1/2" PVC into the existing 2 1/4" Copper. Worked out great & no leaks!
  7. Feb 11, 2016 at 8:27 AM
    #6167
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Copper drain lines?
  8. Feb 11, 2016 at 8:33 AM
    #6168
    daggs81
    daggs81 Well-Known Member
    CT Shoreline
    2017 TRD Sport
    Yeah, ive seen that in a bunch of older homes here in CT, copper must have been extremely cheep back in the day.
  9. Feb 11, 2016 at 1:25 PM
    #6169
    Sig45
    Mark
    Maine
    Yup...entire house! Built in the mid 60's when copper must have been the norm & cheap.
    Copper vent pipes as well.
  10. Feb 11, 2016 at 1:47 PM
    #6170
    OZ-T
    Peter North
    British Columbia
    Our old house waa all copper drains and vents too
  11. Feb 11, 2016 at 1:51 PM
    #6171
    Gamebreaker81
    Gamebreaker81 Well-Known Member
    MA
    2016 sr DCSB 4x4 v6
    Had to install a new dishwasher, heating element clips broke and caused it to touch and melt threw plastic tub on the old one..... Good times water all over the place, leaked into basement....
    Maticuno likes this.
  12. Feb 11, 2016 at 2:53 PM
    #6172
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Maybe I just can't see it in the photos, where's the P trap?
  13. Feb 11, 2016 at 2:54 PM
    #6173
    Maticuno
    2011 Suburban 2500
    Stainless steel tub FTW.
  14. Feb 11, 2016 at 3:42 PM
    #6174
    Sig45
    Mark
    Maine
    No P trap under the sink....I used the existing copper trap to the left of where I connected the PVC to the copper. That's how the old double sink was setup (but with copper drains that connected where I cut the copper for the new connection).
    I simply recreated what was there using pvc.
  15. Feb 11, 2016 at 6:59 PM
    #6175
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    A guy at work had a problem with his heating element on his dishwasher today.
    He came down stairs and smelled smoke, walked into the kitchen and it was full of smoke. opened the dish washer and one of his kids sippy cup lids had fallen on the heating element and was burning (i guess the rinse cycle had finished).
    Do all dish washers have heating elements? I was always under the impression they just use the regular hot water from the water heater.
  16. Feb 11, 2016 at 7:00 PM
    #6176
    abarber11
    abarber11 Well-Known Member
    ATX
    2011 DCSB
    Heating element is for heated dry I think
  17. Feb 11, 2016 at 7:08 PM
    #6177
    Protosimian
    Roger
    2012 MGM Sport
    ^^ this,
    But, I believe that my dishwasher also heats the water. It has a steam sanitize function.
    But not with the element in the tub.
    Also, I've had the smoke show with the rinse aid cap falling on the element. Unpleasant.
  18. Feb 11, 2016 at 7:33 PM
    #6178
    Gamebreaker81
    MA
    2016 sr DCSB 4x4 v6
    The new one has same element on bottom of tub. SS this time around and a product that's made in the USA go figure... I didn't even think that was a thing anymore.
  19. Feb 11, 2016 at 7:36 PM
    #6179
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I think anything heat dry cycle will have a heating element..
  20. Feb 11, 2016 at 7:41 PM
    #6180
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I know this is an older post now, but I sold these for a while at HD. They are strong and last well but people broke the power switch pretty commonly. So once you change the power switch they do a great job.
    scocar[QUOTED] likes this.
