Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 6, 2016 at 11:12 PM
    #7021
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    That is the pattern yes. He claims he took apart some shingles, reflashed the area where the skylight was, and shingled it back up. But I've had 2-3 leaks again since
  2. Jun 6, 2016 at 11:24 PM
    #7022
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I thought you removed the skylight and then reshingled the whole roof on that side
  3. Jun 6, 2016 at 11:26 PM
    #7023
    ABA180
    East Bridgewater MA
    Contractor removed skylight and shingled whole roof on that side.
    Leak happened. Contractor came out and said he saw a leak, reshingled part of it.
    Leak happened. Contractor came out, reflashed the area where skylight once was, reshingled.
    2 more leaks since.
  4. Jun 6, 2016 at 11:30 PM
    #7024
    OZ-T
    Peter North
    British Columbia
    Is it a straight gable side of roofing ( ie no dormers or valleys ) ?
  5. Jun 6, 2016 at 11:33 PM
    #7025
    ABA180
    East Bridgewater MA
    There is a small dropoff right to left, I'll try to get a pic tomorrow. The left side is where the issue is but it's about 6 feet away from said drop and I'm not taking any water there.
  6. Jun 6, 2016 at 11:39 PM
    #7026
    OZ-T
    Peter North
    British Columbia
    Just curious because you said his second repair attempt included " re-flashing the area where the skylight was " , if there is no valleys , dormers or similar there , then there should be no requirement for any type of flashing , the shingles should be continuous
  7. Jun 6, 2016 at 11:48 PM
    #7027
    ABA180
    East Bridgewater MA
    So he stated to me, yup. Were it that the skylight still existed, I guess it would be flashed..correct?
  8. Jun 6, 2016 at 11:50 PM
    #7028
    OZ-T
    Peter North
    British Columbia
    Yes , the skylight would have flashing around it , but that would be removed when the skylight was removed and the hole filled in
  9. Jun 7, 2016 at 12:00 AM
    #7029
    ABA180
    East Bridgewater MA
    Would the top of the roof be flashed? Only other thing I can think of, unless he's pulling my chain
  10. Jun 7, 2016 at 12:05 AM
    #7030
    OZ-T
    Peter North
    British Columbia
    Do you have a continuous ridge vent ?
  11. Jun 7, 2016 at 12:07 AM
    #7031
    OZ-T
    Peter North
    British Columbia
    I gotta hit the rack
    Take a pic of the roof area if you get a chance
  12. Jun 7, 2016 at 12:11 AM
    #7032
    ABA180
    East Bridgewater MA
    Good idea, past my bedtime.
    Don't think it's continuous but I know diddly shit about roofing. I'll do my best on pictures..thanks for the help Oz
  13. Jun 7, 2016 at 3:05 AM
    #7033
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Remember... it's like my pops says. Water is tricky, the leak may not even be where the water is. It may be coming from somewhere else and it just shows up there.
  14. Jun 7, 2016 at 5:37 AM
    #7034
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    Where the skylight was what does it look like. Did they remove and fill it in or did they remove it and leave it proud of the roof?
  15. Jun 7, 2016 at 8:01 AM
    #7035
    OZ-T
    Peter North
    British Columbia
    Exactly , thats why I asked about the underlayment , if done correctly even water under the shingles should flow down to the eaves
    Cativelense[QUOTED] likes this.
  16. Jun 7, 2016 at 8:04 AM
    #7036
    OZ-T
    Peter North
    British Columbia
    Thats a good point , I assumed the curb was removed but if not then there would be flashing required there
    That would be a pretty lame way to do it if the curb was left
  17. Jun 7, 2016 at 8:08 AM
    #7037
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    Got some news on my fireplace remodel today. Had another company come out and look at what I have. They're the 3rd source to tell me to tear down the existing brick chimney to the roof line, frame it in and shingle over it, and put in a vent-free gas insert. The materials cost to do this is pretty minimal, just some labor. I'll then cover the lower half of exposed brick with vinyl.
    Any advice on how to cover the brick with vinyl? Do I need to worry about moisture?
  18. Jun 7, 2016 at 9:28 AM
    #7038
    OZ-T
    Peter North
    British Columbia
    Not sure why people hate skylights so much , if your roofer doesn't suck they don't leak
    SH7mi likes this.
  19. Jun 7, 2016 at 9:35 AM
    #7039
    OZ-T
    Peter North
    British Columbia
    Exactly what I said , poor workmanship
    scottalot likes this.
  20. Jun 7, 2016 at 9:36 AM
    #7040
    OZ-T
    Peter North
    British Columbia
    I've probably installed about 50 in my projects never once had a leak
