Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Aug 12, 2016 at 6:43 AM
    #7441
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Out with the old...
    I literally tore it apart by hand. It was built with 4" common nails and joists that were placed 'about here'... 'no, over here'... 'maybe there would be better.'
    In with the new...
    (replaced a shitty cedar sash window with a brand new vinyl crank out on the way by ($20 at a garage sale) Built an insulated box to fill the void underneath.
    ... are we there yet?
    ... it's just around the next corner, kiddies.
    BBQ and bistro table centre.
    This is tier one. It will step down onto a lower deck across the angle, then down again into a gazebo/pagoda/hut or some kind of cabana. I change my mind every day I look at it.
    I've started decking it as well.
    No need to dig, as it's sitting on compacted clay and shale (80 to 90%) that would break your ankle using a shovel, or your wrist with a pick. Also, it's lower than the 1'10" required for dug footings/bigfoots/sonotubes.
    Here's a sample of how I'm doing the corners. The old deck was butted square and looked like shit. Because each catwalk is a different width, and the house is not square, I ran a butt trim between the angles.
    ... and I was an 1/8" off on my calculations for the last board along the wall, probably because I've been hosing down the lumber pile every evening to stop the wood from warping in this ridiculous heat wave. I don't want to rip it, so I'm going to let the boards dry and shrink in this heat, then pop the last one in and run a bead of Flex 9000 along the wall after I replace the lower clap board with an ice/water shield behind it that lips over the ledger. Yes, I will carriage bolt the posts.
    BTW, do yourself a favour when building a deck and use FastenMaster Guard Dog screws. They do not strip, twist, bend, rust, or try and mess with your little sister. You can put them in and take them out numerous times. Also get a good quality cobalt Robertson #2 (square for you Yanks) bit and an impact driver and call it a day.
    It's been brutal working alone in this 34*C heat (42* + with the humidex).
    scocar, Cuffs and AKSig88 like this.
  2. Aug 12, 2016 at 7:49 AM
    #7442
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    1. looks FANTASTIC
    2. thank god, so tired of nails and screws messing with my little sister. home depot will be happy to not receive any more complaints as well
  3. Aug 12, 2016 at 8:05 AM
    #7443
    taczilla
    Marc
    2016 RAM Rebel
    Thanks, man!
    You should have seen the 28 year old train wreck that was there before.
    I just want to get Tier 1 done:
    Stage 1 - framing (done, some touch-ups and re-enforcement/blocking of the angle header required)
    Stage 2 - picture frame and decking (in progress)
    Stage 3 - balusters and railings
    I'm just fried from working out in the heat yesterday. I'll deck this little inside corner up to the outside corner section today and call it 5 o'clock:
    I am running out of deck plank. Thank heavens...
    BTW, my outside clock quit at 5:05 two years ago. I refuse to fix it. Look between the bugs on the wall:
    :cheers:
    wilcam47, scottalot and truchador like this.
  4. Aug 12, 2016 at 9:12 AM
    #7444
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    @taczilla did you run lags or timber screws for the ledger to building connection ?
    Looks good
  5. Aug 12, 2016 at 9:28 AM
    #7445
    Bennett707
    Oregon
    for a bed platform,
    think OSB plywood would be fine? don't expect it to get very wet under my canopy. hmm
  6. Aug 12, 2016 at 9:35 AM
    #7446
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    It'll still draw moisture and swell and crumble depending on what part of Oregon you live in lol. If you're in the desert no prob
    Bennett707[QUOTED] likes this.
  7. Aug 12, 2016 at 10:12 AM
    #7447
    taczilla
    Marc
    2016 RAM Rebel
    Thanks!
    Because this is an older house and had crappy insulation, I had already foam sealed all of the floor joist/header/sill pockets inside. I ran 4" lag screws through the ledger into the building every 2' and paired at 4'. I figured they would bite through the ledger/sheathing/joist header without encountering any surprises (e.g. wires that shouldn't be there). Much better than the 4" common nails that were scattered hither and yon along the ledger.
    The house is an older Beaver Lumber kit A-frame home that was put together by Fric & Frac. Don't get me started on the main girder support beam that I replaced with a 12" steel I-beam. That was four 2x10's butt scarfed together at parallel half-way points (2 inside mated together and 2 outside at half way over a span of 27', if you can picture that) without any thought towards engineering! I had to jack the center of the house 1 1/2" to make it level, support the entire floor on both sides with jacks and temporary steel beams everywhere, all the while avoiding the fresh-air return and main heating ducts, remove the old wood girder beam :)sawzall:), and then slide the new I-beam in, shim and pack it. Inside double and triple header supports for openings and support walls only had a few nails holding them together on each side, all without hangers on the ends. I screwed all those together at 8" intervals and installed hangers everywhere that was necessary. The floor does not bounce anymore.
    My wife was freaking out through the whole process and went and stayed at her friends place.
    23Skidoo likes this.
  8. Aug 12, 2016 at 10:52 AM
    #7448
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
    taczilla likes this.
  9. Aug 12, 2016 at 10:59 AM
    #7449
    98tacoma27
    Ben
    Not Beech Creek
    Specs on the dovetail saw please. I'm in the market for one
    JLink likes this.
  10. Aug 12, 2016 at 2:28 PM
    #7450
    OZ-T
    Peter North
    British Columbia
    Phase 2 all ready to go for tomorrow
    2 coats of paint inside and out on the steels and the jigs all set , plumbed and braced
    Plain Jane Taco likes this.
  11. Aug 12, 2016 at 4:42 PM
    #7451
    OZ-T
    Peter North
    British Columbia
    Concrete truck is all ready to go to work in the morning
    joshua721, Jiveydude, robssol and 5 others like this.
  12. Aug 12, 2016 at 4:50 PM
    #7452
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    If I'm not mistaken, that's the latest Armstrong 4700R model, correct? ;)
  13. Aug 12, 2016 at 4:51 PM
    #7453
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    well aint that some shit. good engineering there man!
    Maticuno likes this.
  14. Aug 12, 2016 at 5:09 PM
    #7454
    Bennett707
    Oregon
    why not dump concrete mix in ground
    pour water
    profit
  15. Aug 12, 2016 at 5:10 PM
    #7455
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    yep, ..it's the smaller one, the DF 500... i like their track saw so much, and came to the point where if feel i need a good (and faster, ..and dust collection port!) tool for joinery...
  16. Aug 12, 2016 at 5:16 PM
    #7456
    OZ-T
    Peter North
    British Columbia
  17. Aug 12, 2016 at 5:26 PM
    #7457
    wileyC
    Centerville, OH
    it's the rob cosman dovetail saw (woodcraft.com has them on sale).
    specs:
    1. the one i got has the black composite handle, ..the white handle was on backorder... i think he'll be offering this saw with the option for a wooden handle (various hardwoods), but i think it's considerable more money.
    2. brass spine and flush copper pins, brass saw nuts
    3. progressive pitch teeth, designed to make starting the initial kerf easier...
    4. 0.002 set
    5. dovetailed pine box included!
    i have to say, it has a good feel, and heft, to it... it comes in the nicely dovetailed (of course) pine box, ..i've been going a while without a true dovetail saw, and, as a rob cosman fan, i think this will be a joy to use... he's got videos on his youtube channel talking about the saw, and a longer one about how he manufactures them, all 100% hand built there at his shop!
    https://www.youtube.com/watch?v=Fb8tVZtX1_4
    BTW, rob is also now making a tenon saw version...
    98tacoma27[QUOTED] likes this.
  18. Aug 12, 2016 at 11:58 PM
    #7458
    Threerun
    Threerun Well-Known Member
    Lost in Montana *recalculating*
    2016 Silverado LTZ
    6.2L 8spd stock
    C7788B7E-10F0-4BFE-9E16-5ED1FB9AB03E_zps_17681d3cd54b22cea84795583763a13acdffeb19.jpg
    Wifey's potting shed coming together..
  19. Aug 13, 2016 at 8:31 AM
    #7459
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I love the look of that retaining wall.
    theredofshaw likes this.
  20. Aug 13, 2016 at 8:31 AM
    #7460
    taczilla
    Marc
    2016 RAM Rebel
    Crap! I just sold an old rusty cart like that for $20. Coulda, woulda, shoulda.
