Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Oct 27, 2016 at 11:26 AM
    #7961
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    I have question for any plumbers, I have a second floor shower stall which started leaking thru the ceiling so I cut a hole and found that water rivlets are coming thru the seam in the pvc trap, the trap has been cemented in on both ends so removing it would be futile, my question is the best fix is to cut it out and replace but what could I replace the cut piece with or is it feasible to do anyway, somebody says you can cut it out and replace with a neoprene coupler that has 2 hose clamps but its a trap and is constantly holding water im afraid the the coupler itself would eventually start leaking at the cut joints. some people recommended using a sealant or glue but it wont be a permanent fix, other than ripping out the floor pan and PVC connections and start all over does anyone have a suggestion that may work?
  2. Oct 27, 2016 at 11:31 AM
    #7962
    Threerun
    Threerun Well-Known Member
    Lost in Montana *recalculating*
    2016 Silverado LTZ
    6.2L 8spd stock
    Can you access the pipe above and below the trap?
    scottalot likes this.
  3. Oct 27, 2016 at 11:53 AM
    #7963
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You would have to cut it out to get a Fernco fitting on no matter what
  4. Oct 27, 2016 at 11:58 AM
    #7964
    Mush Mouse
    mush
    2013 SR5
    only where these pictures are I cannot from above only if I remove the whole shower floor
  5. Oct 27, 2016 at 12:03 PM
    #7965
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Do you have any room above the trap maybe 2 inches to cut it loose? Can you get a side pic of this trap?
  6. Oct 27, 2016 at 12:30 PM
    #7966
    Mush Mouse
    mush
    2013 SR5
    no I cannot get a side pic of it unless I rip down more of the ceiling or all of it, but its similar looking to this picture.
  7. Oct 27, 2016 at 12:34 PM
    #7967
    Mush Mouse
    mush
    2013 SR5
    this seems to be the best, I am a little hesitant to do this cutting myself, it might be best to call a plumber to evaluate but I know the answer would be a complete renovation of the shower stall and bathroom which is what I want to avoid
  8. Oct 27, 2016 at 12:36 PM
    #7968
    Threerun
    2016 Silverado LTZ
    6.2L 8spd stock
    Check with a plumbing supply house, but I'm thinking cut it but with enough exposed either end for a slip pipe adapter and simply put a new p trap to the side.
  9. Oct 27, 2016 at 12:37 PM
    #7969
    Threerun
    2016 Silverado LTZ
    6.2L 8spd stock
    My old house had old pipes and a few areas had adapters. Had no issues
  10. Oct 27, 2016 at 12:39 PM
    #7970
    Mush Mouse
    mush
    2013 SR5
    I may just try using the jb weld after cleaning and drying up the pvc its only a slight leak and you cannot see it with the human eye in the seam
  11. Oct 27, 2016 at 12:41 PM
    #7971
    Mush Mouse
    mush
    2013 SR5
    yes, probably the best way, probably best get a plumber to do it unfortunately ive never done it might be over my head and dig a deeper hole trying to do it myself
  12. Oct 27, 2016 at 12:45 PM
    #7972
    OZ-T
    Peter North
    British Columbia
    I would call a plumber
    truchador likes this.
  13. Oct 27, 2016 at 12:49 PM
    #7973
    Mush Mouse
    mush
    2013 SR5
    I agree, if I can cut the leaking area out and replace it with a neoprene fernco coupler probably would work hopefully long term, better than just trying to seal it with something
  14. Oct 27, 2016 at 12:50 PM
    #7974
    Mush Mouse
    mush
    2013 SR5
    agreed, thought to get some input 1st probably best to get an expert, but I will ask about just cutting the trap and trying a coupler
  15. Oct 27, 2016 at 12:52 PM
    #7975
    Mush Mouse
    mush
    2013 SR5
    thing is that its unusual and my luck that a tiny leak developed in the seam of the trap like that, I guess having water lying in the bend eventually found its way out
  16. Oct 27, 2016 at 12:54 PM
    #7976
    Mush Mouse
    mush
    2013 SR5
    yes from what im reading online they work very well as opposed to cutting a regluing pvc parts
  17. Oct 27, 2016 at 1:06 PM
    #7977
    Threerun
    2016 Silverado LTZ
    6.2L 8spd stock
  18. Oct 27, 2016 at 1:08 PM
    #7978
    Mush Mouse
    mush
    2013 SR5
  19. Oct 27, 2016 at 1:52 PM
    #7979
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    If OZ-T cant fix it ;)
    theredofshaw likes this.
  20. Oct 27, 2016 at 2:32 PM
    #7980
    Toyko Joe
    Toyko Joe Here for the pictures
    IMO I would:
    -Remove drain
    -Remove elbow
    -Cut back to clean PVC for new union
    -Replace drain, elbow etc.
    It's like $50 in parts maximum.
