Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jan 25, 2017 at 3:38 PM
    #9041
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    I have a smart thermostat...but it came with my heating/cooling unit. They are nice, give you a lot of control on how you heat/cool your house and when. I don't think they are necessary....but then again, I didn't think smart phones were.... till I owned one.:)
  2. Jan 25, 2017 at 3:53 PM
    #9042
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Ive always been curious what the advantage of something like a Nest or Ecobee3 is? Yeah i get that they "learn" when you are home and not home but I can do that with my programmable thermostat. Especially with my schedule that could end up changing week to week I feel like i would just confused the Nest more than it learning. Example being right now Im getting up at 3am, next week i might be getting up at 6am, the following week might be 430. Same for getting home, that can be anywhere from 230 to 5.
    Most of the reviews Ive read are more from people who were to lazy to use a programmable thermostat. Or people complaining they are hard to set. But i change mine all the time and find it take all of 2-3 minutes to do.
  3. Jan 25, 2017 at 4:11 PM
    #9043
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    The Nest will also detect when you are home via a motion/proximity sensor built into the unit, and there's also a feature you can opt in or out of where it will use your phone to tell if you are home or not. The unit will automatically change from your "Away" temperatures, to your "Home" temperatures or vice versa when it detects that you're home or away and helps for when you're in or out outside of regular programmed times.
  4. Jan 25, 2017 at 4:21 PM
    #9044
    Frkypunk
    Timmy
    Woods of P.A.
    You can also change temperature, from your phone
  5. Jan 25, 2017 at 4:25 PM
    #9045
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Any simple way to figure out why my house is always so.. wet? Every morning the upstairs windows are completely covered in moisture, not hazing - actual drops, like someone sprayed the window with a bottle. Also have the accompanying mildew issues in the window frame channels. I don't have central air, windows are newer double pane vinyl retrofits.
    Even the sweep on the front door has drops on it each morning, downstairs and away from a room of sleeping humans.
  6. Jan 25, 2017 at 4:29 PM
    #9046
    Frkypunk
    Timmy
    Woods of P.A.
    High moisture content could be a variation of things. New construction, strippers running out of the hot tub in your living room;)
  7. Jan 25, 2017 at 4:29 PM
    #9047
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Does your attic condensate heavily? How is the intake and an exhaust air of your house? Does this happen in winter months only?
    Vapor diffusion—moisture permeating through solid surfaces, such as cement, gypsum board, or wood.
    Do you take a lot of showers, do dishes or Laundry contributing inside moisture.
    Do you have a basement?
  8. Jan 25, 2017 at 4:33 PM
    #9048
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Do you use humidifiers? Or have any ventless propane logs? I know my windows will get wet on the inside when it's cold out and I run my fireplace or humidifier.
  9. Jan 25, 2017 at 4:37 PM
    #9049
    T4RFTMFW
    I don't believe so. I went up once last year looking for a leak, and don't remember any moisture issues there. We have lived here since Feb/March 2015 and it's been a problem every winter.
    No central air of any kind, no attic fan, moisture escapes out of windows only or a bathroom fan (in our showerless half bath..) that's vented outside. Range hood is not vented outside.
    We don't have a fireplace or use a humidifier. I've been looking at dehumidifies, but they're spendy. Likely will experiment with some Damp Rid next fall/winter when the weather dictates closed windows, as its cheap and effective.
  10. Jan 25, 2017 at 4:40 PM
    #9050
    T4RFTMFW
    Worth noting I live in a townhome and share a wall with a single story unit to one side and an identical two story unit to the other side, which we also share a roof with, and I've not seen any issues with moisture on the windows of their top or bottom floors, or any others in my development.
    Seems to be just a problem I am experiencing.
    Windows and home construction are all otherwise identical.
  11. Jan 25, 2017 at 4:42 PM
    #9051
    IPNPULZ
    going to be fun!
    What part of the country are we talking about?
  12. Jan 25, 2017 at 4:47 PM
    #9052
    Frkypunk
    Timmy
    Woods of P.A.
    Is there a garage below you? Just asking, because if your garage is below your living space it may create this problem.
  13. Jan 25, 2017 at 4:52 PM
    #9053
    T4RFTMFW
    Santa Rosa CA.
  14. Jan 25, 2017 at 4:52 PM
    #9054
    T4RFTMFW
    Garage is detached.
  15. Jan 25, 2017 at 4:54 PM
    #9055
    IPNPULZ
    going to be fun!
    Have you check the RH Relative humidity at each level?
    Do you have single or double pane windows?
  16. Jan 25, 2017 at 4:57 PM
    #9056
    IPNPULZ
    going to be fun!
    Household moisture sources
    Moisture source Estimated amount (pints)
    Bathing
    tub (excludes towels and spillage) .................................................. 0.12/standard size bath shower (excludes towels and spillage) ........................................... 0.52/5-minute shower
    Clothes washing (automatic, lid closed, standpipe discharge)..........0+/load (usually nil)
    Clothes drying
    vented outdoors ................................................................................. 0+/load (usually nil)
    not vented outdoors, or indoor line drying ................................... 4.68 to 6.18/load (more if gas dryer)
    Combustion (unvented kerosene space heater)....................................7.6/gallon of kerosene burned
    Cooking
    breakfast (family of four, average) .................................................. 0.35 (plus 0.58 if cooking with gas) lunch (family of four, average).........................................................0.53 (plus 0.68 if cooking with gas) dinner (family of four, average).......................................................1.22 (plus 1.58 if cooking with gas) simmer at 203°F, 10 minutes, 6-inch pan .......................................less than 0.01 if covered, 0.13 if
    uncovered
    boil 10 minutes, 6-inch pan ..............................................................0.48 if covered, 0.57 if uncovered
    Dishwashing
    breakfast (family of four, average) ..................................................0.21 lunch (family of four, average).........................................................0.16 dinner (family of four, average).......................................................0.68
    Firewood storage indoors (cord of green rewood) ............................ 400 to 800/6 months
    Floor mopping...........................................................................................0.03/square foot
    Gas range pilot light (each)......................................................................0.37 or less/dayHouse plants ( ve to seven average plants) ......................................... 0.86 to 0.96/day Humidi ers................................................................................................0 to 120+/day (2.08 average/hour) Respiration and perspiration (family of four, average).......................0.44/hour (family of four, average) Refrigerator defrost...................................................................................1 .03/day (average)
    Saunas, steambaths, and whirlpools......................................................0 to 2.7+/hour
    Combustion exhaust gas backdrafting or spillage...............................0 to 6,720+/year
    Evaporation from building materials
    seasonal ............................................................................................... 6.33 to 16.91/average day new construction................................................................................10+/average day
    Ground moisture migration .................................................................... 0 to 105/day Seasonal high outdoor humidity ............................................................ 64 to 249+/day
    T4RFTMFW likes this.
  17. Jan 25, 2017 at 4:59 PM
    #9057
    T4RFTMFW
    Dual pane. Haven't done any kind of checking.. just not sure we are breathing out or cooking so much moisture that the windows and sills are soaked every morning.
    We sleep with the bedroom door closed, it's myself, my fiancée and daughter and our dog. So, I'd expect some level of condensation in the morning but not the drenched window. The other upstairs windows are heavily condensated also, so I don't think it's all escaping underneath the bedroom door and going everywhere else.
    The extent of my curiosity so far has only led me to this thread and some head scratching.
  18. Jan 25, 2017 at 5:02 PM
    #9058
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    Is it newer construction? Might be worth leaving a couple windows cracked open a few nights to see if the problem is there in the morning, just to see the house is buttoned up too tight. Some newer construction buttons things up so much the house can't breath.
    truchador likes this.
  19. Jan 25, 2017 at 5:09 PM
    #9059
    T4RFTMFW
    I believe it was built in the early 1970s as apartments, then converted and updated in the mid or late 1990s.
    We have cracked the master bedroom window a few times and there wasn't much difference in condensation IIRC. No problems except for in winter, we rarely run a heater in the bedroom, so there really isn't a large variance in outdoor/indoor temperatures and also no difference in a 20 degree dry night or a 40 degree rainy night. Still comparable each morning as far as condensation goes.
  20. Jan 25, 2017 at 5:12 PM
    #9060
    IPNPULZ
    going to be fun!
    Indoor air or vapor is getting trapped as air is not moving
