Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jan 25, 2017 at 5:51 PM
    #9081
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not the 2 story unit adjacent to me.
    If you cut our unit in half, they're mirrored but identical.
  2. Jan 25, 2017 at 5:52 PM
    #9082
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Got to use my new mini palm nailer today , works awesome for nailing inside this 6" concrete wall form
    rob1208, 98tacoma27 and pudge151 like this.
  3. Jan 25, 2017 at 5:52 PM
    #9083
    T4RFTMFW
    It's slightly worse in the master bedroom, but the second bedroom window has the same condensation issue and is unoccupied. It's on the second story as well, and the 2 closets of the bedrooms share a wall. Otherwise the windows are separated by 2 doors and 30-35 feet.
  4. Jan 25, 2017 at 5:53 PM
    #9084
    T4RFTMFW
    Neither. Built on a slab.
  5. Jan 25, 2017 at 5:54 PM
    #9085
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Do you have any roof turbines?
  6. Jan 25, 2017 at 5:55 PM
    #9086
    OZ-T
    Peter North
    British Columbia
    Are you sure they are thermopane windows ? ie you can see 2 pieces ( or 3 ) of glass with an air space between the panes ?
  7. Jan 25, 2017 at 5:56 PM
    #9087
    OZ-T
    Peter North
    British Columbia
    Agree no vapour barrier under the slab is likely in an old house and could lead to excess interior moisture drive towards the heated space
  8. Jan 25, 2017 at 5:57 PM
    #9088
    T4RFTMFW
    Negative.
  9. Jan 25, 2017 at 5:58 PM
    #9089
    T4RFTMFW
    I can take a pic of the window.. I assumed they're double pane as they have those white vinyl strips running through the inside of them.
  10. Jan 25, 2017 at 5:58 PM
    #9090
    OZ-T
    Peter North
    British Columbia
    Any roof vents ?
    Ie roof pots or continuous ridge venting ?
    Gable vents ?
  11. Jan 25, 2017 at 6:00 PM
    #9091
    T4RFTMFW
    I know they're not single pane glass windows, anyway..
  12. Jan 25, 2017 at 6:01 PM
    #9092
    T4RFTMFW
    I can't see the upper roof hardly at all, but plan to be in the attic sometime this weekend and can look at what kind of venting is used.
  13. Jan 25, 2017 at 6:12 PM
    #9093
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    On mine, I track how much it's costing me to heat my house day/week/month helps with figuring out what works and what doesn't.
  14. Jan 25, 2017 at 6:35 PM
    #9094
    OZ-T
    Peter North
    British Columbia
    Yeah those are thermopane
    T4RFTMFW[QUOTED] likes this.
  15. Jan 25, 2017 at 6:55 PM
    #9095
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    I use one of those for hay loft joist hangers in pole barns. Makes quick work of Teco nails.
  16. Jan 25, 2017 at 7:02 PM
    #9096
    T4RFTMFW
    Thanks for confirming. :bananadead:
  17. Jan 25, 2017 at 7:26 PM
    #9097
    OZ-T
    Peter North
    British Columbia
    Yeah I used to use a palm nailer for hangers now I have a hardware nailer
  18. Jan 25, 2017 at 7:30 PM
    #9098
    horstuff
    horstuff Re-member
    PNW
    Better yet.
  19. Jan 25, 2017 at 7:32 PM
    #9099
    OZ-T
    Peter North
    British Columbia
    I mostly use palm nailers for formwork now
  20. Jan 25, 2017 at 7:33 PM
    #9100
    horstuff
    horstuff Re-member
    PNW
    More for hard to reach than just elbow saver, eh?
