Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. May 29, 2017 at 3:52 PM
    krap22
    krap22 Well-Known Member
    Made good process this weekend thanks to some help from my dad.
    scocar, cmack, pudge151 and 9 others like this.
  2. May 29, 2017 at 4:42 PM
    krap22
    @HomerTaco all the wood so far is from home depot!
  3. May 29, 2017 at 4:48 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Got the best deal from Home Depot when I ordered the lumber package for my house. It was all kiln dried Douglas Fir too. It was hard on my drywall guns though, stuff is hard!
    scottalot likes this.
  4. May 29, 2017 at 7:57 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :thumbsup:
  5. May 30, 2017 at 6:33 AM
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    Stihl. I'm not sure how much trimming you do, but I would consider a commercial Stihl trimmer. Thats what I did and I've had mine for over 10 years I believe.
    markm0311, wilcam47 and scottalot like this.
  6. May 30, 2017 at 7:04 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Another vote for Stihl. Ran them commercially for about 6 years and never had a failure. Still use one of my original trimmers from 2002 at my house weekly.
  7. May 30, 2017 at 7:05 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I got the one with a brush cutter blade, it does good with brush up to about 3/4". The weed eater part works great too.
  8. May 30, 2017 at 7:12 AM
    PB65stang
    Patrick
    Kansas City
    Looking for ideas on how to fix subfloor squeaking. As I've posted on here, we are currently having wood floors installed. In our lower level (crawl space accessible), I have about a 10x10 area that is very squeaky even after the new floors are in. I did the best I could prepping the subfloor before the floor guys got there, then they prepped it, then they have also driven trim screws through the floors after install to try and quiet this area up, but it’s still super noisy. I am pretty confident that everything from the top side is as solid as could be at this point. So, I’m going to try to attack this from below and wanted to get ideas from people that have dealt with this before. My current plan is to run 2x10 blocking across the joists (16” on center, but long spans) to see if that helps some deflection, and then run construction adhesive along every joist/subfloor seam to try and limit any movement from below. At this point, that seems to be all I can do, because I know the subfloors are more than adequately screwed down into the joists from above. Does this sound like a good starting point? Anyone else have any other suggestions? The new floors look amazing and the guys are doing a great job, but this is all I can focus on and it’s taking away from my satisfaction with the new floor.
    theredofshaw likes this.
  9. May 30, 2017 at 8:45 AM
    krap22
    My other thought besides the blocking would be to put some pocket screws from the joists into the subfloor.
  10. May 30, 2017 at 9:10 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    These might help
    http://www.essentialhardware.com/si...m_medium=cpc&gclid=CIfenseAmNQCFRGBswodQT8DnA
    Hopefully your subfloor is glued to the joists
  11. May 30, 2017 at 9:18 AM
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    Another +1 on Stihl. I have the FS 56 RC-E and have never had an issue. There is not another thing more frustrating than needing to fix your weedeater before using it.
    markm0311 and scottalot like this.
  12. May 30, 2017 at 11:16 AM
    PB65stang
    Patrick
    Kansas City
    Looked into bridging, but everything I read says blocking is stronger. But a good option possibly. Also, my subfloors are glued and nailed. I just wonder if some of the glue is failing a little. Guess we will give it a go and see what happens.
    scottalot and truchador[QUOTED] like this.
  13. May 30, 2017 at 11:50 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Stihl, I wont buy any other brand of equipment.
    scottalot and markm0311 like this.
  14. May 30, 2017 at 12:17 PM
    beachingtaco
    beachingtaco "We have assumed control"
    Long Island, new york
    2012 DCLB trd sport
    westin nerf bars, ARE in-channel visors, Wet Okole's, mobtown tailgate skin, Tail Gate theft mod
    i'm no professional carpenter here but if you know the thickness of all of the floor material, including the subfloor and you have access underneath, couldn't you just put deck screws in from below? Would pull the hardwood, subfloor and everything in between together and screws wouldn't back out on ya......(if your subfloor is solid)
  15. May 30, 2017 at 12:42 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Ever needed a condom and not had one?
  16. May 30, 2017 at 12:56 PM
    PB65stang
    Patrick
    Kansas City
    The issue isn't the floor to subfloor, it's the subfloor to joist. It made the noise before the new floors were installed and after, and they're nailed in like crazy, so I know the floors are solid. I just have to find what's causing the subfloor to joist noise.
  17. May 30, 2017 at 1:20 PM
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    No matter what you get it's nice to have the whole lineup like blower, wacker, chainsaw, whatever and only have to use one jug of pre-mix. I got one jug for my mower of straight gas and one jug of 50:1 mix for all my Sthil stuff. Makes life simple.
    Cuffs and scottalot like this.
  18. May 30, 2017 at 1:21 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sister 2x4's onto your joists , up against the subfloor , put PL Premium on the upper side and the side that will contact the joist prior to installation , screw or nail in place
  19. May 30, 2017 at 1:25 PM
    OZ-T
    Peter North
    British Columbia
    Check that there are no shiners , ie nails or screws that were driven through the subfloor into the joists originally but skimmed off the edge of the joist , the subfloor moving up and down on the fastener shank can cause a squeak , pull them through the bottom if possible
  20. May 30, 2017 at 1:30 PM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    It can be several different issues. I have successfully used Jack Posts (sometimes called foundation jacks) and blocks to provide a slight lift/pressure to the bottom of a floor joist in an older building of mine (1920s house). I ran them roughly on 4' centers and added blocking in areas that had greater than 10' span between the original foundation's load points.
