Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jul 8, 2017 at 2:57 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Kolunatic, Drainbung, TK-422 and 2 others like this.
  2. Jul 8, 2017 at 3:25 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I think 4 lag bolts would be fine as long as they are centered on the studs. You could use the plastic anchor nuts for the two additional. I think they hold an additional 45Lbs pull or 90Lbs down each.
    Nickel likes this.
  3. Jul 8, 2017 at 4:08 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Is there strength difference....yes. All depends on what grade of stainless and what grade of the zinc plated you are going for. For a ~100lb TV with 4 lag bolts....i wouldnt worry about it to much though. I like stainless for the look better and for four of them its not to costly.
    Caligula[QUOTED] likes this.
  4. Jul 8, 2017 at 4:58 PM
    krap22
    krap22 Well-Known Member
  5. Jul 8, 2017 at 5:12 PM
    Justified
    Justified Well-Known Member
    Wayne
    Nevada
    2023 MGM 4x4 TRD Off Road
    The deck is coming right along nicely. I was lazy today but it's 114 and humid here.
  6. Jul 8, 2017 at 5:15 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Thats hot.
  7. Jul 8, 2017 at 5:23 PM
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    20k worth of ipe showed up Friday, thankfully it stopped pouring rain as soon as the driver left...
    Nickel likes this.
  8. Jul 8, 2017 at 5:49 PM
    krap22
    Wow, How long are those boards?
    I didn't spend anywhere close to that.
  9. Jul 8, 2017 at 5:52 PM
    krap22
    Hell it was only 88 here, but it was fairly humid and no breeze. It got hot toward the end in the midday sun.
  10. Jul 8, 2017 at 6:09 PM
    joshua721
    16 f150 xlt v6
    20'
  11. Jul 8, 2017 at 7:50 PM
    krap22
    That's gonna be a big deck. Make sure to post pics
    1200+ sq ft?
  12. Jul 8, 2017 at 8:02 PM
    krap22
    Fridge kept freezing, so I put a separate thermostat on it to make sure it stops freezing.
  13. Jul 8, 2017 at 8:58 PM
    Caligula
    Los Angeles, CA
    New invention:
    Hot fog on a stick
  14. Jul 8, 2017 at 9:11 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I would not add extra anchors if you are in fact dealing with lath and plaster , drilling into that stuff between studs can open a serious can of worms with cracking , but if you do you should use a toggle anchor or something intended for lath and plaster
  15. Jul 9, 2017 at 9:19 AM
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    https://youtu.be/1GyryMMfXFI
    Also getting new wood floors installed after the foam injection Monday, so everything is ripped up.
  16. Jul 9, 2017 at 9:36 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    There's plywood subfloor or is it pier and beam house?
    scottalot likes this.
  17. Jul 9, 2017 at 9:47 AM
    Pistol Pete
    Eric
    Oklahoma
    Post tension concrete foundation with a moisture barrier/plywood/felt/4" red oak.
    scottalot and Kolunatic[QUOTED] like this.
  18. Jul 9, 2017 at 9:49 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Never seen that before.
  19. Jul 9, 2017 at 9:59 AM
    OZ-T
    Peter North
    British Columbia
    How is the plywood fastened to the slab ? With screws or powder actuated nails ?
    Do you know if there is a vapour barrier under the slab and is there insulation under it ?
  20. Jul 9, 2017 at 10:27 AM
    Pistol Pete
    Eric
    Oklahoma
    The plywood subfloor in combination with the felt layer between it and the flooring helps prolong the life of the wood floors by aiding in moisture resistance. It also helps reduce noise, keeps the floors warmer, works as a cushioning agent, allows for additional expansion and contraction and it allows for the wood flooring to be stapled down rather than glued.
    The plywood is attached with concrete screws.
    There is a moisture barrier between the plywood and concrete slab.
    Drainbung and Kolunatic[QUOTED] like this.
