Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jul 14, 2017 at 12:08 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Most units come pre-charged for a 25 foot line set
  2. Jul 14, 2017 at 12:09 PM
    IPNPULZ
    going to be fun!
    Not many it seems like
  3. Jul 14, 2017 at 12:11 PM
    IPNPULZ
    going to be fun!
    And I know for a fact to this day there are a few TH that are the same model as ours that have a 2 ton unit cheap fuckers were cutting corners....
  4. Jul 14, 2017 at 12:11 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    These arent even from the biggest mat ftg I have ever done. Still, it was pretty involved.
    mbarbay, joshua721, OZ-T and 4 others like this.
  5. Jul 14, 2017 at 12:15 PM
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    Good contractors are hard to find which is why I do so much of my own work. Never tried A/C work but considering installing a multi-zone mini-split. Might try to do all of the install except for the vacuum and fill. Anyone ever installed a multi-zone ductless mini-split?
    Cuffs likes this.
  6. Jul 14, 2017 at 12:17 PM
    scocar
    scocar Patron of the Farts
    Was that your SF job?
  7. Jul 14, 2017 at 12:24 PM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    Almost none...they come into the tracks and build for speed.
    If that's the case, that's my issue. I've got probably 25 feet of line in the attic alone for each unit lol
  8. Jul 14, 2017 at 2:39 PM
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    What brand is your unit? I had issues with mine last spring where it was low on refrigerant, and the evaporator coil had a leak. Turns out, there was a class action settlement and Lennox had to provide a new coil and replacement refrigerant. I was out the labor cost for the service call and installation after everything was all said and done.
  9. Jul 14, 2017 at 3:02 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    My buddy is going through the same thing right now I believe.
    Pistol Pete[QUOTED] likes this.
  10. Jul 14, 2017 at 3:07 PM
    Justified
    Justified Well-Known Member
    Wayne
    Nevada
    2023 MGM 4x4 TRD Off Road
    I hate to have to make sure the concrete gets consolidated. I'll have to look for pictures.
    Edit Picture: Not a big mat but 36" deep. I'll try and find a better project picture.
    Drainbung and Nickel like this.
  11. Jul 14, 2017 at 4:05 PM
    IPNPULZ
    going to be fun!
    Is that the Start of the new Border wall along Mexico?
  12. Jul 14, 2017 at 4:09 PM
    scocar
    When I was looking into mine, I found similar suit against Trane (my brand for one unit), and it was relatively new. Pinhole leaks, etc.
  13. Jul 14, 2017 at 4:15 PM
    Justified
    Wayne
    Nevada
    Close. It's the start of a tunnel.
    Caligula likes this.
  14. Jul 14, 2017 at 4:16 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    I was guessing the unit is either undersized or even oversized for the home. There's always the possibility of loose fittings, not enough charge, or leaks like the others have mentioned as well
  15. Jul 14, 2017 at 4:19 PM
    SilverBullet19
    Scott
    Sacramento County
    That sucks...mine is under warranty through my builder. So if is anything other than an issue related to normal use, it's on them. I've only owned the house 3 months, so there's very little they can try to pin on me.
    Mine is Goodman, it appears the evaporator coil itself is ADP.
    I contacted the builder and they gave me a company to contact locally. It's their subcontractor, and it seems to have a decent rep. Since its not the building company coming directly, I feel I'm less likely to get the runaround, like trying to blame me for the issue or trying to charge me. The outside company just wants to get paid, doesn't matter to them if the builder has to cough it up.
    I say that because we had a door handle break internally. When we did the walk through, I noted it was "notchy" when turning the handle, and the builder agreed. When it finally broke and I couldn't open the door, the guy came out to fix it. Had to order a part, builder's email was "It seems it broke from being slammed repeatedly, we will still cover it, however." Came off as "your fault but I GUESS we will fix it."
    EDIT:
    Both units are the same, 3 ton units. Given our climate, thats good for roughly 3000-3600 sq feet, in total if both are running. We are ~3040 sq feet. Not sure on design temp, honestly.
  16. Jul 14, 2017 at 4:29 PM
    Pistol Pete
    Eric
    Oklahoma
    My ac guy mentioned that they stopped installing trane because of all warranty work they were having to do.
    SilverBullet19 likes this.
  17. Jul 14, 2017 at 4:38 PM
    SilverBullet19
    Scott
    Sacramento County
    When I did a walk through at this place, I called my brother to inquire about the Goodman brand. He told me they're decent and when they have issues it's usually a cheap, generic part. Which is nice.
  18. Jul 14, 2017 at 5:32 PM
    scocar
    Yay me. The 2-year-old AC is having more issues than the other 19-year-old unit. Seems OK for now.
  19. Jul 14, 2017 at 5:35 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    So, what brand of A/C is a good one? My unit is 15 years old and wonder how long it will last :notsure: Current one is a Trane - was supposed to be a good brand and I've only had one issue with it. Had the builder put this in, instead of the cheapo one they were gonna use. I do still see a lot of the cheapo ones in the neighborhood.
  20. Jul 14, 2017 at 6:07 PM
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    Got the barney board up in the shower today, getting ready for the fat mud, then tile. Also ran some electrical. Hope to finish that tomorrow. Set the throne in place to make sure the holes line up... so far so good.
    Nickel and pudge151 like this.
