Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jul 27, 2017 at 4:34 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Yeah....I was being sarcastic....
  2. Jul 27, 2017 at 4:57 PM
    scocar
    scocar Patron of the Farts
    Ah. I thought that a bit odd coming from you. Please use the sarcastic font in the future.
    Caligula and phillstill like this.
  3. Jul 27, 2017 at 5:29 PM
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
  4. Jul 27, 2017 at 9:42 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    I never understood the need for radiant floor heating in bathrooms. Is a cold tile floor that much of an issue to need a heating system for it? Just sayin'
    SilverBullet19 and scottalot like this.
  5. Jul 28, 2017 at 6:25 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    No you wouldn't, you live in LA.
  6. Jul 28, 2017 at 7:11 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    We put radiant heating throughout most of the houses I build
    Caligula[QUOTED] likes this.
  7. Jul 28, 2017 at 9:31 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Why have cold feet when you don't have to? Do you use AC in your truck for comfort?
    SilverBullet19, Cuffs and Drainbung like this.
  8. Jul 28, 2017 at 11:30 AM
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    Invite 10 friends over and eventually could be today! Why wait?
  9. Jul 28, 2017 at 4:49 PM
    Caligula
    Los Angeles, CA
    People cant just put socks on? :notsure:
    la0d0g[QUOTED] and Drainbung like this.
  10. Jul 28, 2017 at 4:54 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    You don't seriously shower with your socks on, do you? o_O
    robssol, Cuffs, la0d0g and 3 others like this.
  11. Jul 28, 2017 at 5:09 PM
    Caligula
    Los Angeles, CA
    So im pretty much all done with my project. I still may remount the TV, it ended up about 3 inches higher than I wanted. Ill be picking up a sound bar soon, but for now i am pleased.
    I used 4 3" lag bolts on the studs and Hilti 1/4" Toggler anchors on the right. I replaced the included phillips head screws with 1/4" bolts. I had a 150lb asian guy hang from the mount, its solid.
    Patched the area and completed my hookups, so much cleaner now. Made all the ethernet cables myself with the Cat6 cable i found un the crawl space. Last pic i have from underneath.
    The other end of the ethernet port goes into the next room. I set up the old router as an access point for the new one, i can now get wifi in the bedroom.
    ALL HAIL PRESIDENT BANNON!
    I ran some speed tests before i started. I set the router to the same 802.11n signal as the old one, then ran some new tests. Over a 100mbps improvement! Not bad at all.
    Nickel, Drainbung, truchador and 2 others like this.
  12. Jul 28, 2017 at 5:13 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Is that a Netgear R6700?
  13. Jul 28, 2017 at 5:18 PM
    Caligula
    Los Angeles, CA
    R7000 with dd-wrt
    xJuice[QUOTED] likes this.
  14. Jul 28, 2017 at 5:46 PM
    Frkypunk
    Timmy
    Woods of P.A.
    I could do without that jackass on the TV....but glad you worked everything else out!
    Nickel and Caligula like this.
  15. Jul 28, 2017 at 6:17 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    I'm running the R7000 too (stock firmware). Blazing fast... Even for LAN traffic not involving the net.
  16. Jul 28, 2017 at 6:21 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    I feel like im living in a holmes on homes episode here. lets see if you guys can name everything wrong in these pictures. 20170728_210522.jpg20170728_430720.jpg
  17. Jul 28, 2017 at 6:27 PM
    Frkypunk
    Timmy
    Woods of P.A.
    No header above the door....possibly 2x4 exterior wall? Hammer from harbor freight.
  18. Jul 28, 2017 at 6:31 PM
    Gaunt596
    Matthew
    Central Maryland
    its a start, theres more
  19. Jul 28, 2017 at 6:32 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Was this a porch formerly?
  20. Jul 28, 2017 at 6:33 PM
    Gaunt596
    Matthew
    Central Maryland
    close, Open Carport
