Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Dec 13, 2017 at 7:22 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    we need you down here to fix our American Legion building...:)
  2. Dec 13, 2017 at 7:38 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Are they at 2 foot centers?
  3. Dec 13, 2017 at 7:48 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Added a brick accent wall to my basement (BTW I hate brick) came out OK but I need to lighten the color....gonna try lime washing it.61C19C57-5B7B-41B6-B099-66E73B5485B5.jpg
  4. Dec 13, 2017 at 7:59 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    really depends on its application. in this case it turned out good. some of the houses we looked at in the past though...holy crap, brick everywhere it shouldn't and even once in the bathroom :rofl:
    Toyko Joe likes this.
  5. Dec 13, 2017 at 8:08 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Brick is a dated thing....I needed to break it up in my basement and cover up a block wall. Hopefully I can lighten the red color, it’s the only thing that bothers me. If I can get it like the chimney I did it would be ok...if not...I will tear it out.E37BF232-BAEC-4DD3-A182-99D0578FF4FA.jpg
  6. Dec 13, 2017 at 8:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Joists ? Yes
  7. Dec 13, 2017 at 8:30 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Ouch!
  8. Dec 13, 2017 at 8:32 PM
    OZ-T
    Peter North
    British Columbia
    Meets current code for span and will get glued and ring nailed 3/4" ply with concrete topping
  9. Dec 13, 2017 at 8:39 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Do not understand the concrete part...but the rest I get. Do you mean concrete board or actual concrete?you can do 2x6 floor Joist at 2 foot..wow!
  10. Dec 13, 2017 at 8:52 PM
    OZ-T
    Peter North
    British Columbia
    2" of concrete over the subfloor , its getting hydronic heat throughout the house
    Drainbung and Toyko Joe like this.
  11. Dec 13, 2017 at 8:58 PM
    Frkypunk
    Timmy
    Woods of P.A.
    You can lay concrete over that! In the States they would shut us down.
    wilcam47 likes this.
  12. Dec 13, 2017 at 9:05 PM
    OZ-T
    Peter North
    British Columbia
    For what reason
  13. Dec 13, 2017 at 9:06 PM
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    They did that in the 70's/80' around here, put a little over an inch of concrete or "elasticil" or however its spelled. Right over the sublfoor
    Edit: Elastizell, apparently
  14. Dec 13, 2017 at 9:12 PM
    Frkypunk
    Timmy
    Woods of P.A.
    It would be the 2x6 floor joist.....I guess if you are putting a tng ply that would tighten things up...but I would say the weight you are adding they would want an engineered system in play. I am not criticizing just surprised you can do it. You have harsher coded than we do.
  15. Dec 13, 2017 at 9:15 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Right, in the 70s/80s.....we just got safety options too!
  16. Dec 13, 2017 at 9:15 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Isn't this a light weight material? The stuff we used was called Gyp-crete. It was light, like plaster of Paris. It weighed about the same as solid, 3/4" T & G hardwood flooring.
  17. Dec 13, 2017 at 9:16 PM
    Frkypunk
    Timmy
    Woods of P.A.
    Please tell me....am totally ignorant to concrete on wood framing.
  18. Dec 13, 2017 at 9:19 PM
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    No I got dibs on Oz work, building us a new (replacement) home! ;)
  19. Dec 13, 2017 at 9:20 PM
    koditten
    Kirk
    Central Michigan
    You just need something to create a heat mass for the floor heat. Concrete is the best, but like said is very heavy. The stuff we used years ago was light weight, but still have you a mass to hold the heat better than just plane wood.
    Radiant heat (tubes of hot water running thru the concrete) is one of the nicest heat types, but it does require some extra set up to be effective.
  20. Dec 13, 2017 at 9:23 PM
    Frkypunk
    Timmy
    Woods of P.A.
    I understand the heat part, more than, the part where you can do it over 2x6 floor joist spread out over a 2 foot span.
