Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Dec 19, 2017 at 5:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have a 60 gallon Campbell-Hausfield compressor. It has an automatic drain already equipped on the bottom.
    So I understand I should really be using the dessicant/oil remover combo for when I run a spray gun on an individual line?
    Toyko Joe, stairgod and wilcam47 like this.
  2. Dec 19, 2017 at 5:33 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That is correct.
  3. Dec 19, 2017 at 5:35 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Now I have a dinky little sandblaster from harbor freight circa 2002, it's the benchtop model. Should I worry about an air drier? I mainly use aluminum oxide/glass beads and garnet for really rusty stuff.
  4. Dec 19, 2017 at 5:35 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
  5. Dec 19, 2017 at 5:36 PM
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Nope
  6. Dec 19, 2017 at 5:37 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Do I need any kind of filter for just normal air tools? I can't figure out if I need that independent air filter or if I should return it.
  7. Dec 19, 2017 at 5:38 PM
    koditten
    Kirk
    Central Michigan
    Not really. You would have to do hours and hours of wrenching to make it worth while.
  8. Dec 19, 2017 at 5:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    When would using that air filter make sense?
    Kind of wondering it would be beneficial to painting if I used it in series with the air/oil separator combo.
  9. Dec 19, 2017 at 5:52 PM
    koditten
    Kirk
    Central Michigan
    Why? How is there going to be dirt if you have an air filter on intake of the compressor?
    You really only need a particulate filter if the air is going thru a desiccant dryer then to your spray gun. We've already decided that a desiccant dry won't gain you enough to pay for itself.
    Garentee you will get more contaminates in the paint from the shop atmosphere. This is why we wet sand when done. Lol.
    stairgod likes this.
  10. Dec 19, 2017 at 7:13 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Gotcha. I'll return the air filter then, lol.
    Thanks for your help guys.
  11. Dec 19, 2017 at 7:32 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    We got snowed out today , back at it tomorrow hopefully
    wilcam47, robssol and pudge151 like this.
  12. Dec 20, 2017 at 1:08 PM
    PHLinPHX
    PHLinPHX Well-Known Member
    Brian
    Bucks County, PA
    2023 Tundra CrewMax TRD Offroad 4x4 Limited
    Ok, electrical question for the day. House had a timer switch when I bought it that didn't work. Decided easiest thing would be to just replace timer switch and rewire same way. That did not work. Which means original switch might be fine also. Main question I have is why would someone wire black to white and white to black as pictured? Is there any reason for that? Any ideas on how to troubleshoot? I'm at a loss because everything else works fine. House was also completely original from when it was built in 1994 so I highly doubt the previous (original) owner screwed with anything. Pictures are hard to follow I know but hopefully helpful...
  13. Dec 20, 2017 at 1:18 PM
    corprin
    corprin Well-Known Member
    corprin
    Do you keep popping breakers?
    Where does the black-in-white line go? Is the object down stream wired backwards as well?
  14. Dec 20, 2017 at 1:22 PM
    PHLinPHX
    Brian
    Bucks County, PA
    Breakers are not popping. It's been like this for years I'm assuming. Don't know where it's going either
  15. Dec 20, 2017 at 1:26 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    If you did connect the black/white that are "backwards" does it have any voltage present?
    The black/white issue might be out to the fixture that is NOW hardwired that could have been wired through a switch originally, something like an outdoor light that is motion/light sensitive or a fixture that has its own controls on board like a ceiling fan with lights.
  16. Dec 20, 2017 at 1:27 PM
    PHLinPHX
    Brian
    Bucks County, PA
    Update: new switch came on. Couldn't tell you why exactly. I reset it and removed a jumper and wired directly to hot. Maybe that did it?
  17. Dec 20, 2017 at 5:10 PM
    Cuffs
    Cuffs Well-Known Member
    Lummi Island & Grand Canyon NP.
    2016 Inferno TRD OR 4x4 DCSB/2021 4R MGM Nightshade
    If I didn't know any better, and the fact that our house burned down, Id swear that was a box out of our house! Shit mess wiring every time I went to change a fixture...
    Toyko Joe, wilcam47 and Kolunatic like this.
  18. Dec 20, 2017 at 6:23 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    most wiring looks like that, that Ive seen...lol
    Cuffs[QUOTED] likes this.
  19. Dec 20, 2017 at 6:28 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    I wonder if they lost a hot wire and using the neutral as a hot wire?
  20. Dec 20, 2017 at 6:32 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    is it a two way switch? sometimes when the fixture has two switches that control it like stairway light switch at top of stairs and one at the bottom. one switch will have the white tied into black but should have electrical tape at the end of the white wire to let you know it is power.
    TacomaUSA, knayrb and Dustin28 like this.
