Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 16, 2018 at 9:29 AM
    scocar
    scocar Patron of the Farts
    This. I replaced a single crap flourescent on my 2 bay side. Had the fixture converted to a duplex outlet in the ceiling, and had 2 more duplexes installed in a row across the center of the ceiling. Bought a 6 pack of led shoplights off Amazon and mounted in a grid pattern to illuminate every dark, obstructed corner.
    Before:
    After, and this doesn't even do it justice because the camera darkened it:
    The third bay had higher ceilings with two tired double tube T8 flourescents. I just swapped led replacement tubes into this for now.
  2. Feb 16, 2018 at 10:15 AM
    PHLinPHX
    PHLinPHX Well-Known Member
    Brian
    Bucks County, PA
    2023 Tundra CrewMax TRD Offroad 4x4 Limited
    Nice. I ended up ordering a set of LED strips from Amazon too. I have one double door and one single. The single never had a garage door opener and the one light in the whole place was wired to where the outlet should go for that door. I changed that out to an outlet that is half controlled by the existing switch and then got lights that plug into each other so I'll only need the one plug. Installed a garage door opener last night that plugs into the always hot side of the outlet. Really didn't feel like crawling through the attic again....
  3. Feb 16, 2018 at 10:40 AM
    scocar
    Y
    yeah,
    the LED fixtures I got have linkable plugs too. I did not need to use them, but boy do they open up easy, inexpensive options and flexibility. And the low electric load maximizes that.
  4. Feb 16, 2018 at 10:47 AM
    PHLinPHX
    Brian
    Bucks County, PA
    I was originally going to hardwire in several new fixtures, but when I figured out that the builder ran the wiring needed for my garage sensors to that location already and I didnt have to go in the attic at all i decided to go the easy route. The lights were about $100. If I went with hardwired options I couldve got some for about $50, but then I have to buy wire, buy boxes, and perform the f-ing circus act that is balancing on the ceiling joists of my garage while climbing over all of the roof trusses. Last time I was in there running coax for cable install, my leg cramped up and I thought I was going through the ceiling.
    scocar[QUOTED] and Toyko Joe like this.
  5. Feb 16, 2018 at 10:49 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I got mine at Costco and Ive got them linked also. It was harder for me to put the lights up than the overall wiring. but they are working great, and if one does happen to go out someday I just replace it..
  6. Feb 16, 2018 at 12:21 PM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    If your joints are less than a inch thick I'd probably say it's polymeric sand. I just used stone dust since it's cheaper and I won't have to deal with cracking down the road. I also read the sand can leave a residue film over the the pavers or stones.
    ImpulseRed008 likes this.
  7. Feb 16, 2018 at 12:28 PM
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
    Thanks for the info.
  8. Feb 16, 2018 at 12:49 PM
    scocar
    I corrected my earlier post. I did NOT use the linking plugs. But now I can easily add more if I find I'm not sufficiently blinded by this setup.
    I paid an electrician to deal with the outlets. I have more money than time for this type of work now. The lights only came with hook hanging hardware, but I wanted them flushed mounted on the low ceiling. This made me think things through.
    The lights are very lightweight and can be single handed while wielding a screw gun atop a ladder. Screws with fender washers straight through the sheet metal shade and into joists made sense. But I needed everything to be perfectly prepped before climbing the ladder. I'll post pics with more info later.
  9. Feb 16, 2018 at 12:55 PM
    wilcam47
    Will
    Bourbon state
    m
    mine had hanging light hardware and slots for screws to flush mount. The difficult part was set up, but after they are in place they work great.
  10. Feb 16, 2018 at 1:36 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    There are certain things I hope I will never do again...
    • muddling drywall seams.
  11. Feb 16, 2018 at 6:10 PM
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    And 2 more waiting after this one.
    Drainbung, truchador, TK-422 and 2 others like this.
  12. Feb 16, 2018 at 6:13 PM
    su.b.rat
    su.b.rat broken truck
    Mark Mothersbaugh was my second choice of avatar. if it wasn't for the shift knob we would be twins. ok back to the gin..
    Championsumo likes this.
  13. Feb 16, 2018 at 7:13 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Whats going in where you have the plywood dummy ?
  14. Feb 16, 2018 at 7:50 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Glass block?
  15. Feb 16, 2018 at 8:52 PM
    OZ-T
    Peter North
    British Columbia
    Likely an accent tile , just wondering what it is
    wilcam47 likes this.
  16. Feb 17, 2018 at 3:30 AM
    fleckosaurus
    fleckosaurus Certified Toyota Enthusiast
    Brian
    Versailles, KY
    2024 Tundra
    Installed my first toilet ever. Getting closer to done with this bathroom.
  17. Feb 17, 2018 at 3:40 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    What’s the lotion for next to toilet? o_O
  18. Feb 17, 2018 at 3:53 AM
    fleckosaurus
    Brian
    Versailles, KY
    2024 Tundra
    you know
    phillstill and Kolunatic[QUOTED] like this.
  19. Feb 17, 2018 at 3:53 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    :anonymous:
  20. Feb 17, 2018 at 3:58 AM
    DrFunker
    DrFunker Well-Known Member
    Dry "legs". o_O
    Kolunatic likes this.
