Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 26, 2018 at 6:18 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Appreciate the concern, but this is the house I'm retiring in and the fireplace is not operable right now. It's blocked off by a thick piece of rigid foam (painted black) that's wedged into the opening. Can't even tell it's there when doors are closed. Doors are 100% decorative. In the event I were to use the fireplace, I'd install an insert (wood or pellet).
    I have a dual flue chimney (furnace & fireplace) that's capped with a stainless steel cap...so no moisture is getting down there.
    if I were to sell, I'd remove both.
  2. Mar 26, 2018 at 6:57 AM
    Sig45
    Mark
    Maine
    I've considered one of those electric heaters that resemble a small woodstove. Would simply place on the hearth and use during those really cold spells...just to take the chill off. Purely supplemental & asthetic.
    scottalot[QUOTED] likes this.
  3. Mar 26, 2018 at 7:07 AM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
  4. Mar 27, 2018 at 6:13 AM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
  5. Mar 28, 2018 at 4:34 PM
    Manwithoutaplan
    ID
  6. Mar 28, 2018 at 5:06 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Has anyone gotten concrete counter tops? My current kitchen has tiles (4"x4" ish) and its getting a bit annoying so looking at other options. Kind of wanting to keep it on a budget as we are only planning on staying in the house two more years.
    wilcam47 likes this.
  7. Mar 28, 2018 at 5:35 PM
    theredofshaw
    Trying to remember who but think someone here did do it for a laundry room countertop as a trial run.
  8. Mar 28, 2018 at 5:43 PM
    AKSig88
    AKSig88 Well-Known Member
    Ann Arbor, MI
    2023 SR5 Tundra
    www.concretecountertopsolutions.com
    A co-worker of mine used this and his countertops turned out phenomenal, I have his left over material to do a laundry or bathroom. Worth checking out!
  9. Mar 28, 2018 at 5:47 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Kind of funny but thats the "system" Ive been looking at....if i do it myself.
    AKSig88[QUOTED] likes this.
  10. Mar 28, 2018 at 5:54 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Check out Instructables. Several Concrete desks on there I saw in the past, should be same concept.
  11. Mar 28, 2018 at 5:54 PM
    AKSig88
    Ann Arbor, MI
    2023 SR5 Tundra
    It's pretty awesome, I've seen the results firsthand and couldn't reccommre it enough. Just post about it if you go for it!
  12. Mar 28, 2018 at 6:16 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Glad to hear you (and they) like it! I havent found anyone locally that I know who has done it.
    Its definitely something Im thinking I would like...just a matter of deciding if its worth the cost. Both a good thing and a bad thing (when thinking of redoing them) is the fact it would be 64sq ft of counter top without any extra. Plus would mean a new sink too.
  13. Mar 28, 2018 at 6:32 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Question for you.... son moved into a brand new house last July, so 8 months ago, and his garage floor is cracking, even going through the grooves they put in. How worried should he be? Thanks for any inputs.
  14. Mar 28, 2018 at 6:43 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Depends on the size of cracks. Some cracking is fine, but I don't know any specifics on amount/size that constitutes worry.
  15. Mar 28, 2018 at 6:46 PM
    ImpulseRed008
    Susan
    SC
    I'll take some pics next time I go up there.... I'd worry about the number of them and some of them, the floor isn't "smooth" anymore - has shifted a little on one side of the crack
  16. Mar 28, 2018 at 6:59 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    There are only 2 kinds of concrete .
    Concrete that has cracked and concrete that will crack .
    If by grooves you mean the control joints , it is supposed to crack there , that's why they are there
  17. Mar 28, 2018 at 7:02 PM
    ImpulseRed008
    Susan
    SC
    At what point is it too much cracking? Yes, the control joints, but it's not cracked along there, but like a 90* right through it
  18. Mar 28, 2018 at 7:07 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    when your 10mm socket rolls in the crack you know its too much...;)
  19. Mar 28, 2018 at 9:16 PM
    OZ-T
    Peter North
    British Columbia
    If there is differential settling I would be concerned ( ie slab sections at different heights ) .
    Control joints can be ineffective if too shallow , too far apart or the slab is constrained by other obstacles that don't allow for shrinkage
  20. Mar 28, 2018 at 10:46 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
