Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 13, 2018 at 12:39 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    we got a killer deal on the house, below market value and its a blank canvas. Owner was the original owner who bought it brand new when it was built. Inspection was yesterday and went over great so next step is waiting for the title company to tell me to come in and pick up my keys.
    Immediate plans are scrape ceilings, knock down wall between kitchen/dining and living room and installing a beam for load bearing. Can lights throughout and paint.
    scocar[QUOTED] likes this.
  2. Jun 13, 2018 at 12:42 PM
    scocar
    scocar Patron of the Farts
    Open plan improvements are very attractive. When was it built? What came up on inspection?
    LTDSC[QUOTED] likes this.
  3. Jun 13, 2018 at 12:43 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I remember @joshua721 had some input on the Kerdi vs Wedi subject.
  4. Jun 13, 2018 at 12:43 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Was built in 1973.
    Only "marks" on the inspection were missing GFCI's in the kitchen/bath. Otherwise he said it looks great. He also mentioned to get my breaker box swapped ASAP, is an old Zinsco...which will also be an immediate fix.
    scocar[QUOTED] and Drainbung like this.
  5. Jun 13, 2018 at 2:06 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I might weld up some metal for a mount for the side of the deck, shouldn’t be too hard, just some flat with a piece of pipe welded to it. Then find a pole (maybe black iron pipe) and get some online quotes for a custom shade sail.
  6. Jun 13, 2018 at 3:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Schluter and Wedi systems create a waterproof enclosure
    Drainbung likes this.
  7. Jun 13, 2018 at 4:17 PM
    PHLinPHX
    PHLinPHX Well-Known Member
    Brian
    Bucks County, PA
    2023 Tundra CrewMax TRD Offroad 4x4 Limited
    Doesn't cement board or densshield with the appropriate tape and sealers provide a waterproof enclosure for a lot less money? Are you paying a premium for ease of use?
  8. Jun 13, 2018 at 4:39 PM
    scocar
    Nice. Yeah, I had a Zinsco come up on my current house. I had an electrician come out to inspect it specifically after that, and he found no signs of corrosion on the aluminum bus bars, or other signs of arcing, overload or wear, and breakers were all sound. Plus it was huge, 400A, and there was a newer subpanel inside the house (Square D). It is embedded in stucco, too. We hemmed and hawed over it, and he finally said, if it were his house, he would leave it alone.
    Sooooo, before you dump that money, and if you have adequate capacity in it, might want to get an actual electrician out to look at it first for a second opinion. Just a thought.
    T4RFTMFW and LTDSC[QUOTED] like this.
  9. Jun 13, 2018 at 4:40 PM
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    If your time doesnt cost anything then yes.
    You could just paint redguard on fiberboard and call it it good. Wedi and kerdi take alot less time to install and also eliminate the areas that are more likely to cause failures. It's simple, easy to install and bulletproof for anyone with half a brain.
    OZ-T and Drainbung like this.
  10. Jun 13, 2018 at 4:42 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    This one is tiny. But I plan to do the same, have someone come out and look at it and give me a full report. Although after what I’ve read about them it will always be in the back of my mind before I go to sleep every night.
  11. Jun 13, 2018 at 4:44 PM
    PHLinPHX
    Brian
    Bucks County, PA
    Thank you. That's exactly what I was wondering. So for a homeowner who's pretty good at tiling and has done a few showers with backer board, it probably wouldn't pan out as worthwhile to use wedi or kerdi. No time crunch. Multiple bathrooms so i could spend a month tiling and not care.
  12. Jun 13, 2018 at 4:45 PM
    joshua721
    16 f150 xlt v6
  13. Jun 13, 2018 at 4:47 PM
    scocar
    Yeah, I forgot about it after I spent 14k on a new heater/AC this past winter, showering sparks out of a shorted ceiling fan in the office, replacing the washing machine supply valves and the garage drywall over those, the broken fridge, two broken garage door springs, the dryer box and vent system repairs and upgrades (complete with contractor sticking his foot through my ceiling), adding insulation up to code in half the house above the bedrooms, lots of irrigation fuckery, and rebuilding the kitchen sink drain system. That was all since last May.
    But I'm not bitter.
    Edit: oh yeah, and remounting the door hinges in one bedroom, replacing pocket door handles in three rooms, and I'm sure some other shit I'm forgetting. None of that was one the list at the time of purchase. Shit just starting breaking at a phenomenal rate. 1986.
  14. Jun 13, 2018 at 4:53 PM
    joshua721
    16 f150 xlt v6
    I think both wedi and kerdi ste far superior to anything else. But a well built drypack over a leadpan still works to. It's about time. Wedi panels are light and easy to work with and both wedi and kerdi can be used th o do things I wouldn't attemp with other systems. The mistake alot of people make is thinking that tile and grout are waterproof. They are not. I'll be using wedi in my home, and if you find a local supplier you might be surprised at no marked up price.
  15. Jun 13, 2018 at 4:58 PM
    PHLinPHX
    Brian
    Bucks County, PA
    Speaking of irrigation fuckery... Asked some questions on here a few months ago and here's the result. Been working outside the past few months to beat the Phoenix summer heat - new sprinklers, landscaping clean up and painted the house. Pics before during and after. Amazing what a little water can do in the desert.
    F89F0307-8855-4545-8764-E15A3F063B19.jpg47064341-B8D3-44B6-98BC-D523B2608867.jpg27212740-0331-4C24-AC00-1C44BB906F2A.jpg52884C94-B8DB-4432-8A54-C124C2EA3CA9.jpgBD310FE4-891C-4BCD-8A1C-CE05D2DF4EAC.jpg18306540-2BB6-4DCB-9365-B81BA6F04404.jpg5C931EC6-F3EC-4F85-BD28-6025FCE07E5D.jpgD3A0D552-672D-4E1F-8781-F34CC54DE057.jpg987F2205-D19E-4F1F-963E-5BFA13FCEB98.jpgB2F2B22B-7BC9-40B3-9644-A91D3C240603.jpg4B27FCE7-8604-482F-9B12-01BBBBBFFAD7.jpgEDC5933B-D036-4C87-A0E0-D6F6A73E0660.jpg
  16. Jun 13, 2018 at 5:05 PM
    PHLinPHX
    Brian
    Bucks County, PA
    The only price I found for wedi was over $300 for a shower kit. I could do the same tub surround for under 100 with backer. Kerdi rolls were a little more reasonable but I would have to put drywall under them after I tear out the existing cultured marble slab walls, right? Thats still significantly more than cement fiber board. What I'm looking into now is densshield which seems reasonably priced, easy to work with (lightweight, can score with razor, have to waterproof the seams and screw holes). Do you have any experience with that? Are kerdi/wedi that much cheaper from a supplier?
  17. Jun 13, 2018 at 5:33 PM
    OZ-T
    Peter North
    British Columbia
    Can do , partially
    Schluter and Wedi are systems that ensure a totally waterproof substrate for tile , you can get close to that with other products used in combination
  18. Jun 13, 2018 at 5:35 PM
    308savage
    Adam
    East Tennessee
    robssol likes this.
  19. Jun 13, 2018 at 5:45 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Check your local hardware stores (small box). OSH around here (SoCAL) sells sunshade material by the yard at about a 6' width in your choice of 3 colors (tan, black, and green). I fired up the sewing machine and sewed two panels together to get full coverage on my small patio (12'x12'). Used small bits of canvas in the corners for grommet reinforcement and have a DIY sunshade in the correct size for around $15 and a little time and effort. I even got a couple yards of black to use as an awning for the truck with some tent poles. Beats paying for an ARB.
  20. Jun 13, 2018 at 5:53 PM
    PHLinPHX
    Brian
    Bucks County, PA
    Costco also sells these cheap. I picked up a 13 x 7 sail for about $20. Haven't hung it up yet. Bonus is lifetime returns if it eventually fails.
