Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 22, 2018 at 8:33 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    They did a really neat job , I was impressed
  2. Jun 22, 2018 at 8:41 PM
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    We had some old TNG redwood fence pickets set aside and my GF needed a planter, so I threw this together this morning.
  3. Jun 22, 2018 at 9:07 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Heated floors? Fancy!
  4. Jun 23, 2018 at 5:44 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Its always fun looking at a pro's (or someone who takes time) layout vs the DIYer who just slaps it together.
  5. Jun 23, 2018 at 7:34 AM
    916carl
    Carl
    Lol. I put heated floors in my bathroom, however they are electric. I had scheduled the tile guy for a Monday, figuring I'd have the weekend to methodically lay out the wires and set them with a little hot glue (I used a wire brand different than the mat manufacturer's so it didn't snap in as well). He calls on Friday morning and wants to come over and start tiling that day as his jobs got moved around. It was a mad scramble to get the wires down and it was not the way I wanted to get it done, but it worked out in the end.
  6. Jun 23, 2018 at 10:29 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Does the tile go directly over that?
    scottalot likes this.
  7. Jun 23, 2018 at 10:35 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Yes. I did this at my cabin last year. You just put the thin-set right over it and lay the tile on top. Works great. It takes a while to heat the floor up so it isn't the type of thing you turn on and off frequently. Once you turn it on, you want to leave it on like on for a while.
    scottalot and robssol[QUOTED] like this.
  8. Jun 23, 2018 at 1:24 PM
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    I might have a stroke.
  9. Jun 23, 2018 at 1:42 PM
    916carl
    Carl
    As mentioned, they just tile right over it. Mine doesn't take very long to heat up, maybe 10 minutes? I turn it on when I get in the shower and it's usually warm when I get out. There's also a timer, so you can set it to come on at a regular schedule.
    Drainbung and scottalot like this.
  10. Jun 23, 2018 at 2:06 PM
    OZ-T
    Peter North
    British Columbia
    The Ditra Heat is an uncoupling membrane like standard Ditra and Ditra XL , you tile right over it either as is or after prefilling it with thin set and then tiling
  11. Jun 23, 2018 at 2:07 PM
    OZ-T
    Peter North
    British Columbia
    Is that your work?
  12. Jun 23, 2018 at 2:08 PM
    joshua721
    16 f150 xlt v6
    Fuck no, that's the company that's doing the three in this house. Went and checked on him today.
  13. Jun 23, 2018 at 2:41 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    The final item from my LR renovation was to remove and paint the fireplace doors and reinstall as is. I don't use the fireplace and I had a 2" thick piece of rigid insulation (painted black) wedged in the opening just behind the doors to prevent heat loss in winter. Upon removing the doors I said "hmmmmm...I kinda like the open fireplace look". So I picked up some fireplace brick cleaner and went to town for about 4 hours. Cleaned up fairly well. I picked up a simple screen with doors. I checked the flue and it's spotless and the damper works perfectly. I'll probably not use it and will stuff some fiberglass insulation up near the flue this winter to prevent heat loss. I have a nice stainless steel chimney cap that prevents rain/snow from getting down into the flue. If I ever want to use it, I can just simply remove that insulation. All the mortar and bricks are in great shape. The log holder was pretty dirty and rusty, so I cleaned that all up and will use some of that rust primer and high temp black paint on that. Quite happy with the new look.
    [​IMG] [​IMG]
  14. Jun 23, 2018 at 2:48 PM
    OZ-T
    Peter North
    British Columbia
    I was going to say
  15. Jun 23, 2018 at 3:10 PM
    joshua721
    16 f150 xlt v6
    My bid was way higher. Cant imagine why.
  16. Jun 23, 2018 at 5:55 PM
    OZ-T
    Peter North
    British Columbia
    Probably the Wedi
  17. Jun 24, 2018 at 2:37 PM
    joshua721
    16 f150 xlt v6
    Fixed it
  18. Jun 24, 2018 at 4:30 PM
    OZ-T
    Peter North
    British Columbia
  19. Jun 24, 2018 at 7:15 PM
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    Is there a way to repair wood veneer? Front door is only 4 years old but the finished faded really bad and it was starting dry out and split. Took it off, sanded, and one area I sanded a little too much while trying to get the spots to clean up. I really don’t want to paint it
  20. Jun 25, 2018 at 5:17 AM
    Sig45
    Mark
    Maine
    Got the wood rack and the clean-out device all cleaned up & painted with high temp paint.
