Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jun 25, 2018 at 6:07 AM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    Where did you get the fireplace screen? I like it
    scottalot and Sig45[QUOTED] like this.
  2. Jun 25, 2018 at 7:03 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Funny story. I didn't want the tri-fold kind as they take up too much room. I just Google searched for "single panel fireplace screen" and viewed results in images and scrolled until I found this one that I liked. Was expecting to have to order, but this one was on the Ace Hardware site, so I checked inventory at my local store and they had one remaining in stock. Drove over and grabbed it. Was the exact size, style and color I wanted/needed.
    It has doors...not sure if you can tell from the pic.
    https://m.acehardware.com/product/i...DxUvDwmb6c0VQt0PaDiRlJqPnX0BhCRQaAgRzEALw_wcB
    cafereef[QUOTED] and scottalot like this.
  3. Jun 25, 2018 at 8:34 AM
    Cozza
    Cozza Hi
    Corey
    Denver area, CO
    GX
    Where did you source that screen for the fireplace? Been looking for a nice simple one and failing miserably.
    scottalot likes this.
  4. Jun 25, 2018 at 8:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    You have to cut the bad area out and replace it with a new piece. The fun part is matching up the wood and grain pattern to make it unnoticeable.
  5. Jun 25, 2018 at 8:54 AM
    cafereef
    Thanks, yes I saw the doors, that's what really caught my attention. I have a fake Puraflame fireplace, but wanted the doors to access the control panel if necessary. This is perfect.
    Sig45[QUOTED] likes this.
  6. Jun 25, 2018 at 9:15 AM
    Sig45
    Mark
    Maine
    See a few posts above.
    #15519
    Cozza[QUOTED] likes this.
  7. Jun 25, 2018 at 9:18 AM
    Sig45
    Mark
    Maine
    This one was slightly larger than my opening. So I didn't need to install the feet/braces on the back. Those would be needed if the screen fit within the opening.
  8. Jun 25, 2018 at 9:29 AM
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    How the hell do I find a piece thats the same thickness, then I assume it gets glued together?
  9. Jun 25, 2018 at 9:45 AM
    98tacoma27
    Ben
    Not Beech Creek
  10. Jun 25, 2018 at 9:47 AM
    bacollier90
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
  11. Jun 25, 2018 at 1:40 PM
    Sig45
    Mark
    Maine
    Cleanout plate & grate all dried and reinstalled.
    Decided to paint the screen an Oil Rubbed Bronze color to match the light fixtures and curtain rods in the LR and adjacent DR.
  12. Jun 25, 2018 at 4:22 PM
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    S
    Pictures would help.
  13. Jun 25, 2018 at 4:56 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Needed a second lam trimmer so I wouldn't need to change bit settings and seeing as I already have a corded one I decided to get the 18V cordless Makita
    We're on the last lap , last row of soffit on the lower roof section , will finish tomorrow
  14. Jun 26, 2018 at 6:33 AM
    bacollier90
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    So I did a little research and one trick was to score the spot in the direction of the wood grain with knife or razor blade. That would help it take the stain better in those spots and hide them. I tried it and it actually worked (kinda), not perfect but with my wifes pressure to get the door back on the house asap... that is what I ended up doing. Last coat of finish is drying so ill update with an after pic.
    I had to sand way more aggressively than I would have liked, which also left some not so good sanding marks... some I did not see until I stained.
    ySY4GQ__DA15pqefBS0JryH5bN-6w2MMLzdOnepb_8bbecccc66dfe01b1ce9e76753d41c5598ef674b.jpg
    Drainbung, DoorDing and 916carl like this.
  15. Jun 26, 2018 at 6:37 AM
    DirtyTerp
    DirtyTerp Well-Known Member
    Randy
    Freeland, MD
    '14 DCSB MGM
    So for some reason or other,my house never had a front walkway put in from the driveway to the front door. Me and my buddy spent two hours digging out a pathway and then laid the base course of crusher run down for the sidewalk. It's going to be the same flagstone material I'm using on the back patio to tie everything together.
    98tacoma27, Sig45, Slashaar and 4 others like this.
  16. Jun 26, 2018 at 11:10 AM
    bacollier90
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    What is really weird is that the door weathered, but the trim did not. I put 3 good coats of spar urethane onit. Seems like good stuff and should hold up until the bad spots on it bug me enough that I want to buy a new one.
    I don't have a storm door because I am reluctant to cover up this door, that also may be a good option.
    DoorDing likes this.
  17. Jun 26, 2018 at 12:03 PM
    joshua721
    16 f150 xlt v6
    Yeah I'd paint or just replace the door.
    And I'm so confused on the plan these tile professionals have.
    Drainbung, Slashaar and pudge151 like this.
  18. Jun 26, 2018 at 12:06 PM
    OZ-T
    Peter North
    British Columbia
    Is there going to be Kerdi over drypack for the base ?
    Drainbung likes this.
  19. Jun 26, 2018 at 2:23 PM
    joshua721
    16 f150 xlt v6
    Nope rubber liner and he tiled it before even putting the cement board on the walls.
  20. Jun 26, 2018 at 2:33 PM
    Sig45
    Mark
    Maine
    Screen dried for a day and installed...quite pleased with how it turned out.
    cafereef, truchador, DoorDing and 4 others like this.
