Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jul 29, 2018 at 11:25 AM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    Question about HVAC unit in house. Should all five of these terminal connections be wired straight to the thermostat? Or could any of the wires from these five terminals go elsewhere?
    I attempted to wire in a new smart thermostat and I only have four wires coming out of the wall
  2. Jul 29, 2018 at 11:41 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    One of them might be a relay to ur compressor?
    Just make sure the wires are connected to terminals with same labels on furnace and thermostat and u should be fine lol
    If in doubt get a technician to look at it :) I’m far from an HVAC expert
    What kind of thermostat did u get?
  3. Jul 29, 2018 at 12:11 PM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    Got a Honeywell WiFi free from my brother in law.
    truchador[QUOTED] likes this.
  4. Jul 29, 2018 at 12:14 PM
    truchador
    Otto
    WV
    15 DC OR
    What is it replacing?
  5. Jul 29, 2018 at 12:21 PM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    An old white Rodgers
  6. Jul 29, 2018 at 12:48 PM
    truchador
    Otto
    WV
    15 DC OR
    So if it is a dial thermostat it might not have a c wire which means you’ll likely need to run a new 5 wire bundle or the “add a wire” module (although it looks like all the terminals on your furnace are being used)
    When u get a chance take another pic of your furnace where u can see terminal labels (and how all the wires are related/connected-looks like 3 different bundles come together there) and maybe a pic of where u can see terminal labels on your existing thermostat
    Until then this is a good read: https://smartthermostatguide.com/thermostat-c-wire-explained/
    I needed to run some 18/5 wire when I upgraded to a smart thermostat
    Also I think there is an “ask an electrician” thread somewhere on TW that might have some hvac trsffic :)
    phillstill[QUOTED] likes this.
  7. Jul 29, 2018 at 2:48 PM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    The terminals in order are C G R W Y.
    There are three sets of wire wired in to the furnace. The first set of wire(4 wires) goes back to the thermostat and all but the R connection match (G=G Y=Y and W=W). The R terminal on the furnace is connected to the second set of wire(2 wires) with the second wire tied to the R connection going back to the thermostat (my guess is this wire goes to the limit switch in the drain pan). The third set (2 wires) is connected to the C and the Y. I don't know where this set goes.
    I believe i just need to add one new wire from the Furnace C back to the C of the new thermostat.
    I'm in Houston and my attic to too hot to work in, so I will have to wait till I get back in town in two weeks. I just reinstalled my old thermostat.
  8. Jul 29, 2018 at 3:07 PM
    truchador
    Otto
    WV
    15 DC OR
    Sounds like a plan :)
    I think it is an 18 gauge wire, might as well run 18/5 while you’re in there for futuremods
  9. Jul 30, 2018 at 8:20 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    So, continuing to get ready to paint the exterior of house, and not sure if the columns can be saved or if I should replace them.
    What do you think?
    wilcam47 likes this.
  10. Jul 30, 2018 at 10:00 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Id get a good paint stripper and take it down to wood. see what it looks like...go from there
    DoorDing and T Fades[QUOTED] like this.
  11. Jul 30, 2018 at 10:09 AM
    Martyinco
    Martyinco Well-Known Member
    No matter what you do, you will continue to get rot and moisture from the bottom unless you cut up and get the wood off the ground. I always leave a 1/2" of space when using wood outside as to not create a wicking effect with ground water.
    98tacoma27, cafereef, robssol and 5 others like this.
  12. Jul 31, 2018 at 8:20 AM
    scocar
    scocar Patron of the Farts
    Stud finder upgrade recommendations. I have an older Zircon that has "deep stud" and electrical sensing, but it takes a lot of back and forth calibration, and does not slide very well along high friction (flat paint) textures. This sucks for overhead joist locating.
    What new stud finders do you all recommend? Trying to strike a balance between good DIY vs contractor grade.
  13. Jul 31, 2018 at 8:30 AM
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    I've been very happy with my ProSensor 710. It's a little pricey if you don't use it much.
    https://www.amazon.com/gp/product/B0064EICKG/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    scocar[QUOTED] likes this.
  14. Jul 31, 2018 at 8:58 AM
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    Costco has one that I picked up and really like b/c it has been dead on accurate. The Zircon was becoming hit or miss for me and many times my whole wall would get an electrical hit, which drove me nuts. Can't find a link other than this YouTube, and I haven't even watched it. Just to show you what it looks like.
    https://www.youtube.com/watch?v=_PElkQRGyeo
  15. Jul 31, 2018 at 9:15 AM
    scocar
    Yes on Android....? Go on....
  16. Jul 31, 2018 at 9:17 AM
    scocar
    dlawrence529[QUOTED] likes this.
  17. Jul 31, 2018 at 9:29 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
  18. Jul 31, 2018 at 9:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    Skip to 5:11 for actual demo
    DoorDing and scocar[QUOTED] like this.
  19. Jul 31, 2018 at 9:40 AM
    dlawrence529
    Maine
  20. Jul 31, 2018 at 10:04 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I have similar issues with mine. Either finds electrical behind everything, or says studs are there when they aren’t.
    Good times.
    LTDSC likes this.
