Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 28, 2018 at 8:36 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    can you reach the vent safely from the outside? Have someone turn on the dryer and check the vent from the outside? Just seems weird if it was working ok now its not its something going out. Is there 2 elements in the dry or just one?
    95 taco[QUOTED] likes this.
  2. Nov 28, 2018 at 8:39 AM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    In the middle of a remodel right now.
    400sqft of tile has been removed, and mortar removed to bare concrete.
    Cabinet doors have been sprayed.
    Cabinet boxes are primed, ready to be sprayed
    Crown moulding has been added to cabinets.
    Under cabinet lighting has been hardwired to dimmer switch.
    Countertop is scheduled for install next week.
    Luxury vinyl plank flooring will be on entire bottom floor (900 sqft)
    looking to be done around New Years
    Before:
    Cabinet doors drying after being sprayed:
    As of last night:
    Bagman, Jiveydude, RocTaco and 3 others like this.
  3. Nov 28, 2018 at 8:41 AM
    su.b.rat
    su.b.rat broken truck
    bought my house and previous owner had at some point in the past moved the laundry toward the center of the slab. then after that maybe in the 90's there was another round of addition, and the effect was a 20' run of dryer vent line under the slab ( half in the foundation and half under a pool cap). it went down then back up to above the slab to vent. not sure I'd even call that a 'design'. after our 6 months of reno we moved in and 6 weeks later the dryer stopped working and the end of that line was making glug sounds. the entire line was full of water just from the moist vent air. vacuumed it out and 5-6 weeks later same thing. so i shut down the laundry and started a huge round of work to correct it.
    the simple solution would have been to vent straight up through the roof, but i took the opportunity to move the laundry out to the garage and convert the laundry room to an office. that required replumbing the hot water through the whole house and adding a second 3" drain line on the other side of the property. massive expense but big improvement. the vent line has been filled and sealed. it ran under my wife's side of the bed in the slab and she could smell the stagnant water.
    the new 3"drain had to run about 150'. huge pita but all good now. live & learn the hard & expensive way.
  4. Nov 28, 2018 at 8:41 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Typically what happens is you have moist hot air from the dryer going into a cold metal vent. It just turns to water and if its not graded down enough moisture just sits in the pipe and it gets too humid to dry your clothes.
    Unfortunately if you’ve cleaned it out and its a moisture issue, you’ll want to revent.
    But yeah its not fun when you’re tearing up your walls. :(
  5. Nov 28, 2018 at 8:44 AM
    PackCon
    Connor
    :bananadead:
    Oh no.
    su.b.rat[QUOTED] likes this.
  6. Nov 28, 2018 at 8:45 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Yeah, I’ll check that when I get home.
    It lost effectiveness when it moved houses which makes me think it’s the vent system.
    I’m not sure on the number of elements, I didn’t pull the cover off when I had it apart, heat isn’t an issue though because if you run the dryer for 20 minutes the clothes are warm (110-120 degrees) even though they’re wet.
    Another reason I’m looking at the vent is because there’s some lint trying to escape the drum out the front which indicates excess back pressure.
  7. Nov 28, 2018 at 8:47 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Do you have a electric leaf blower? If you do hook it up and blow it out
    wilcam47 and 95 taco[QUOTED] like this.
  8. Nov 28, 2018 at 8:48 AM
    PackCon
    Connor
    Looks good!
    I’m working on painting the bath vanity and its been one heck of a job so far. Kitchen cabinets are already painted but need to be redone. I’m not looking foward to that project.
    What paint are you using for the cabinets?
  9. Nov 28, 2018 at 8:48 AM
    su.b.rat
    pretty sure those were the first 2 words out of my mouth when i heard the glugging sound. but those were definitely not the last 2 words lol.
    95 taco and PackCon[QUOTED] like this.
  10. Nov 28, 2018 at 8:49 AM
    PackCon
    Connor
    First words would be “Oh no”
    Last words “honey looks like we’re getting a clothes line!”
  11. Nov 28, 2018 at 8:51 AM
    95 taco
    95 taco Battle Born
    It’s not even metal, it appears to be ABS or PVC (it’s some sort of plastic but paint makes it difficult to see the original color) and the vent guard on the outside of the slab was just glued on so I’ll have to get some small concrete screws so I can remove it to clean it for the time being.
    I’ll have to do some measurements but we may be able to get away with just pulling the Sheetrock in our office closer to run the vent.
    It’s better to vent upwards (and then out) anyway because heat rises, correct?
    wilcam47 likes this.
  12. Nov 28, 2018 at 8:52 AM
    trdNick
    trdNick Odie
    Texas
    Thanks!
    Used a bonding primer, 2 coats sanded in between each coat. For the paint we are using Sherwin Williams Pro Classic acrylic latex in a satin finish, 2 coats. Snowbound is the color.
    PackCon[QUOTED] likes this.
  13. Nov 28, 2018 at 8:52 AM
    95 taco
    95 taco Battle Born
    I’m sure I can get access to one, I’ll try that.
  14. Nov 28, 2018 at 8:53 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Is there good flow to the outside vent when the dryer is running? Maybe the problem is in the dryer, sometimes a lot of lint will build up just past the filter where it tapers down. Maybe try running the brush through there a few times with the filter removed.
  15. Nov 28, 2018 at 9:01 AM
    Ck1010
    Ck1010 Well-Known Member
    Ohio
    ‘21 Tundra TRD Off-Road
    Just finished a bathroom remodel.
    6173C90D-9E5A-4B87-BE8B-044125436F27.jpg C38023BD-DA2D-44E7-BEAD-C203CF171A7F.jpg 60A88A4B-9764-42BC-BB99-C09010725069.jpg E4BA287C-88B1-4F7B-B657-19B59757F651.jpg 5D48398B-43D1-4F2F-902A-EF5AAE0FEB65.jpg
  16. Nov 28, 2018 at 9:01 AM
    95 taco
    95 taco Battle Born
    I disassembled the dryer (including removing and cleaning where the filter goes and the dryer itself flows well (tested after re-assembly) before being attached to the house vent.
  17. Nov 28, 2018 at 9:02 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    How “tight” is the house? Try opening a window or door for a dry cycle see if it changes anything.
  18. Nov 28, 2018 at 9:23 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    I have a similar timeline for my kitchen, but I'm no where near as far along hahaha.
    It's going to be a very busy month.
  19. Nov 28, 2018 at 9:52 AM
    95 taco
    95 taco Battle Born
    I’ve never thought about that, it’s fairly tight, the loosest fit is the front door (1/8 gap when the wipe isn’t on it) but it’s not toght enough to have a tangible pressure wave when you close a door and everything else is closed.
    I’ll have to try that.
  20. Nov 28, 2018 at 10:01 AM
    PackCon
    Connor
    I’m not a builder or contractor BUT I thought it was against the fire codes to have a PVC vent pipe from the dryer because if you ever have a fire start in the dryer it will keep the fire going more than metal.
