Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jan 21, 2019 at 9:06 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    yes thats what hes talking about. You dont really need it if your arent going to drill into the concrete and use concrete nails.
    Make sure you clean the area really good, and put some liquid nails or epoxy, then put your trim down add some weight to the trim to hold it down the the epoxy/liquid nails dries. Should be dry enough overnight but at least 24hrs for most stuff.
    scottalot and 258900[QUOTED] like this.
  2. Jan 21, 2019 at 9:15 AM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    And the other side. Just needs a quick coat of paint and will be good to go F6570911-3794-49D8-88E1-8FD10DBAADED.jpg
  3. Jan 21, 2019 at 9:50 AM
    258900
    258900 Well-Known Member
    Eddie
    BOSTON, MA
    2013 tacoma trd offroad
    debaged tailgate & doors, trd pro headlights, trd pro grille w/white surround, 4runner trd pro sema wheels, 265/70/17 pirelli a/t, morimoto fog light, klearz light smoked 3rd brake light cover, led lighting all around.
    okay thanks bro
  4. Jan 21, 2019 at 9:57 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Take the short piece off that runs along the skirtboard and rip it narrower so the front edge planes out with the shoe on the baseboard
    scottalot, 98tacoma27 and wilcam47 like this.
  5. Jan 21, 2019 at 10:01 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Yes XD there it is!
    It's supposed to be secured to the floor, not glued to the strip hahaha.
    Yes liquid nails dries fast. Ideally don't let anyone step on it for about an hour but within a few minutes it should be firmed up a bit.
    258900[QUOTED] likes this.
  6. Jan 21, 2019 at 10:01 AM
    258900
    Eddie
    BOSTON, MA
    also would it be best to take of the rack from the trim then glue it down? theres some type of wood on the floor
    wilcam47 likes this.
  7. Jan 21, 2019 at 10:04 AM
    wilcam47
    Will
    Bourbon state
    Looks like they have a plywood under the hardwood. I'd scrap the old glue off at a minimum. You could also get some small flat head screws and screw that channel into the wood then you just lock the trim piece into the channel.
    PackCon likes this.
  8. Jan 21, 2019 at 10:12 AM
    OZ-T
    Peter North
    British Columbia
  9. Jan 21, 2019 at 10:17 AM
    258900
    Eddie
    BOSTON, MA
    ok i will give those two a try
    wilcam47[QUOTED] likes this.
  10. Jan 21, 2019 at 10:28 AM
    Markcal
    Markcal Well-Known Member
    I have 2 DeLonghi oil space heaters like that. They work very well in the rooms I have them in. My daughters bedroom is 120 sq ft and mine is 160 plus a open door walk in closet. Keeps our bedrooms as warm as we want without using the oil burner to heat the whole upstairs.
    X2. I had one in the kid's room when we were having HVAC issues, and we have a lower bedroom half set below grade that can be an icebox in winter. Works great in both. Each was approx the size of your two rooms.
    X3... This heats a small bedroom in my 100 year old home and best of all is very safe.
    shakerhood likes this.
  11. Jan 21, 2019 at 10:53 AM
    Markcal
    Most of you probably know this tip, but for those that don't, I will share it. Last night I had a constant drip under the kitchen sink faucet, so grabbed another stainless steel hose to replace the old one. I closed the main water supply line, but couldn't stop the pipe from dripping and with the water dripping couldn't coat the threads properly with plumbers dope , so what I didn't was take a small piece of Italian bread (must be Italian) and stuff it down the pipe to stop the water flow, as I coated the threads with plumbers dope. It worked great and was able to stop the dripping, with the bread being easily flushed out, as I listen to the Patriots on the radio.
  12. Jan 21, 2019 at 1:48 PM
    PackCon
    Connor
    OR you could replace your broken valves LOL
    wilcam47 and megillet like this.
  13. Jan 21, 2019 at 1:56 PM
    Markcal
    It wasn't a broken valve causing the leaking but a stainless steel hose. If you were talking about replacing the main supply line that would take hours and money, to taking a 1/100th of a cent piece of bread, then you are masochistic of the highest order. :facepalm:
  14. Jan 21, 2019 at 2:07 PM
    PackCon
    Connor
    I must be confused as to what you are talking about. You should have a water shut off at the sink, if you turn it off no water should be coming out (past what drains out).
  15. Jan 21, 2019 at 2:13 PM
    Markcal
    Couldn't stop the water dripping from the pipe in my 100 year old house, so I used a 1/100 of a cent piece of bread = no more leaking sink. Just a tip I wanted to share with others Conner, you don't need my tip.
    Kolunatic likes this.
  16. Jan 21, 2019 at 3:57 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    the bread temporarily stops supply drip while fittings are installed. The resulting dryness increases adhesion of pipe dope or solder
    Then it theoretically dissolves and washes thru
    PackCon[QUOTED] and Kolunatic like this.
  17. Jan 21, 2019 at 4:01 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Just signed the papers with the contractors to do a full kitchen remodel and complete my master bathroom remodel. Here are the current shots of the two rooms...
    scottalot, PackCon, Slashaar and 3 others like this.
  18. Jan 21, 2019 at 5:44 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Since the blinds will be open to enjoy the new view I decided to add mirror tint.
    It works great. I used cling on instead of adhesive. It is gold but for some reason it came out silver. Maybe due to having dual pane windows.
    The difference between the mirror tint and no tint.
  19. Jan 21, 2019 at 6:10 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Not always
    Haven’t used bread in 30 years or so.
    They’re are better alternatives now
    PackCon and truchador[QUOTED] like this.
  20. Jan 21, 2019 at 7:46 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    I plan to make something like this soon. Underneath I'll put a old shop vac and a DIY cyclone dust collector (plenty of idea in google/youtube).
    Bagman, ejl923, Slashaar and 5 others like this.
