Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Feb 23, 2019 at 2:04 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I like PL Premium
    98tacoma27 and Martyinco like this.
  2. Feb 23, 2019 at 2:07 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Last sub floor I put in I used my son's Elmer's. We have the quietest floors
    Martyinco likes this.
  3. Feb 23, 2019 at 2:14 PM
    Martyinco
    Martyinco Well-Known Member
    We use to use Elmer’s to glue down our tack strip onto concrete floors when flooring, couldn’t believe how well that held.
  4. Feb 23, 2019 at 3:06 PM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Thanks y'all for your help.
    Mucho appreciated-o
    23Skidoo likes this.
  5. Feb 25, 2019 at 4:52 PM
    billum v2.0
    billum v2.0 Well-Known Member
    Flyover Country
    '01 SR5 TRD Off Road Extra-cab
    Bone Stock
    So, I'm building a box beam ceiling in my den. Can't come up with a solution of material to install inside the beams at the ceiling. T & G carsiding only comes in 5" & 8" widths (8" too wide, 5" too close to mimicking width of beams). Most bead board is 2" c-to-c of the beads, makes it too busy. Found some 3" c-to-c bead board, but the cutters used to cut the profiles must have been dull ........a decade ago. Painting will only magnify the roughness. V groove would work, but everything I've seen has too deep of groove (¼"+).
    Variation between the trusses of up to ½", otherwise I'd just paint the drywall and be done. Adjusted the beams to level by how they're attached at the cleats. Will need to shim whatever material install between them so the trim doesn't follow variation caused by the trusses when nailed to beams. Thinking I'll install ½" ply to drywall (shim as needed) and final ceiling material to the ply. None of the spacing between beams is wider/longer than 4'x8', so a sheet product would work.
    This is the look I'm going for. Wider than bead board, narrower than the width of the beams.[​IMG]
    Ideas?
  6. Feb 25, 2019 at 6:10 PM
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    Can you just get a router bit and make it yourself?
    wilcam47 likes this.
  7. Feb 25, 2019 at 6:36 PM
    OZ-T
    Peter North
    British Columbia
    Install mdf and paint it , bail on the beading
    Bottom pic looks like 1x4 t&g v groove to me , but I'm on my phone
  8. Feb 25, 2019 at 7:51 PM
    thelate1
    thelate1 Well-Known Member
    PA
    2013 DCLB Sport 4x4
    I'd just do a small piece of molding to hide the difference, then paint the drywall. Even if it just an inch tall or whatever you need to be able to nail it up. It'll be so small that 45 deg cuts will be fine and you shouldn't have to miter anything.
    It'll look much cleaner.:thumbsup:
  9. Feb 26, 2019 at 6:58 AM
    billum v2.0
    Flyover Country
    Bone Stock
    Hmmmmm. Going to combine these two suggestions, run a test pattern and see how it looks. Like MDF for the sharp/clean profiles it takes from router. Hadn't thought of cutting MDF to size, routing v grooves. Can adjust grooves to any spacing/depth, eliminates problem of variation between boards/gaps and won't require a backer to support. Only concern is weight. 7/16ths would be nearly 40 lbs. for the largest panels, less whatever route away (nominal). Likely have to use some screws to support that much hanging weight.
    The problem is the ½" truss height difference shows up in the ceiling drywall as a hump over a 6 to 8" span and not over the 24" centers. If molding is thin enough to follow hump, it'll be obvious. Could span the humps a foot or so either side, but end up with a wedge of caulk to fill the gaps that will be noticeable.
    Not following your 45 degree cuts will be fine and no need to miter. I typically cope trim.
  10. Feb 26, 2019 at 7:07 AM
    OZ-T
    Peter North
    British Columbia
    You could land 1/4" mdf base sheet shimmed to your final height and rip strips of 1/4" mdf at whatever width you want and rout whatever edge detail you want then apply strips with Titebond 3 and brads
  11. Feb 26, 2019 at 7:50 AM
    billum v2.0
    Flyover Country
    Bone Stock
    I haven't had good luck working with ¼" MDF unless has a paper facing. Gets too noodley running much length, have to use a bucket full of spacers to keep it straight. Not an issue on a bench, little appeal working overhead.
    Curious to your choice of Titebond 3, I've always used the original on everything wood/MDF unless exposed to elements. Am I missed something?
  12. Feb 26, 2019 at 10:11 AM
    OZ-T
    Peter North
    British Columbia
    Higher strength , longer open time
    billum v2.0[QUOTED] and Crodell6 like this.
  13. Feb 26, 2019 at 4:03 PM
    dlawrence529
    Maine
    If youre worried about weight, you could level it out by shimming some furring strips. Then use 1x stock for the boards. You can run a chamfer on or roundover bit across the edges to give it some depth
  14. Feb 26, 2019 at 5:06 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
  15. Feb 26, 2019 at 6:05 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  16. Feb 26, 2019 at 6:06 PM
    Slashaar
    Josh
    Kansas City, MO
    Damn near silent. and I don't have the extra sound proofing it comes with installed yet either.
    Disclaimer though, with all the settings on it runs for ~5 hours....
    wilcam47[QUOTED] likes this.
  17. Feb 26, 2019 at 6:10 PM
    wilcam47
    Will
    Bourbon state
    blame the Government on that...
    98tacoma27 and Slashaar[QUOTED] like this.
  18. Feb 26, 2019 at 6:14 PM
    Slashaar
    Josh
    Kansas City, MO
    Efficiency crap?
  19. Feb 26, 2019 at 8:55 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  20. Feb 27, 2019 at 10:32 AM
    thelate1
    PA
    2013 DCLB Sport 4x4
    Most just trap the food chunks in a container at the bottom. If you don't rinse your stuff, make sure to empty this container frequently or it'll back up.
