Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 14, 2019 at 6:39 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Just need another pistol for the wife and we are set! for now what I have is plenty I'd hope, unless they're bringing a small army?
    wilcam47 and SRH[QUOTED] like this.
  2. Mar 14, 2019 at 8:43 PM
    scocar
    scocar Patron of the Farts
    Needs moar Lorax
    Slashaar likes this.
  3. Mar 14, 2019 at 9:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Has The Truax
    scocar[QUOTED] likes this.
  4. Mar 14, 2019 at 9:15 PM
    OZ-T
    Peter North
    British Columbia
    I have the C3
  5. Mar 14, 2019 at 9:17 PM
    OZ-T
    Peter North
    British Columbia
    I haven't used it a ton , actually got it to problem solve a thermal bridging / thermal bypass issue on a job but it is pretty cool
    shakerhood and Crodell6[QUOTED] like this.
  6. Mar 14, 2019 at 9:26 PM
    OZ-T
    Peter North
    British Columbia
    Its pretty awesome for all that kind of stuff , my reason for getting it is mostly for improving the thermal envelope on buildings
  7. Mar 15, 2019 at 6:05 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    I would pull that cement board too, I seriously doubt it was installed properly with a rain screen and with your h2o issues it will likely become a sodden crumbly mess if u cover it up with another product. Then u can reinstall your windows correctly :)
    floodedkiwi[QUOTED] likes this.
  8. Mar 15, 2019 at 10:41 PM
    Slashaar
    Josh
    Kansas City, MO
    Our inspectors used one to check our circuit panels, outlets, and heat flow through the house.
    Crodell6[QUOTED] likes this.
  9. Mar 15, 2019 at 11:41 PM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Anyone have any experience with drywall/insulation in a garage? Renting a home in the PNW with half the garage insulated and drywalled. I'm going to get the other half done so I can hopefully spend more time in there during the winter months. Codes permit me to install it myself, going to match what was previously installed.
    I've got to do 3 4'x8' sheets per side to complete it. I'm going to get a drywall driver bit and some drywall tape for the seams. Anything else I should consider?
  10. Mar 15, 2019 at 11:55 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    If you don't want to throw down $800 for a Flir system and don't have to have as much detail Seek thermal has a nice gadget for around $225 that connects to most smart phones. Flir make a similar one. Both make a lower price the one I have and a better model for a little more $.
    Crom and truchador like this.
  11. Mar 16, 2019 at 6:44 AM
    truchador
    Otto
    WV
    15 DC OR
    Youtube is your friend. Speaking of friends, hanging sheetrock is definitely easier with one. Or a lift lol.
    You’ll want to put a bead of drywall adhesive on studs and plates, and you’ll need mud and a 6” drywall knife to make the tape stick and to seal the gap
    I assume you’re not finishing/painting?
    What are you insulating with?
    Just saw you’re renting. check with your landlord first, they might give U a break on your next rent in the amount of materials invested. Or keep ur security deposit lol
    Slashaar and wilcam47 like this.
  12. Mar 16, 2019 at 7:05 AM
    DrFunker
    DrFunker Well-Known Member
    I borrowed one of those from the local library. Worked great.
    TK-422[QUOTED] likes this.
  13. Mar 16, 2019 at 7:09 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    its also easier if you pay someone to do it...;) I hate sheetrock.
    truchador[QUOTED] likes this.
  14. Mar 16, 2019 at 7:11 AM
    truchador
    Otto
    WV
    15 DC OR
    No doubt. I don’t mind hanging it so much but finishing it is not my favorite thing to do lol
    wilcam47[QUOTED] likes this.
  15. Mar 16, 2019 at 7:14 AM
    wilcam47
    Will
    Bourbon state
    yeah I usually put too much stuff on the seams and have to sand it off :anonymous:
  16. Mar 16, 2019 at 7:39 AM
    Ck1010
    Ck1010 Well-Known Member
    Ohio
    ‘21 Tundra TRD Off-Road
    And then sand too much off and have to do it all over again....(that’s why I payed someone this time to finish it)
  17. Mar 16, 2019 at 1:35 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Ok..more questions..
    I will likely be starting my garage interior build soon. So far I have been given the following in from here..
    -put outlets up high
    -plywood/osb behind drywall
    -hang items off isulation if storing in attic
    I can see light through the bottom of the exterior walls. It doesnt have a frost wall so water can potentially enter.
    How do I seal this up?
    Also, in prep for a gas heater...should I pipe in for this? Radiant vs forced air? Both consumption and heat distribution.
  18. Mar 16, 2019 at 1:44 PM
    truchador
    Otto
    WV
    15 DC OR
    Pics of bottom of exterior walls might help :)
  19. Mar 16, 2019 at 1:56 PM
    OZ-T
    Peter North
    British Columbia
    Is it exterior walls directly on to the slab ?
  20. Mar 16, 2019 at 1:59 PM
    ImplicitlyAlberta
    David
    edmonton
    Yes
