Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 28, 2019 at 11:26 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Yeah..just hoping to offset some beers while we watch the Vols play Purdue tonight in the Sweet 16
  2. Mar 28, 2019 at 11:29 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Odd for sure. Maybe he was raised without a father figure, though.
    I’m sure in certain environments that it’s probably more common than we’d think.
    wilcam47[QUOTED] likes this.
  3. Mar 28, 2019 at 11:31 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    usually around .04cts a pound.
  4. Mar 28, 2019 at 11:32 AM
    wilcam47
    Will
    Bourbon state
    true, but Im not in a big city. Im out in the sticks where some basic knowledge is necessary to survive...
    T4RFTMFW[QUOTED] likes this.
  5. Mar 28, 2019 at 11:33 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    For galvanized stuff??
  6. Mar 28, 2019 at 11:34 AM
    wilcam47
    Will
    Bourbon state
    I couldnt find specifically galvanized but scrap steel goes for .04Cts a pound here...I dont know if they lump it the same as scrap steel
  7. Mar 28, 2019 at 11:37 AM
    honda50r
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    I anticipate it to be a little bit better than that, but not by much
  8. Mar 28, 2019 at 11:38 AM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    It's for this exact reason I have a tool kit in my vehicle at all times. Never know when you will need it. be shocked how often I've found uses for a length of paracord too.
    Crom and wilcam47[QUOTED] like this.
  9. Mar 28, 2019 at 11:40 AM
    wilcam47
    Will
    Bourbon state
    yep, I got some cresent wrenches, jumper cables, tow strap and some other sockets wratchet etc.
    FastEddy59 likes this.
  10. Mar 28, 2019 at 12:11 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    No power to any of this.
    20190328_135907.jpg 20190328_140046.jpg 20190328_140101.jpg 20190328_140129.jpg 20190328_140135.jpg 20190328_140144.jpg
    wilcam47 likes this.
  11. Mar 28, 2019 at 12:19 PM
    TireFire
    Olympic Peninsula
    Looks like daisy chained? You have power anywhere else on the circuit?
    If not, check the breaker
    wilcam47 and Slashaar[QUOTED] like this.
  12. Mar 28, 2019 at 12:21 PM
    wilcam47
    Will
    Bourbon state
    where on the wall was this in the master bath? might check the circuit breaker for that particular line. the line on the right is usually power coming in then they go power out to the line on the left and down. but not always could be any combo of this. Sometimes you have to check the circuit breaker at the panel and see if its got power there and if the line going to that havent come loose for some reason--Ive seen it so it does happen. try resetting the circuit breaker for that line and see if it resets. Other than that you have to follow the lines and see where they go. Should basically go from the Circuit breaker panel/circuit breaker to the line to the particular GFCI. Could be 2 or more GFCI's in one line.
    robssol and TireFire like this.
  13. Mar 28, 2019 at 12:28 PM
    cafereef
    is it a new GFCI? I'm not an electrician, but I know I've had GFCI's that cannot be wired they way yours is. Maybe the hot (black) needs to go to the line terminal next to where it is wired currently. With the neutral staying where it is. If it is new, ensure you read the the wiring instructions carefully.
    If you have one, use a Pen style voltage tester and stick it in the box. See if there is any voltage coming into that gang box at all. If there is none, then you have to trace it back to the next hop, going all the way back to the breaker until you identify the point of failure
  14. Mar 28, 2019 at 12:37 PM
    wilcam47
    Will
    Bourbon state
    Also the first pic looks like the GFCI isnt reset
  15. Mar 28, 2019 at 12:50 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Here you go.
    55653314_830168850684076_686809360187680_74c51fea06ac396071def47c23c5cb67ec509285.jpg
    stronghammer[QUOTED] likes this.
  16. Mar 28, 2019 at 2:44 PM
    Slashaar
    Josh
    Kansas City, MO
    But I'm not picking up any voltage to any of the wires in the box with a voltmeter or non-contact tester either.
    All other GFCI's and outlets work except aforementioned outdoor outlet. All breakers are on and have power.
    This is in our hallway bathroom. I've checked all the other GFCI's none are tripped. Unless there's one hidden somewhere. I need to have my panel replaced still anyways. Maybe I'll just tack this onto the bill. Though I fear it'll require some demo to find where these wires go.
    truchador and wilcam47[QUOTED] like this.
  17. Mar 28, 2019 at 5:13 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    If it ends up being that easy...
    :bananadead:
    wilcam47[QUOTED] and Martyinco like this.
  18. Mar 28, 2019 at 6:19 PM
    wilcam47
    Will
    Bourbon state
    you said you have an outside outlet not working also? How close is that to the hall bathroom? maybe a wire is broke at the back of the outside outlet or the nearest GFCI outlet. Also how close is the hall bath from your master bath? do all fans and heaters work in the bathrooms? maybe go in the attic and see if theres any damage that can be seen above the hall bath. Maybe a squirrel/rat/raccoon...etc..
  19. Mar 28, 2019 at 6:23 PM
    Slashaar
    Josh
    Kansas City, MO
    Nope, its reset. no power.
  20. Mar 28, 2019 at 6:27 PM
    wilcam47
    Will
    Bourbon state
    I still think its upstream of the hall bath...usually they are connected to the master bath. Like ours the hall bath doesnt have a GFCI but is connected to the master bath outlet, so if it trips usually its the hall bath overloaded it.
