Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Apr 13, 2019 at 5:31 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    We used this super thin green rolled foam type of underlay for the laminate floor by the front door. Keep in mind this is Canada so i'm layin' upstairs floor over wood & moisture is less of a factor.
    scottalot[QUOTED] likes this.
  2. Apr 13, 2019 at 5:33 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    They make those for ocillating multi tools as well
    wilcam47, pudge151, truchador and 2 others like this.
  3. Apr 13, 2019 at 5:35 PM
    OZ-T
    Peter North
    British Columbia
    wilcam47, scocar, scottalot and 2 others like this.
  4. Apr 13, 2019 at 6:18 PM
    OZ-T
    Peter North
    British Columbia
    Use a spray bottle with water and mist it all down as you go , thats how the remediators would remove it too . It keeps the friable particles from becoming airborne .
  5. Apr 13, 2019 at 7:16 PM
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    What about a roof shovel/shingle remover? Might work alright on a slab
  6. Apr 14, 2019 at 1:04 AM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I used roofing felt on my slab before installing ceramic tile. It was glued down to the slab. I was more worried about the cracks moving in So Cal earthquakes. It's been there since 2001 without any tiles or grout being displaced. Just something to consider.
    FastEddy59 and scottalot[QUOTED] like this.
  7. Apr 14, 2019 at 6:32 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Beer. U forgot beer.
    Well to be fair that kind of work really calls for more of an herbal relaxation/zoning out with some music :)
    Or so I’ve heard
  8. Apr 14, 2019 at 7:59 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    If you are concerned about the possibility of asbestos I'd take a few more precautions, even though glue should be pretty completely non-friable.
    -Tape plastic up covering doorways and vents, turn HVAC off.
    -Skip the shop-vac. Unless it's a HEPA filter it'll just blow fibers around, and may reintroduce them later when you use it.
    -Add a little dish soap in your spray bottles of water, not sure exactly why but it was something I read and it seems to help.
    -Dont skimp on PPE. Get a legit respirator with the pink P100 filters, that's probably the most important things. We went full up, tyvek suits, rubber boots and gloves, chem goggles. Was hot as fuck even with below freezing temps outside and heat off.
    -Keep debris wet when you bag it, double bag and tape it. Dispose properly, don't just throw it in with your normal garbage lol.
    -When you're all done, wipe EVERYTHING down with water and mop the floors too.
  9. Apr 14, 2019 at 8:19 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    If you have the room to match floors that will join to it, what about putting self leveling compound over the top? I had to use it in a second floor bedroom and the floor came out so perfectly level you can drop a marble on it and it won't roll. The subfloor doesn't move at all now, no creaking boards under foot. It's amazing, I wouldn't put down laminate without it honestly (unless already on a perfectly smooth slab).
  10. Apr 14, 2019 at 9:46 AM
    4BYTOY
    4BYTOY Well-Known Member
    Colorado Front Range
    2018 TRD Off Road
    Looking Good :thumbsup: Nice clean work area. Interesting how different geographic areas use different materials for building ....looks like all plywood for you and no OSB. Yet, here in Colorado it would be the opposite - OSB instead of plywood. Unless the specs called for fire resistant sheeting, then it would probably be fire resistant plywood, but I haven't seen that for years.
    4BYTOY
    scottalot and Drainbung like this.
  11. Apr 14, 2019 at 9:50 AM
    OZ-T
    Peter North
    British Columbia
    I never use OSB , its not really used at all residentially in my area
    scottalot and 4BYTOY[QUOTED] like this.
  12. Apr 14, 2019 at 11:52 AM
    FastEddy59
    Eddie
    When my S.I.L was drywall sanding his basement with a newborn in the house, I lent him a long 3" dia. hose that he hooked up to the shop vac discharge so he could vent it out a window. It worked, No sign of dust in the house.
  13. Apr 14, 2019 at 12:33 PM
    megillet
    Mark
    Atlanta, GA
    Depends on what you are putting it on. Did you say over a slab? If so, I think it can go that thin. If you apply over plywood, it needs expanded metal mesh which you have to cover, but I believe if straight onto a slab it doesn’t need the mesh and can go as thin as 1/8”. It probably depends on the SLC that you use. I had good luck with the stuff Home Depot sells near me.
  14. Apr 14, 2019 at 2:19 PM
    OZ-T
    Peter North
    British Columbia
    23Skidoo and scottalot like this.
  15. Apr 14, 2019 at 2:56 PM
    Ck1010
    Ck1010 Well-Known Member
    Ohio
    ‘21 Tundra TRD Off-Road
    Getting ready to build a house and sheathing options are OSB or Dow Foam board. I’ve read enough about the both of them but would like an opinion from someone else. I’m leaning towards the OSB as I’m not sure the insulation gained from the Dow board would justify it over the strength of the OSB. Of course, if using the Dow, OSB would still be used in places where windows/doors are.
    Any opinions?
  16. Apr 14, 2019 at 3:54 PM
    OZ-T
    Peter North
    British Columbia
    The insulating sheeting is nice as far as cutting thermal bridging through the studs but then you need to address your lateral restraint issues by other means . Here we would go 1/2" ply and comfortboard of XPS over that for exterior insilation value
    23Skidoo likes this.
  17. Apr 15, 2019 at 4:56 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Hey guys.
    I’ve got a weird issue going on with my thermostat in my house.
    The thermostat is hardwired and had batteries in the back.
    One day I turned the heat up when I got home and felt like the furnace was just pouring out heat so I walked back to the thermostat and it was blank.
    I pulled it out from the wall, waited about 30 seconds and plugged it back in and it popped back up.
    Same thing happened yesterday.
    The box is firmly pressed into the wall so its not wiggling from the connection.
    I put new batteries in it but feel that shouldn’t be an issue if its hardwired??
    The circuits obviously aren’t tripping and power is getting to the box.
    I feel like the furnace goes full boar when it happens but that could just be in my mind.
    What kind of things can I check to see if its a simple fix vs just needing to buy a new thermostat.
    I’m concerned about leaving home and the furnace just flares up all day. I have a cat and prefer that not be the way she dies.
    That happened in an old office I worked at where that happened and the interior got to 140F
    Furnace and thermostat are 13 years old.
    Thanks!
  18. Apr 15, 2019 at 5:02 AM
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    Definitely get a floor scraper but be careful not to chip the slab, and I have found that a heat gun (used with caution) may help...or just make the old adhesive extra sticky. Either way it’s hard, time consuming work.
  19. Apr 15, 2019 at 5:06 AM
    Rexfordian13
    J
    Looks awesome! Are you back on the island this week? I’ll be at Florence Building Supply today (Monday) and conducting a training in Melville Tuesday
  20. Apr 15, 2019 at 5:11 AM
    dlawrence529
    Maine
    Do you have any info on the thermostat or a picture?
    The wires going into the thermostat may not provide power. Mine do not. They just send a signal to the furnace and tell it when to kick on.
    It would probably be tough to troubleshoot a thermostat. Even if you found the problem it would probably be more expensive to fix then it is worth. I'd pick up a cheap one at home depot and try to swap them out. In the meantime, just flip the service switch on your furnace when you aren't home.
    robssol, wilcam47, 98tacoma27 and 2 others like this.
