Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. May 19, 2019 at 8:37 AM
    Martyinco
    Martyinco Well-Known Member
    I’ve started doing those manifolds in basement finishes that I do. Gives customers the option to just turn off one bathroom or whatever they have down there.
    TacoBella[QUOTED] likes this.
  2. May 19, 2019 at 8:41 AM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    Heres my whole house manifold.
  3. May 19, 2019 at 9:06 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I’ve seen a house flood from those, and one was a slow leak in wall and seeped under wood floor and black mold set in, was a mess. Over time some of the nuts loosen idk if it’s from the pipe wanting to go back in the roll they came off
    robssol and truchador like this.
  4. May 19, 2019 at 9:14 AM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    We run these with ball valves on all the branches cuz the plastic ones seem so flimsy and expensive
  5. May 19, 2019 at 9:15 AM
    TacoBella
    Tom
    14 years and counting. Every water connection is open to leak. So far so good. I would do it again. Definitely worth the risk.
    My pipes run in the attic. Don't worry about freezing issues with PEX. We have had PEX freeze with no issues. I have since re-insulated all the PEX runs. No more freeze on the occasional sub 30 Degree nights we may get in the Winter. I don't know how this would fare in the North though.
  6. May 19, 2019 at 9:20 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Those are good for other hobbies :burp:
  7. May 19, 2019 at 9:21 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I won’t ever but we all have choices.
    truchador likes this.
  8. May 19, 2019 at 12:11 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Gonna start tomorrow.
  9. May 19, 2019 at 12:51 PM
    TacoBella
    Tom
    HA I started mine today. Its the only real exercise I get. I spent the last five years converting from Centipede to Bermuda. Bermuda is far more tolerant, I should have 90% Bermuda this season.
    SOSHeloPilot and Acerwin[QUOTED] like this.
  10. May 19, 2019 at 3:13 PM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Very nice. I love Bermuda when it’s been taking care of.
  11. May 19, 2019 at 9:19 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    pic?
  12. May 20, 2019 at 2:02 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    If I need a pad poured for a 7'x7' shed. How deep should the concrete be? I want the shed about level with the ground. What kind of prep do I need? or should I just drop down some pavers?
  13. May 20, 2019 at 5:25 PM
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    I'm assuming you are referring to a floating slab. I'd dig as deep as you can, the deeper the better, fill with crusher run compacted. An inch of #1 clean stone, and 4" of concrete with mesh and rebar. Cut reliefs before setting/building shed. I have about 12" of #2 clean under mine, no concrete, and I regret it everyday. Allows WAY too much uneven settling. I was pressed for time, so I didn't do it right. Another year or two, and I may move it to fix, or jack and fix in place.
    Slashaar[QUOTED] and wilcam47 like this.
  14. May 21, 2019 at 4:04 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Its the kind of thing that needs to be seen in person. You can’t see the crappiness of the cabinets in a photo.
    wilcam47[QUOTED] likes this.
  15. May 21, 2019 at 6:47 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Built a little box and hard mounted the hose reel. Should help with the sitting water that sometimes happens here.
    Slashaar, Gunshot-6A and wilcam47 like this.
  16. May 21, 2019 at 12:08 PM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    So back to the screen porch. Does anybody have experience with screens? Fiberglass versus aluminum? I have 36x80 panels I need to replace the screens on. They stay on year round if that makes a difference.
  17. May 21, 2019 at 12:09 PM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    If you have kids or pets, aluminum will likely show dents easily. I would go fiberglass myself.
    wilcam47 likes this.
  18. May 21, 2019 at 1:06 PM
    Slashaar
    Josh
    Kansas City, MO
    I found a deal for 126 12x8x4 stone pavers for $156 + tax.
    Not sure what the cost after stone, 1 yard of concrete and mesh/rebar would be. Do you think it's a smarter decision to just dig, tamp, put down sand, tamp, then pavers and place the shed on that or would that not be a good idea? Would still have to figure a way to secure the vinyl shed down, assuming something like an screw style ground anchor.
    Just trying to do this cheap and effective and avoid dumping another ~600 into it. I bought a craftsman 7'x7' vinyl shed to house lanmower, wheelbarrow and gardening tools and spent about $680 on it.
  19. May 21, 2019 at 3:31 PM
    wilcam47
    Will
    Bourbon state
    if you are doing 7'x7' you are going to need less than a yard. going to be tough to get someone to come out for less than 1 yard. you could hand mix it but its about 27 80# bags.
    https://www.concretenetwork.com/concrete/howmuch/calculator.htm
    robssol and Slashaar[QUOTED] like this.
  20. May 21, 2019 at 4:00 PM
    Slashaar
    Josh
    Kansas City, MO
    Might just do pavers then for now, then when I redo my patio I'll just have both slabs poured same day. :notsure:
    Ugh. So much money I don't have.
