Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jul 30, 2019 at 1:33 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  2. Jul 30, 2019 at 2:23 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    So what would you do if you just pressure washed your house and found this at the top of the garage door??
    wilcam47 likes this.
  3. Jul 30, 2019 at 2:26 PM
    wilcam47
    Will
    Bourbon state
    cafereef, 916carl, Gunshot-6A and 5 others like this.
  4. Jul 30, 2019 at 2:28 PM
    PackCon
    Connor
    I’m thinking more dry it out and putty it in then paint over it.
    Unless I can just saw out a block and put a small section in without it looking all janky.
    I’m just hoping its not dry rot thats going to start eating away the header.
  5. Jul 30, 2019 at 2:29 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Replace the header. Do it once..Do it right.
  6. Jul 30, 2019 at 2:30 PM
    PackCon
    Connor
    The header is on the inside correct?
    Or should I be ripping out my drywall inside the garage to check that its not all like this?
  7. Jul 30, 2019 at 2:32 PM
    wilcam47
    Will
    Bourbon state
    you need to replace it. its rotted. probably goes out at least 8' maybe longer. they have some higher grade pressure treated wood that is really smooth or put some cedar in there.
  8. Jul 30, 2019 at 2:34 PM
    Brianz1001
    Brian
    too much to type
    I wouldnt do that, you can cut the header back a foot or so, and look at the rot damage, see how far it goes. but in the small picture you have the caulk is seperating from the header letting the elements in causing that rot to accur.
  9. Jul 30, 2019 at 2:34 PM
    wilcam47
    Will
    Bourbon state
    is there a seam on the underside where that 2x6 ends or does it go all the way across?need more pics
    98tacoma27 likes this.
  10. Jul 30, 2019 at 2:49 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    You could also grab a screwdriver, then poke the edge of the header, see if it brakes away or soft, but like said above replace the header. Water has been getting in there for a while to cause that rot. looks like the caulk has shrunk and failed to do its job.
  11. Jul 30, 2019 at 2:57 PM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Pull the siding above it and investigate. There should’ve been some flashing to divert the water, not just caulking.
  12. Jul 30, 2019 at 3:06 PM
    Brianz1001
    Brian
    too much to type
    Hard to tell, but that siding looks like 4x8 plywood panel siding (older style) easier to cut the header back. No flashing is used on the garage header, you can cap it, but this looks older. On doors and windows flashings yes. better picture is needed.
  13. Jul 30, 2019 at 3:12 PM
    PackCon
    Connor
    There is flashing above it and the header extends all the way across the door.
    The caulk has shrunk and has been sucking in water for awhile. The previous owners had their head so far up their butt they couldn’t tell to recaulk it.
    I found it washing it to recaulk and repaint it.
  14. Jul 30, 2019 at 3:22 PM
    23Skidoo
    Paul
    meme
    That 2x that is rotten is just “trim”, just remove it, the header is above it. You’ll be able assess the damage then, probably isolated to the 2x. Add some flashing when you replace it. You will most likely have to remove the leg to get it out.
  15. Jul 30, 2019 at 5:32 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    If u do decide to cut thru the header ur gonna want to block it up from underneath lol those things can carry some weight. Hopefully it won’t come to that and the damage is limited to the bottom trim
    Definitely flash it in good like @23Skidoo said :)
    wilcam47 and PackCon[QUOTED] like this.
  16. Jul 30, 2019 at 5:34 PM
    PackCon
    Connor
    Thanks.
    The header seems solid but you know its always one of those things where you don’t know what you are getting into until you are too into it to back out.
    Its frustrating because I’m also dealing with this:
    Rotting on the inside of the door... the inside out it looks like.
    The joys of homeownership...
  17. Jul 30, 2019 at 5:55 PM
    truchador
    Otto
    WV
    15 DC OR
    Lol no doubt
  18. Jul 30, 2019 at 6:01 PM
    23Skidoo
    Paul
    meme
  19. Jul 30, 2019 at 6:11 PM
    truchador
    Otto
    WV
    15 DC OR
    Wonder where that water’s coming in at?
  20. Jul 30, 2019 at 6:16 PM
    23Skidoo
    Paul
    meme
    I’d assume from underneath. It looks close to grade and doesn’t have a water drainage system. It’s also an in swing door and is relying on the sweep to keep water out, could be entering that way.
    truchador[QUOTED] and PackCon like this.
