Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Sep 9, 2019 at 10:53 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    So I am getting ready to sheetrock and insulate my garage ceiling. The current framing where I am going to hang sheetrock is 48'' on center, What is the best way to attach sheetrock in this scenario? Im assuming Ill have to add some additional framing, just not sure what the best route is for that.20190909_104230.jpg
    Drainbung, Blackout14 and Cooktop86 like this.
  2. Sep 9, 2019 at 11:10 AM
    excorcist
    Reno, NV
    I appreciate it, current plan in my head is to hang perpendicular 2x4s using joist hangers 24'' oc and use 5x8 sheetrock with some liquid nails for extra bonding. Just was curious if someone with more experience in a similar scenario had a better idea.
    wilcam47, shane100700 and Blackout14 like this.
  3. Sep 9, 2019 at 11:24 AM
    dlawrence529
    dlawrence529 Well-Known Member
    Maine
    2015 MGM Double Cab Long Bed
    *edit: I thought the picture was 24". This doesn't cover 48"
    https://www.usg.com/content/dam/USG...-gypsum-panels-installation-guide-en-J371.pdf
    excorcist[QUOTED] likes this.
  4. Sep 9, 2019 at 11:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    That's what I would do as well.
  5. Sep 9, 2019 at 1:04 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    No idea but more pics of second photo left bike please. :popcorn:
  6. Sep 9, 2019 at 1:13 PM
    excorcist
    Reno, NV
    Im just getting that one wrapped up, was quite the challenge to build. Custom carbon fiber tank and tail, decided it would be a good idea to use 1098 headlight and mount to a s2R, ended up painting Toyota 1G3 magnetic grey metallic with a flat clear. Came out pretty cool, here are a couple pictures I have on my comp
    llibrm, rob1208, Lawfarin and 9 others like this.
  7. Sep 9, 2019 at 1:36 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    :bowdown:
  8. Sep 9, 2019 at 8:45 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Id hire somebody, I hate sheetrock...
  9. Sep 10, 2019 at 7:08 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Strap it at 16" OC perpendicular to the existing framing
    TK-422, Blackout14, Hawco636 and 6 others like this.
  10. Sep 10, 2019 at 10:44 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Me too
    wilcam47[QUOTED] and shane100700 like this.
  11. Sep 12, 2019 at 12:52 AM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I replaced my water heater in 2014 but did not change the intake/return hoses because they were fine at the time. The shutoff valve was a little corroded but worked fine. It keeps the water from back-flowing from the attic. It's on the hot side.
    So last night I shut off that valve to replace the whole house filter. When I went to turn it back on it seized completely after a few turns. It would not move either way.
    That meant no hot shower and and I'm not making it in to work.
    Of course the valve was soldered in and the replacement hoses I bought had opposite fittings so I had to cut and replace.
    The output from the heater was corroded pretty bad and would not budge. PB Blaster and an hour soak fixed that.
    Then I had to wait another 1 1/2 hours for all the water to stop trickling down from the attic before I could solder on the new parts.
    Here you can see where the valve seized up.
    New valve, hoses installed an no leaks. Any time I can I replace screw valves with 1/4 turn ball valves. They work so much better.
  12. Sep 12, 2019 at 10:13 AM
    Martyinco
    Martyinco Well-Known Member
    No offense to any of the plumbers on here, but sometimes I wonder if the guys they hire here for these track homes even read the plans :annoyed:
    Finishing a customers basement and if I would have left the rough in plumbing as is. You’d have to step around the toilet to get to the tub :rofl:
  13. Sep 12, 2019 at 12:16 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Ground work isn't for everyone. You actually have to know how to read plans and layout. All without those pesky slabs or walls being there. lol
  14. Sep 12, 2019 at 2:44 PM
    Martyinco
    And I have no doubt that these cookie cutter builders find the cheapest possible labor :annoyed:
  15. Sep 12, 2019 at 7:53 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    That’s what I was thinking. Like purlins for a metal roof.
    excorcist likes this.
  16. Sep 12, 2019 at 7:57 PM
    theesotericone
    Bishop CA
    Yep. It's all about pushing them out as fast as possible. Sub-standard work is all over large scale developments. I've been fortunate to build only custom homes. No two will ever be the same.
  17. Sep 15, 2019 at 12:44 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Installed two 48" LEDs in the attached garage to replace the single 40w which was located directly behind the garage door opener.
    Gunshot-6A, Coolerman, TK-422 and 7 others like this.
  18. Sep 15, 2019 at 5:47 PM
    Oregon Mike
    Oregon Mike Well-Known Member
    Eugene OR
    18 AC OR
    Had to spend some time up on the roof in the rain this morning. I guess I need to get up there more often to check things out :cheers:
    FastEddy59, wilcam47 and shane100700 like this.
  19. Sep 15, 2019 at 6:48 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Sitting in the living room thinking about how many light switches we need to replace and where we’re putting the new switches for can lights and the spotlights for the paintings and we hear “drip....drip” from the AC closet, we shoot each other looks like “I don’t wanna check it, you go check it.” And I open the closet door and see wetness around the air handler.
    Pop the return grate (unfiltered) off and see water standing on the slab, crap.
    Turns out the drain tube was blocked (who uses soft line for drain tube?) so I got to re-plumb it with PVC.
    Tile is now also set and grouted in the master bath.
  20. Sep 15, 2019 at 7:37 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Updated the color of door and added anew style door knob. F009C36C-7663-4EBE-81ED-58CF172FB8F3.jpg
