Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Nov 15, 2013 at 8:21 AM
    #1841
    scocar
    scocar Patron of the Farts
    And then you'd have to get a bigger water heater...
  2. Nov 15, 2013 at 8:25 AM
    #1842
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Or a whole extra one
  3. Nov 15, 2013 at 1:41 PM
    #1843
    killianeric
    killianeric Well-Known Member
    High Desert
    2007 Bass Model Tacoma
    Thanks guys! And my dad just really loves old things and wanted to find a way to incorporate all of his old stuff into his backyard and this is what he came up with. The shed on the far left we know as the school shed, because of the old school bell on the roof, or the Snap-On shed. My dad has decided to turn it into a saloon. Which is going to be badass. He just bought about ten whiskey barrels to use as tables, and he also has been collecting bottle caps for the roof. So that should be interesting.
    My dad even inspired his own dad to do some stuff in his backyard
  4. Nov 16, 2013 at 9:12 AM
    #1844
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Created a new redwood deck platform. This is my first deck. On the area to the left, we took out the huge Elephant Palm that was about 16 feet tall and had a trunk base about 4 foot wide. My wife hated the tree. My son cut it down. We thought it was going to be tough but it had almost no root system (basically just sitting on the ground).
    I built out a floating frame for the deck. In hindsight, I should have made all the planks run the same direction. It would have been a little more difficult to frame but it would have made adding the deck planks look nicer. I coated everything with deck sealer before putting on the floor.
    Here, I was initially planning to stagger the wood but because of the angle of the joists to the right, it made it difficult to ensure any seams met across a joist. The wood I bought was only 8 foot lengths (short bed). You can see where I started staggering them on the left. Then I realized it wasn't going to work right so I cut the boards at the point they are in this picture.
    I finished the deck. I bought some 2x6x10 boards and ripped them down to make the deck railing balusters. I put a 45 degree cut on the bottom of each baluster. I coated everything with deck sealer.
    Here's a shot from the other side of the railing.
    I eventually plan to cover the rest of the green area with a deck. We're going to cut some openings around the major rocks for interest.
  5. Nov 16, 2013 at 10:29 AM
    #1845
    scocar
    Do you charge admission to your back yard?:p Looks like a fun-park.
  6. Nov 16, 2013 at 10:33 AM
    #1846
    Evil Monkey
    Robert
    Escondido, CA
    Might be a way to pay for the deck. Thanks for the idea. :D
  7. Nov 16, 2013 at 10:36 AM
    #1847
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Is that cedar or redwood ? Sure has a nice colour
  8. Nov 16, 2013 at 11:14 AM
    #1848
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    He said redwood in the original post. It does have a nice color though.
  9. Nov 16, 2013 at 11:20 AM
    #1849
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Beautiful deck. Love the wood you picked out.
  10. Nov 16, 2013 at 11:21 AM
    #1850
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Looks like all heart redwood but there are some knots in the wood. It is actually beautiful with a clear treatment on it for protection.
  11. Nov 16, 2013 at 12:22 PM
    #1851
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    it is a nice "color"
  12. Nov 16, 2013 at 1:18 PM
    #1852
    OZ-T
    Peter North
    British Columbia
    Damn , obviously not enough coffee this morning
  13. Nov 19, 2013 at 8:16 PM
    #1853
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    ...made retractable "landing gear" for my workbench build... :D
    since it's default location has to be in a corner of my garage, i want it to be easily moveable to the center of the garage... it will be quite heavy once i finish the top slab and attach it to the frame...
    the wheels retract automatically (basically via gravity, and geometry) by lifting up on an end of the bench. to deploy the wheels, i just pull the t-handle back (spring loaded), and put it in a clasp on the underside (not visible in the photos), then just lift up each end like before.. the spring in tension helps the wheels swing into the deployed position, and then the load is channeled directly to the lower stretchers on the bench (and some some rubber "shock absorbers"made from rubber furniture foot protectors) - it rolls nice and smooth ;)
    ...here is the frame, resting on ground (wheels up):
    ...wheels down:
    ...a look at the mechanism, wheels down:
    ...mechanism, wheels up:
  14. Nov 19, 2013 at 8:26 PM
    #1854
    scocar
    Sweet. Complex, but sweet. I think I saw plans for that setup a few years ago. I really like having a mobile project table/bench/outfeed table, and will be looking at designs this winter. My existing one put together from various scrap years ago can be vastly improved upon, but it has been extremely useful in concept.
    I need to look more closely at the mobile stairs at Home depot, too...LOL.
  15. Nov 19, 2013 at 8:40 PM
    #1855
    OZ-T
    Peter North
    British Columbia
    Very nice job wiley
  16. Nov 19, 2013 at 11:05 PM
    #1856
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Lots of detailed shit in there man. Very nice.
  17. Nov 20, 2013 at 10:45 AM
    #1857
    wileyC
    Centerville, OH
    thanks! ...if i can get the oz-t stamp-of-approval i must be doing something right... :cool:
  18. Nov 20, 2013 at 10:48 AM
    #1858
    wileyC
    Centerville, OH
    ...simpler than it looks... i did some research before hand, and some guys were building retractable wheels w/ an included cam "lift" mechanism (a handle of sorts connected to a large wooden cam pushes down on a sill plate w/ casters), ...but since i'm a novice and work slowly, i didn't want to get into that amoutn of complexity... so, just came up w/ my own method...
  19. Nov 20, 2013 at 5:38 PM
    #1859
    ImpulseRed008
    Susan
    SC
    Nice job on the table.
  20. Dec 2, 2013 at 12:20 PM
    #1860
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    New toilet today. Old one started leaking. It had a good 30 year run.
    The whole bathroom needs remodeled but I haven't gotten there yet.
    I was planning on hunting this morning but this took priority.
