Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Oct 15, 2019 at 6:00 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    have you seen this thing in the wild yet ?
    https://www.makita.ca/index2.php?event=tool&id=3044&catid=9
    Martyinco likes this.
  2. Oct 15, 2019 at 6:49 PM
    jsi
    jsi Well-Known Member
    native earthling
    You guys have my respect. I'm one of the owner representatives. I make sure the all the data networks and other technology is done to our standard. The site supers amaze me by not killing a sub or two. Or for that matter not killing an owner or two. On the current job a bunch of the "VP" level office workers decided they didn't like the way the doors swung. This is of course after heaven only knows how many design meetings, final design reviews, purchasing, and installing the door frames. The when the CFO got the change order price, he helped the VP's understand that the doors were not changing.
    IPNPULZ and shane100700 like this.
  3. Oct 16, 2019 at 4:53 AM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    To note, my walls are drywall faced, not open studs
  4. Oct 16, 2019 at 5:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    You can still do either, just use metal boxes. The metal clad will look nicer. You can do PVC also. That will be a clean look. The only thing you "can't" really do is run straight wire. It has to be in something or Romex.
  5. Oct 16, 2019 at 5:22 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    shane100700 likes this.
  6. Oct 16, 2019 at 5:23 AM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Then I would definately run conduit and pull wire. I wouldn't want romex stapled exposed to see. Cleaner look, if your not going to fish it behind the drywall.
  7. Oct 16, 2019 at 5:51 AM
    cafereef
    Romex would be run inside the wall, I can access the top of the stud wall from the attic to run wire down and will staple to the trusses in the ceiling. nothing would be exposed. Since the gang box would be inside the wall cavity, that's why I was wondering if the wall not being insulated would be an issue.
  8. Oct 16, 2019 at 5:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    Use a remodel box
  9. Oct 16, 2019 at 6:01 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    New work boxes are amazing, especially for us non-pro folks!
    98tacoma27[QUOTED] likes this.
  10. Oct 16, 2019 at 6:15 AM
    Martyinco
    Martyinco Well-Known Member
    Zero issue
  11. Oct 16, 2019 at 3:37 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    so questions for yall folks more knowledgeable than me. im getting a vapor barrier installed under my house and the insulation under there has seen better days as well. I was talking with someone the other day and they say a lot of homes in my area don't see much (if any) benefit from having the underside of the house insulated. it didn't quite sound right to me but I got to thinking about it and its usually cooler under there than it is in my house in the summer, and we don't have much of a winter. should I worry about putting up new insulation?
  12. Oct 16, 2019 at 4:59 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Dad got the gate finished for me, drive through gate is just shy of 11’ and will swing completely open against the fence, the frame is 4x6 tubing, hinges are rated for 120 lbs each, the hinge side post is 6x6 and 36” concreted in, the latch side is a 4x6 post set 36” and concreted.
    The walk gate is around 38” opening width and is also attached to a 4x6 set at 3’ and cemented.
    Overall I’m happy with how stout it is.
  13. Oct 16, 2019 at 5:07 PM
    truchador
    truchador Well-Known Member
    Otto
    WV
    15 DC OR
    weathertech, seat covers, scratches
    Any joist/subfloor funkiness from having insulation in the cavities?
    I wouldn’t stuff any more fiberglass up in there
    I would insulate around the inside of crawl space wall and rim joist with some 2” xps board and sprayfoam
    wilcam47 likes this.
  14. Oct 16, 2019 at 5:47 PM
    jpneely
    Charleston, SC
    I wouldn't say funkiness, I don't see much mold, if any. the last house I had here that had a vapor barrier had a fine layer of mold "dust" on the rafters. this house isn't near as bad.
    truchador[QUOTED] likes this.
  15. Oct 16, 2019 at 6:43 PM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Yo. This flooring still sucks.
  16. Oct 16, 2019 at 6:57 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Septic tank failed, installed a nice big 1550 gallon tank. Thankfully I’m a plumber, got it done in 2 easy days, have to seed the grass, feeling good having it done, old tank was falling apart.
    HerT4R, DirtyTerp, 23Skidoo and 9 others like this.
  17. Oct 16, 2019 at 7:34 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I like that floor
  18. Oct 16, 2019 at 7:38 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Just dont thread the screw in the wrong way and have the tab fall off into the wall. That leads to a rather angry trip to Home Depot for another box.
    Dont ask me how I know. :bananadead:
    tacofish, Kolunatic, jsi and 6 others like this.
  19. Oct 16, 2019 at 8:44 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Ummm lefty loosy, righty tighty... o_O
    HerT4R, 95 taco, disconnected and 2 others like this.
  20. Oct 17, 2019 at 3:56 AM
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    Thanks! Lifeproof vinyl plank. Fresh oak color.
