Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jan 10, 2020 at 3:08 PM
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    I would have picked something different for the floor, but it's a huge room.
    Slashaar, wilcam47 and shane100700 like this.
  2. Jan 10, 2020 at 5:23 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Did a shitlap under the loft with recycled fence boards.
  3. Jan 10, 2020 at 6:58 PM
    mCat
    mCat Well known member.....lol member
    Bay Area
    2014 Tacoma TRD DCSB
    Nice Johnson level. Haven’t seen one of those mahogany levels in a while. Any concerns with dust getting into that slot along the bottom of the ship lap
  4. Jan 10, 2020 at 8:25 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Ha, thanks that levels been around a long time. No worries with dust since it's in the shop end, nothing that can't be sucked up with the vac.
    six5crèéd likes this.
  5. Jan 12, 2020 at 7:36 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Finished up the back wall of my "shitlap" in the shop.
  6. Jan 12, 2020 at 9:47 PM
    scocar
    scocar Patron of the Farts
    You should serve drinks there.
  7. Jan 13, 2020 at 12:31 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    worked a bit on my backyard finally. I absolutely hated this backyard, its still not my favorite with a lot of things to still change, like the sunroom walls. But for now its a huge improvement and i actually feel like i could spend some time out here.
    Before:
    After:
    Also found this gem that put power to that terrible lattice gazebo :bananadead:
    robssol, pudge151, buyobuyo and 6 others like this.
  8. Jan 13, 2020 at 1:11 PM
    scocar
    Every house I've bought is WTF inside and out. Some have been better than others.
    Are you just gonna plant some new stuff, or are you going to re-imagine the whole yard and do some site prep first?
    1. How is the drainage?
    2. Where to you want water supply?
    Many many more questions after this.
    Slashaar, shane100700 and Kolunatic like this.
  9. Jan 13, 2020 at 1:14 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    drainage is terrible. It all leans and flows towards the house and makes a swimming pool up by the master bedroom wall shown.
    Were going to deal with it for now, but eventually going to fully demo and redo the concrete back here. But for now, the walls of the sunroom are coming down, going to do my best to preserve the patio cover as it was a patio cover before they put the sunroom walls up. Still trying to gameplan on the removal of the walls.
  10. Jan 13, 2020 at 1:30 PM
    scocar
    Save this for when you need it. The problem with diving into this is you will realize how truly fucked up and ignorant pretty much every irrigation system is that you encounter:
    https://www.irrigationtutorials.com/
    He is a licensed landscape architect, and one of my licensed PE water engineers used this for his house.
    Get this no matter what
    https://www.amazon.com/Graphic-Guid...eparation&qid=1578950683&s=books&sr=1-2-fkmr1
    Buy a copy of this
    https://www.ebmud.com/water/conserv...er/plants-and-landscapes-summer-dry-climates/
    And look into the Sunset guide, too.
    https://www.amazon.com/New-Western-Garden-Book-Gardening/dp/0376039205
    And finally this for conceptual inspiration about how you will use the space and leaves the nuts, bolts, and details behind.
    https://www.amazon.com/Foundations-...pe+architecture&qid=1578950749&s=books&sr=1-5
    And go sit outside with a beer(s) with them and some post-its and a sketch pad. Because all four are intertwined.
  11. Jan 13, 2020 at 1:33 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    saved.
  12. Jan 13, 2020 at 1:37 PM
    scocar
  13. Jan 13, 2020 at 1:39 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    once we act like Gorbachev and tear down these walls, it will be nice and wide open back there except i will have multiple heights of concrete. I foresee that as a tripping hazard once intoxicated.
    I really need to investigate and see if i can spot how the hell the walls are attached to the roof. I really hope all of it doesnt need to come down.
    Drainbung likes this.
  14. Jan 13, 2020 at 1:48 PM
    scocar
    Put some planters (easy and cheap) and/or change of surface material at each grade change. Gives people a visual cue and reason to look down.
    And wear a helmet. Also so you don't hit your head on the awning.
    Oh look, skinny yard treatment
    And don't forget a play area for your kids. Strategically placed to minimize noise where you are sitting.
  15. Jan 17, 2020 at 12:45 AM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Damn! The cost of copper is really going up!
    I live in an area where the water is really hard. Water softeners have been the solution for years but like all things in So-Cal the leftards have taken over and banned them.
    It is bad enough without one you would have to remove all shower heads and faucets and soak them monthly in CLR to remove the calcium and lime deposits. Rust buildup is also an issue.
    I was grandfathered in but my water softener finally got to the point that it was no longer able to be rejuvenated.
    I bought a whole house 30" carbon filter but after 30 days the water pressure would drop enough that you couldn't take a shower and flush a toilet at the same time. Replacing the filters was expensive.
    So now to today, after months of searching to find the best solution, although still not as good as a water softener, this is the best I can do.
    I want to keep it all copper 1 inch to not have any restrictions but the price of the copper fittings has been rising crazily.
    I have bought most of the copper fittings from Amazon at 1/3 the cost of the local big box stores so that helped a little.
    I have most of it here but am still waiting on the main unit to be delivered. Then the fun begins. Luckily I can do plumbing.
    IT ended up being about $2500 for all the filters and parts and another $500 in copper. Schedule 80 would have been cheaper but it's harder to acquire here.
    Schedule 40 is crap and would just leak.
  16. Jan 17, 2020 at 3:17 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Nice job on sketchup
    How long you think to change out salt free cartridge?
    TK-422[QUOTED] likes this.
  17. Jan 17, 2020 at 5:58 AM
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    Going to derail this, but why would California ban water softeners? Could you not have just gotten on Amazon and replaced your existing one?
  18. Jan 17, 2020 at 6:12 AM
    Greeny
    Greeny Well-Known Member
    Martin
    Rexburg, ID
    bone stock 2001 Taco 4x4 TRD
    TK-422, I don't know about costs in your neck of the woods, but (in Pocatello, ID) I go to Standard Plumbing for the vast majority of my plumbing needs. The staff is very knowledgeable and their prices are often cheaper than Home Depot/Lowe's.
    TK-422 likes this.
  19. Jan 17, 2020 at 12:06 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    ^ This. Plus you don’t have to use salt and on some level I can understand the thought process to ban it. Don’t agree with it, but I can understand the approach to lead others to want to. However back to the issue at hand, we use potassium (not salt) in a standard water softener. Not sure why you couldn’t just go that route?
    TK-422 and Drainbung like this.
  20. Jan 17, 2020 at 12:09 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Probably due to softeners using as much as 30 gallons of water to regenerate
    robssol, scocar, 23Skidoo and 3 others like this.
